Undergrad Is Fermat’s principle appicable to a plane wave?
Fermat’s principle, which states that light follows the path of least time, faces challenges when applied to plane waves, as the actual light ray does not travel directly from point A to point B if they are not aligned with the wave vector. The discussion highlights that interpreting "path" for a wave is complex, suggesting Huygens's principle may be more appropriate. The traditional formulation of Fermat’s principle may have limitations, particularly when considering scenarios where the light source is not on the direct path between two points. The conversation raises questions about the validity of applying Fermat’s principle in general cases, emphasizing that the path of least time does not always correspond to a real light ray. Overall, the application of Fermat’s principle to plane waves and non-linear paths remains a topic of debate.
PFfan01
Fermat’s principle states that light follows the path of least time. In textbooks, a specific formulation of Fermat’s principle is about the optical path between two points, A and B: How can a ray of light, emitted from point A, reach point B? Suppose that there is a plane wave in free space, with the line AB not parallel to the wave vector. In such a case, the actual light ray never goes from A to B because the actual light ray must be perpendicular to the equiphase planes. From this, a question comes to me: Is the Fermat’s principle appicable to a plane wave?
Not really. It's hard to interpret what "path" means for a wave. Huygens's principle is probably better here.
How do the ray paths relate to the wave crests in a pure plane wave?
They are perpendicular
Ok. So maybe this trivializes the example, but can you think of any ways that a ray path other than a straight one could be identified with a (strictly) plane wave?
A plane wave refers to something of the form ##A e^{i(\mathbf{k} \cdot \mathbf{x}-\omega t)}## and propagates in a straight line. Anything else, and it wouldn't be a plane wave.
The (plane wave) phase function defines equiphase planes of motion (wavefronts), with the wave vector as the normal vector. From one equiphase plane to another equiphase plane, the path parallel to the normal vector is the shortest and has the minimum optical length. According to Fermat’s principle, light follows the path of least time, and this path is an actual light ray. ---- Thus the Fermat’s principle for a plane wave can be formulated as: from one equiphase plane to the next, the optical length of an actual ray is the shortest.
It seems to me that the traditional formulation of Fermat’s principle about the optical path between two points has a loophole.
I don't think the plane wave example is trivial. A minor fixing can provide a more general challenge as follows.
Suppose that there is a point light source at S in free space, with SA not parallel to AB. In such a case, the actual light ray never goes from A to B because the actual light ray must be perpendicular to the equiphase surface. Thus the challenge persists: Is the traditional formulation of Fermat’s principle valid for general cases?
I'm still not clear on what you're asking. If the source is at S where S doesn't lie on the ray path between A and B, then what does it have to do with the path from A to B?
S is not between A and B. The source is at S, and all equiphase surfaces are spherical with the common center S. SA is not parallel to SB or AB.
So then what is the (attempted) application of Fermat's theorem?
Are you saying that "light travels from A to B along the path of least time" is invalid because there might be light that does not travel from A to B?
It seems to me that the book by Born and Wolf (M. Born, E. Wolf, Principles of Optics, Pergamon Press, Oxford, 1986, p. 114) interprets what "path" means for a wave.
What I mean is: For arbitrarily given two terminal points A and B, the real light ray does not necessarily go from A to B in general. In other words, for given two points A and B, generally the path of least time is not a real light ray.
  • · Replies 42 ·
29K
  • · Replies 54 ·
10K
