Is External Energy Loss Essential in Calculating Final Energy?
  • Thread starter Thread starter gunblaze
    Energy
The discussion centers on whether external energy losses, such as heat and sound, should be included in the calculation of final energy when applying the work-energy theorem. It emphasizes that work done is defined as the change in energy, specifically the difference between initial and final energy, while accounting for energy losses. The conversation clarifies that net work can be expressed as the final mechanical energy minus the initial mechanical energy and energy losses. It distinguishes between conservative and non-conservative forces, noting that only conservative forces contribute to potential energy. Ultimately, the conclusion is that all forms of resistance and energy loss must be considered for accurate calculations.
gunblaze
ok.. guyz, I'm not really sure on how I'm going to phrase this qn, so juz hope you guyz out there understands
work done= Change in energy
= Energy(final) - energy(initial)
For this eqn, do you have to add in external energy loss eg: heat n sound energy into your energy final..? or do you juz take account the energy change in the body?
Sry.. not very good at this
If there are losses, the net work is
Work = energy(initial) - energy(losses) - energy(final)
That means that energy losses shouldn't be accounted for work done rite?
just in case you aren't clear yet, this is what I understand from work-energy theorem:
there are many kinds of energy. consider kinetic energy. KE of any point mass of mass 'm' at an instant when its velocity is 'v' is KE=(1/2)mv^2
the outright formula for work, applicable in any case whatsoever, with sound loss, heat loss, etc. is:
Net work done = Final KE - Initial KE
remember that this is the work done by all forces, including dissipative ones. The sign of each work done MUST be taken into account. for eg. if a body of mass m is thrown up through a height h with only gravity acting, the force due to gravity=mg, and it acts downwards, but the displacement h is upwards so the work done is
W=(mg)*(-h)= -mgh
Now, there are 2 kinds of forces. CONSERVATIVE forces are those whose 'works' DO NOT depend on the path of the particle, for example gravity, a fixed charge etc. NON-CONSERVATIVE forces are those whose works DO depend on the path of the particle, for example friction. these forces generally result in heat loss, sound etc. When only conservative forces act on a body, we assign potential energies related to these forces. the total Mechanical energy (ME) of a body is the sum of its kinetic energy and its potential energies due to all the conservative forces. Then the following equation holds:
Net work done by all external forces (other than these conservative forces) = ME(final) - ME(initial)
Let the work done by friction and all the other such dissipative forces be w(nf). Let the net work done on the body due to all other forces be W. So,
W + w(nf) = ME(final) - ME(initial)
therefore, W = ME(final) - w(nf) - ME(initial)
but the work done by the dissipative forces causes a reduction (assumed to be reduction, if I took it as increase, I would simply have some changes in sign in the final formula) in ME of the body, ME(losses).
Thus, w(nf) = ME(losses)
so, the final formula is
W = ME(final) - ME(losses) - ME(initial)
as said before.
IF you wanted to find the NET work done by ALL forces other than those for which you have assigned potential energy(all, including dissipative and non-dissipative), you can write this straight:
W = ME(final) - ME(initial)
If you still don't get it, I recommend the book "Fundamentals of Physics" by Resnick, Halliday and Walker (6th ed) or "Fundamentals of Physics" by Resnick and Halliday(2nd ed).
All formulas must contain all resistance to the energy input.Ergo,resistance of a 'bearing' of a particular motor must be involved along with loads of that motor.
LEAVE NOTHING OUT!
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
