Is energy of a free particle observable?
sweet springs
Is Hamiltonian of a particle in free space H=P^2/2m OBSERVABLE ?
-Yes, we can surely observe energy in some manner.
-No, ∫de|e><e| is not identical operator I, thus |e>s does not form a complete set.
As an example, energy eigenstate |e> degenerates, as |e=p^2/2m> = α|p> + β|-p>, according to the directions of momentum.
∫de|e><e|p> = α*|e=p^2/2m> does not give |p>.
∫de|e><e|-p> = β*|e=p^2/2m> does not give |-p>.
Your advice on the correct use of the word OBSERVABLE is appreciable.
Regards.
Regards.
Yes, there are issues with defining *time-independent* wavefunctions for free particles, because the momentum operator eigenstates are not suitable as wavefunctions, since they are not square-integrable. Since the Hamiltonian commutes with the momentum operator in the case of a free-particle, this is also true for the energy eigenstates.
Probably the best way to think about a "real" free particle is with a wave-packet, a superposition of momentum eigenstates, which can then be propagated in time by solving the time-dependent Schrodinger equation. Such a solution would not however represent an eigenstate of the time-independent Schrodinger equation (which I think is what your post is about).
Regarding observables, they correspond to the expectation values of measurable quantities. The result of any single measurement of the energy of a free-particle wavepacket will yield p^{2}/2m, where p corresponds to one of the momentum eigenstates in the superposition. However the expectation value of the energy will be the weighted average of p^2/2m over all of the states comprising the wavepacket. Since the distribution of momentum states in the wavepacket is fixed (in the absence of a perturbing potential), for a given wave-packet the expectation value of the energy will be a constant of the motion, and so is consistent with classical physics.
Thanks SpectraCat for your physical analysis.
My concern is rather on mathematical definition. Operator P^2 allowing degeneracy + and - p is not complete but observable?
Regards.
Regards.
I guess I don't understand what you are getting at; "observable" is a physical concept. A postulate of QM is that all single measurements (i.e. observable quantities) correspond to eigenvalues of Hermetian operators, and the mean value of a series of measurements corresponds to the expectation value of that operator, which will in general *not* be an eigenvalue, unless the system happens to be in an eigenstate of the operator.
For a free particle, the operators \hat{p} and \hat{K}=\hat{p^{2}}/2m commute, therefore they share the same set of eigenstates, which is a complete set of states.
EDIT: fixed incorrect statement pointed out by peteratcam in post #7
I know the defitition of observable in Dirac II-10 "We call a real dynamical variable whose eigensates form a complete set an observable."
Thanks to SpectraCat P form a complete set, but P^2 doesn't due to degeneracy of + and -.
So P^2, or energy of free particle, is not observable in this definition. Correct?
Regards.
hi, coincidentally I am also confused with the concept of free particle. From what i google i found out that there is someone who wrote a contradicting statement from what griffith has written.
here's the link.
folk.uio.no/trondson/freeparticle.pdf
sorry, but i am still a beginner in quantum mechanics, but can you guys point out which one is the more correct. thanks.
Regards.
What are the eigenvalues of the 2x2 identity matrix?
What are the eigenvectors of the 2x2 identity matrix?
Can you form a complete basis out of eigenvectors of the 2x2 identity matrix?
What relevance do these questions have to your question?
SpectraCat said:
A postulate of QM is that all measurements (i.e. observable quantities) correspond to expectation values of Hermetian operators.
I think I've picked you up on this one before. The result of a measurement must be an eigenvalue of the hermitian operator associated with the observable. The expectation isn't the same as the result of a measurement.
I don't know about before, but you definitely caught me here, thanks. I was rushing to write it before leaving work and I changed part of the message at the last minute. That's no excuse of course, and I have fixed it now. (Just for the record, I explained it correctly in my original response in post #2.)
Regards.
