I Is Entanglement Commutative in Quantum Computing?
  • I
  • Thread starter Thread starter Kenneth Adam Miller
    Entanglement
Kenneth Adam Miller
I've seen diagrams of quantum computer components at a high level that discusses multiplexing laser reflections over many qubits, and I have to believe that entanglement as a hardware operation has to be scaled to the many qubits by means of some operation that is applied to each of them simultaneously. That being said, if I remember correctly, there were examples of the slit experiment at a microscopic level to give readers at a introductory level an impression of what the hardware was doing. But I don't think that that was strictly what was actually at that level. Perhaps I working with a very vague understanding, but what I want to know is, if you have light that is entangled, and you strike a super cooled qubit of any kind, does that mean that that qubit is also suspended in entanglement? In other words, is entanglement commutative?
If you have a pair of entangled photons A and B, and one of those photons B interacts with a qubit C, the amount of entanglement between A and the joint system BC remains the same (assuming no additional environmental interaction).
The amount of entanglement between A and B may change due to B interacting with C, but if A has no further interaction with B or C, the total entanglement between A and BC must remain constant.
Ok, so it's as though A now shares a total entanglement with all three, but BC sort of share a subspace determined by the metrics of their interaction, is that correct?
If I understand you correctly, yes.
A shares entanglement with BC, and the amount of entanglement between A and BC is the same before and after B and C interact.
What's different is how much entanglement A shares with just B, or with just C.
There's a useful concept called the monogamy of entanglement that says the amount of entanglement B shares with AC cannot be less than the sum of the entanglement between A and B, and between B and C.
E(A:BC)\geq E(A:B) + E(A:C)
So, as A becomes less entangled with B, A must be more entangled with C, (or at least, the maximum possible entanglement between A and C increases.
Fascinating. Thank you.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