No, not correct. The -p and +p eigenstates are distinct eigenstates. Yes, they happen to yield the same eigenvalue for the energy operator, but so what? The 2-s and 2-p orbitals of the hydrogen atom are also degenerate ... does that mean the energy of those states isn't an observable too in your analysis? I really still don't understand what you are getting at here. Are you sure you know what it means for a set of eigenstates to be complete?
Hi, thanks peteratcam for showing an interesting case.
Ans. 1
Ans. Any vectors
Ans. Any vector is eigenvector, including (1,0) and (0,1) that is usual basis. Since I has only one eigenvalue, 1, two-fold degeneracy is happening. it is similar to P^2 case.
I cannot catch you by your subtle suggestion.
Question from me to catch you. In your view, 2x2 or any identity operator is observable?
Regards.
Hi. SpectraCat. I have no objection that |p>s form a complete set.
Let me state my question again. Do |e>s form a complete set where |e> is an eigenvector of Hamiltonian of a free particle?
The answer is No, isn't it? We need more than |e> to describe the state fully.
Then following the definition of Dirac book, energy of a free particle is not observable. Right?
Regards.
PS Please remind that I use the word OBSERVABLE following the definition of Dirac Book. I fully agree with you that we CAN OBSERVE 2s or 2p orbit energy.
Yes they do. The states you call |e> are IDENTICAL to the |p> eigenstates. How can the set be complete for one operator and not the other? A complete set is complete! Your logic is completely nonsensical as far as I can tell. I am using the same definition for observable that you are. You keep asserting the the set of |e>'s is incomplete, without any justification beyond your degeneracy argument that several people have pointed out to you is wrong.
You keep coming back to the same point repeatedly, when multiple posters have tried to explain why you are on the wrong track. Please think about our responses carefully and try to comprehend why our explanations are correct. If you are still confused, post a *detailed* mathematical derivation of why you think the set of energy eigenstates for a free particle is incomplete, so that we can pinpoint where your confusion lies.
Hi. SpectraCat.
Please be patient to coming back to my first comment.
∫de|e><e| does not equal to identity operator I, does it?
So we cannot say |e>s form complete set, can we?
Of course I admit |p>s or { |e,+> |e,-> } form complete set.
Is the distinction above by degeneracy is meaningless?
Regards.
sweet springs said:
Hi. SpectraCat.
Ok, but this is my last reply in this thread unless you post something with new content. I'll give it one last shot. It doesn't seem like you are carefully considering what I (and others) have posted before. I have no idea what you are trying to represent with those lines you quoted from your original post ... they don't seem correct to me. I have no idea what you are trying to signify by placing an equal sign inside your ket vector description.
Yes, of course it does. The eigenstates of any Hermetian operator *by definition* form a complete set. In this case, the eigenstates of the kinetic energy operator, as I keep pointing out in every post, are IDENTICAL to the eigenstates of the momentum operator.
You say you have no problem with ∫dp|p><p|=1, well then since the two sets are identical, ∫de|e><e|=∫dp|p><p|=1. I can't make it any more explicit than that.
EDIT: Well maybe I can ... consider the expansion:
|p'> = ∫de|e><e|p'> = ∫dp|p><p|p'> = ∫dp|p>delta(p-p') = |p'>, where "delta" is the Dirac delta function. That is correct (but trivial) way to use the resolution of the identity in this case.
Yes, we can (see above).
Of course I admit |p>s [STRIKE]or { |e,+> |e,-> }[/STRIKE] form complete set.
Good, but I have no idea what you are trying to represent by the vectors in the bracket.
Yes! Degeneracy has no bearing on completeness of a basis .. that is what peteratcam was trying to get you to realize with his post.
Hi. SpectraCat. Let me write my understanding of QM.
Any real physical variable forming complete set is Hermitian, but not all the Hermitian form complete set.
Momentum P form complete set and is Hermitian.
Energy of free particle P^2 is Hermitian but does not form complete set.
Here completeness means projection operator ∫de or Σe |e><e|=I where e is eigenvalue of operator.
PS1
As for Identity operator I, there's only one eigenvalue, 1, thus one eigenstate |1> so if it formed complete set, projection should be |1><1|. Projection |1><1|any vector>∝|1> thus vector does not come back to itself but fall into |1>. It means that identity operator is of course Hermitian but does not form complete set, the case of ultimate degeneracy.
Identity operator I is expressed by help of any observable E as ∫de or Σe |e><e| where e is eigenvalue of E. Similarly by held of |p>s, P^2 is expressed as ∫dp |p>p^2<p|. These examples show that I or P^2 does not form a complete set but a complete set helps representation of I or P^2.
Am I right, peteratcam? I appreciate your teaching.
PS2
I apologize my vague notion of { |e,+>, |e,-> }. Here + or - is the direction of motion, introduced parameter to dissolve degeneracy.
Regards.
This point is at the heart of your confusion. The eigenstates of the identity operator must form a complete set!
Physicists love to abuse notation. One such abuse is to label eigenstates of an operator by the associated eigenvalue. This is fine without degeneracy, but is ambiguous with degenerate eigenstates. So for example, |\mathbf p\rangle isn't ambiguous, whereas |E\rangle is ambiguous. You might benefit from the discussion of quantum numbers in https://www.physicsforums.com/showthread.php?t=375171. A more transparent definition would be to say: a hermitian operator A has eigenvalues \lambda_1,\lambda_2,\lambda_3,\lambda_4,\ldots not necessarily distinct and we choose deliberately an orthonormal set of associated eigenvectors |a_1\rangle,|a_2\rangle,|a_3\rangle,\ldots.
So the point is that \int dE | E \rangle \langle E | is meaningless because the |E\rangle are not unambiguously defined. We could include an extra quantum number, for example the direction of momentum ( in 1D).
\sum_{p = +,-}\int dE | E,p \rangle \langle E,p |
And actually, this is still wrong. States are equally spaced in momentum space, so there should be a density of states factor when writing as an integral over energy. Continuum limits are always a bit fiddly.
Peter
Hi. petratcam. I almost agree with you except the point that
#1
I|any vector> = 1|any vector>
How can you generate a complete set from this relation?
#2
| any vector > is expressed by using any observable A of eigenvale a as
|any vector >= ∫da or Σa ψ(a) |a> where ψ(a)=<any vector|a>
I am afraid you are confusing #1 Generation (or Formation) of complete set from I with #2 Representation of |any vector> by a complete set generated by A not I.
Identity Operator Does Not Form or Generate a Complete Set.
I will appreciate it if you correct my mistakes by showing the way of generation or formation of a complete set from I.
If it does not generate a complete set then it is NOT OBSERVABLE according to the definition of Dirac text.
Regards.
Energy is a real physical variable ... so your example falls into case 1 (I guess), but your language is *very* imprecise here .. I have corrected it below (my text in red).
The eigenstates of the momentum operator p form a complete set and p is Hermitian.
This means that the momentum eigenvalues are real, and the momentum eigenstates satisfy the relations:
\hat{\textbf{p}}\left|\vec{p}\:\right\rangle=p\left|\vec{p}\:\right\rangle (eigenvalue/eigenvector relation)
\left\langle\vec{p}\:&#039;|\vec{p}\:\right\rangle = \delta\left(\vec{p}\:&#039;-\vec{p}\:\right) (orthonormality)
\int|d\vec{p}\:\left|\vec{p}\:\right\rangle\left\langle\vec{p}\:&#039;\right| = 1 (completeness, or closure)
\left\langle\vec{p}\:&#039;\right|\hat{\textbf{p}}\left|\vec{p}\:\right\rangle = \left\langle\vec{p}\:\right|\hat{\textbf{p}}\left|\vec{p}\:&#039;\right\rangle^{*} (Hermicity of operator)
where \delta is the Dirac delta function, and I have used vector notation to help distinguish eigenstates and eigenvalues.
If we apply the Hamiltonian operator for the free particle, \hat{\textbf{p}}^{2}/2m, to one of these states, it is easy to see they are also eigenstates of that operator (i.e. they are energy eigenstates). Of course the orthonormality and completeness relations still hold, since we are talking about the same states.
No, as I told you many times, even if you corrected the language to state what you are trying to say correctly, the content is wrong. I gave you explicit justification above why it is wrong. Yet you keep claiming that it is true without any justification or proof. Why do you think the eigenstates of the free-particle energy operator do not form a complete set? Show a detailed proof.
PS1
As far as I can tell, everything you wrote above is nonsense, and indicates that you don't have a clear idea what the terms eigenstate, projection operator, observable, Hermetian operator, closure relation, or identity operator mean. I suggest that you go back to the textbook, read carefully, and work some problems so that you understand better what you are talking about. Then you should be able to phrase your question better, if you haven't already realized the answer for yourself.
#1
That relation shows that any complete set is an eigenset of the identity operator. Any basis you can think of for a vector space V, is composed of eigenvectors of the identity.
#2
No this is wrong. You are using the frequent abuse of notation I referred to previously.
Observable A has a set of eigenvalues a_1,a_2,a_3,\ldots (not necessarily distinct) and an associated set of eigenvectors |1\rangle,|2\rangle,|3\rangle\ldots (by our choice, necessarily orthonormal).
Any vector:
|\psi\rangle = \sum_{n}\psi_n|n\rangle
where
\psi_n = \langle n | \psi \rangle.
The eigenvalues have nothing at all to do with this expansion. However, \psi_n, does have the interpretation as an amplitude to measure a_n (assuming non-degenerate) in an experiment.
Only in special cases is it appropriate to change the sum over labels into an integral over eigenvalues.
Maybe I am because I don't understand the distinction you are trying to make.
Hi, SpectraCat. Thanks a lot for your corrections and teachings.
I almost agree with you except :
I agree with you that an eigenstate of P with eigenvalue p belongs to an eigenstate of P^2 with eigenvalue p^2. But the reciprocal, an eigenstate of P^2 with eigenvalue p^2 does not belong to an eigenstate of P with eigenvalue p. It is a linear combination of two eigenstates of P with eigenvalues p and -p.
This shows that the eigenstates of P and the eigenstates of P^2 are not same.
I tell it you in another way. The mathematical principle says One eigenstate for One eigenvalue of Hermitian, doesn't it?
So it can't be TWO ENERGY eigenstates |p> and |-p> for ONE ENERGY eigenvalue p^2. ( I made 1/2m =1 simply.).
We should call it TWO MOMENTUM eigenstates corresponds to one ENERGY eigenvalue.
I hope the above satisfy you.
Energy operator cannot distinguish degenerated two momentum states. We can't call it complete.
For completeness, we must introduce another operator MOMENTUM.
Regards.
Thank you peteratcam for correction. I would like to show my view different from yours just on one point :
Definition of EIGENSET of the Hermitian E is set of bra {|e>} for all e that satisfy E|e>=e|e>.
Applying this definition, eigenset of the identity operator consists of only ONE bra corresponding to e=1 that is only ONE eigenvalue of identity operator.
"E form a complete set" means the above set {|e>} is a complete set of space. P or X does, P^2 or identity operator doesn't.
Regards.
No, no, no, no and no. You are wilfully ignoring the points that Spectracat and I have been making. You can't use the eigenvalue as a label for eigenstates when the eigenvalue is degenerate.
I am absolutely astounded that you have convinced yourself that the eigenvectors of the 2x2 identity matrix don't span the vector space.
Hi peteratcam. Thanks for your clear statement of No^5.
Again just on one point:
Yes, you are right in case you request a label be complete.
Label by eigenset of P^2 or I is like saying I am in US or on Earth,very large area.
If you wish more detailed and ultimate labeling e.g. I am in xx street NY, another eigenset of OBSERVABLE operator e.g. P should be introduced, but this is another and side story.
Regards.
I almost agree with you except :I agree with you that an eigenstate of P with eigenvalue p belongs to an eigenstate of P^2 with eigenvalue p^2. But the reciprocal, an eigenstate of P^2 with eigenvalue p^2 does not belong to an eigenstate of P with eigenvalue p. It is a linear combination of two eigenstates of P with eigenvalues p and -p.
Ok, I think I may see where your confusion arises now. Eigenstates can be degenerate, and furthermore, when you have two degenerate eigenstates, *any* linear combination of them is *also* an eigenstate. However, this does not affect the basis in question (the complete set of momentum eigenstates in this example), because the new eigenstates that you construct from the linear combinations are not *orthogonal* to the old ones. They are linearly dependent on your original set of momentum eigenstates, so you wouldn't include them in the closure relation that seems to be confusing you.
No, it most certainly doesn't ... where did you get that idea? In fact, if you were reading our posts carefully, you would see that peteratcam told you exactly the opposite in post #17. Eigenstates don't have to have unique eigenvalues ... you already know that there can be degeneracies, so it is strange that you would make such a statement.
Well, who said anything about completeness of an operator? Completeness is a characteristic describing of a set of vectors, as I indicated in post #19. And who cares what the energy operator can "distinguish"? Your problem is that you are focusing on your own linguistically-based interpretations of precisely defined mathematical terms, rather than learning what they are intended to mean in context, and using them appropriately. As I indicated earlier, you need to go to a textbook and study this stuff some more ... learn the standard language so that you can communicate effectively. This is becoming timesome.
Thanks peteratcam, SpectraCat.
Maybe it's good to confirm the points we share:
E: energy operator
P: momentum operator
eigenset of E: all {|e>} that satisfy the equation E|e>=e|e>.
eigenset of P: all {|p>} that satisfy the equation P|p>=p|p>.
subspaces specified by different eigenvalue (eigensatate) are orthogonal.
<e'|e>=δ(e-e'), <p'|p>=δ(p-p').
degeneracy
<p|e>=<-p|e>=0 for e≠p^2/2m
<p|e>+<-p|e>=1 for e=p^2/2m
A form a complete set {|a>} :
{|a>} satisfy the equation A|a>=a|a> and
projection { ∫da and/or Σa }|a><a|=I identity operator.
If you find anything wrong or incorrect, I should appreciate your teachings.
Then I would like to restate my question.
E form a complete set or not?
Regards.
E: energy operator
How many times! You continue to wilfully ignore my point that E|e>=e|e> is needlessly misleading notation when there is degeneracy. Until you engage with this point it seems pointless trying to correct any of your other claims.
Hi, peteratcam.
Eigenvalue relation E|e>=e|e> holds both with and without degeneracy.
I would like to know your idea to write down energy eigenvalue relation in your not misleading notation.
Regards.
Define |e>.
peteratcam said:
Define |e>.
E|e>=e|e>
Regards.
  • #31
sweet springs said:
Define |e>
E|e>=e|e>
Regards.
At this point, I give up.
  • #32
E: energy operator
Ok, fine, but there are an infinite number of equations that satisfy that relation for any single value of e. So you can't use those vectors as an expansion basis
Nope this is wrong ... or at least there exist |e> vectors that satisfy your "eigenset" definition that are not orthogonal.
degeneracy
I have no idea what you are trying to say with the above relation. It happens to be true for certain choices of |e> as you defined it originally. So what? There are an infinite number of cases where it does not hold.
This is not correct, you are missing the orthonormality condition. I showed you the proper way to express what you are trying to express in at least one of my previous posts.
Go back and read them until you understand them .. we are not getting anywhere with this.
  • #33
Hi, SpectraCat.
As you are well aware eigenset of coordinate {|x>} or eigenset of momentum {|p>} is another popular example of expansion basis with continuous so infinite number of eigenvalues.
There cannot exist. As you are well aware for eigenset of Hermitian H: all {|h>} that satisfy the equation H|h>=h|h>, <h'|h>=δ(h-h') for continuous eigenvalue or δh'h discrete case, otrthogonality.
Sorry, I found my mistake in the formula.
<p|e>+<-p|e>=1 should be replaced to |<p|e>|^2+|<-p|e>|^2=1
Then for any choices of |e>, say α|p>+β|-p>.
|<p|e>|^2+|<-p|e>|^2=α*α +β*β=1.
This is the definition of eigenvectors forming a complete set. Your improvement, if there is, should be appreciated.
Readers, I would like to know your reply to the question "Do eigenvectors of E form a complete set?"
Mine is "NO".
Regards.
  • #34
sweet springs said:
Hi, SpectraCat.
But that is not what I said. I said there are an infinite number of eigenvectors satisfying your "eigenset" definition for a *single* eigenvalue of E.
Read more carefully and think about what you are saying ... you are assuming that you are right and we are wrong. I assure you this is not the case, we have provided numerous mathematical explanations of why this is so. What you wrote above is not a true statement. I can provide any number of counter-examples .. can you think of one?
I don't understand how you can write the above statement, and still not understand our other points. Is the |e> vector you gave above orthogonal to |p> and |-p>? Do the three vectors |e>, |p> and |-p>, above all satisfy the "eigenset" definition for E? Do you see your mistake yet?
No it is not. I have already given you the correct definition in another post. You go find it .. I will not repeat myself any more.
Well, that is the first time you asked *that* particular question, so at least we are making progress, even if it is agonizingly slow. I would say that it is possible to choose a sub-set of the eigenvectors of E that form a complete basis. In fact, there are an infinite number of subsets that can be chosen as complete bases. One such choice, as I pointed out in my original answer, is the eigenvectors of the momentum operator.
Mine is "NO".
And you are WRONG. Since we can find a sub-set of eigenvectors of E that is complete, the set of all eigenvectors of E must also be complete, although there are linear dependencies among some of the members.
  • #35
Hi. SpectraCat.
Yes, I have been in accord that eigenstate |e>=α|p>+β|-p> where |α|^2+|β|^2=1, not a "vector" but a "plane" 2 dimensional complex "eigenplane". Maybe word eigenvector was misleading. Eigenstate or eigensubspace is more correct use of word.
But this is mathematics of Hermitian. And E is Hermitian.
Anyway I would like to hear you.
To choose independent specific "vectors" from "plane", you need help of other operator than E, P for example.
I call it eigenvectors of P form a complete set but eigenstates or eigensubspaces of E do not form a complete set.
We are in progress now.
Regards.
  • #36
sweet springs said:
Hi. SpectraCat.
Yes, I have been in accord that eigenstate |e>=α|p>+β|-p> where |α|^2+|β|^2=1, not a "vector" but a "plane" 2 dimensional complex "eigenplane". Maybe word eigenvector was misleading. Eigenstate or eigensubspace is more correct use of word.But this is mathematics of Hermitian.
No .. that is wrong, you evidently don't know the definition of Hermetian.
Your favorite two-state example from above is a perfect example of a vector that is linearly dependent on, and therefore not orthogonal to, the other eigenvectors |p> and |-p>. I pointed this out to you in my last post ... you just refuse to read my posts carefully and think this through. I am almost starting to think that you are intentionally baiting me with your apparent obtuseness.
Regards.
Not really .. you are still using the same old flawed logic. You are saying things that make no sense and are inconsistent with other statements that you made yourself. I have pointed out to you that there is a subset of eigenvectors of H (I am tired of you calling the Hamiltonian operator E ... the well established symbol is H), which is complete. You have agreed that is complete. That should end the discussion .. I'll try one last time.
1) The set of eigenvectors of the momentum operator p form a complete basis
2) The eigenvectors of p are also eigenvectors of H
3) Therefore, there exist a set of eigenvectors of H that form a complete basis
QED ... it does not matter that, due to degeneracy, there exist an infinite number of other eigenvectors of H that are not part of that complete basis. Once a basis is complete, it is complete forever and can be used for resolution of the identity.
Do yourself (and us) a favor and look up the definitions of the following terms in the context of Q.M. ... I believe that you do not know their proper definitions and you are definitely not using them correctly.
Hermetian, orthogonal, complete basis, linear-dependence, resolution of the identity
  • #37
Hi.
Thanks for teachings. Let me write my understanding now.
Operator whose eigenvectors form a complete set is observable.
Here, the conditon ★ each basis must be labelled by different eigenvalue ★ does not apply.
example 1 energy of free particle P^2/2m, P^2/2m ψ= p^2/2m ψ
There are two independent ψs that are labelled by the same eigenvalue p^2/2m.
example 2 Identity operator, Iψ=1ψ
There are as many as dimensions of Space independent ψs that are labelled by the same eigenvalue 1.
Considering there are d(e) indepentdent basis labelled by eigenvalue e, projection to bases is
{∫de and/or Σe}Σi:from 1 to d(e) |e_i><e_i| = I
I was haunted by the idea ★. Thanks a lot.
  • #38
Hi. I write down my understanding again.
Operator E is observable when direct sum of eigenspaces labeled by e of Eψ=eψ compose the whole space.
Space = subspace(e') + subspace(e") + ..., where subspace(e') is composed of {ψ| Eψ=e'ψ} so called eigenspace. one eigenspace is orthogonal to the others.
Probability to get obeserved value e' of E is length of the projection of the state on the eigenspace(e') squared.
Regards.
  • #39
1) Operator E is observable when direct sum of eigenspaces labeled by e of Eψ=eψ compose the whole space.
2) Space = subspace(e') + subspace(e") + ..., where subspace(e') is composed of {ψ| Eψ=e'ψ} so called eigenspace. one eigenspace is orthogonal to the others.
3) Probability to get obeserved value e' of E is length of the projection of the state on the eigenspace(e') squared.
Regards.
I don't know ... this doesn't look quite right to me. In point 1, I don't know what the words "eigenspace labeled by e" means. I also don't think that your statement has anything to do with it being "an observable". The concept of an observable in quantum mechanics is connected to one of the fundamental postulates, which says that any physically measurable quantity (i.e. observable) has a corresponding operator within the framework of Q.M. There are various theorems based on this postulate (and others) which prove that such operators are Hermetian, and have a complete basis of eigenstates. You should look them up in a standard Q.M. text. In other words, the completeness of the basis set for *any* operator corresponding to a physical observable is complete *by definition* ... it doesn't need to be proved.
I think you also still have significant confusion between the resolution of the identity, which is valid for any complete basis of states, and "the set of all of the eigenstates" of an operator, which allows for degeneracies, and therefore may contain states that do not satisfy an orthogonality condition, which is (usually) required for resolution of the identity.
In point 2, I am not sure what you mean when you say an eigenspace "is orthogonal to" another eigenspace, unless it is the trivial case where all the vectors in one space are orthogonal to all of the vectors in the other space. Finally, I don't see how 3 can possibly be correct ... first of all, I don't know what you mean by "projection of the state on the eigenspace" ... is that the sum of the projections of the state on all the eigenvectors in the space? If so, point 3 definitely seems wrong.
  • #40
Hi. thanks for comment.
"eigenspace labeled by e" is subspace composed of {ψ} that satisfy Eψ=eψ.
I expect that statement #37 and #38 on observable are equivalent although the latter is not popular. It is just an expectation and I have not seen a mathematical proof.
"a subspace is orthogonal to other subspace" means any vector in an subspace is orthogonal to any vector in other subspace. For example in XYZ space, a subspace Z axis is orthogonal to the other subspace XY plane. It means that any position vector starting from origin along Z axis, (0,0,z) is orthogonal to any position vector starting from origin on XY plane, (x,y,0). Projection of a position vector starting from origin (x,y,z) to subspace XY plane gives the projected length sqrt(x^2 +y^2)=sqrt(x'^2+y'^2) where x' and y' are coordinates of different chosen X and Y axis. Maybe these are trivial things to you.
Regards.
PS In http: //www.quantiki.org/wiki/index.php/Observables_and_measurements
Observables with degenerate spectra was helpful to write this memo.
  • #41
PS^2 There was confusion of eigenspace with eigenvector in my previous posts.
Thanks again for your teachings.
