High School Is it impossible to prove that some functions are periodic?
The discussion centers on the complexity of proving whether functions G(s) and F(s) intersect periodically, particularly in the context of moving averages and complex numbers. Participants express confusion over the definition of the moving average and the conditions under which intersections occur. It is noted that the functions may not intersect at all points, and the periodicity of functions can be linked to the halting problem, indicating that some functions may be inherently unprovable as periodic. The conversation highlights the challenges of defining the problem clearly and the ambiguity in the initial question, leading to a conclusion that the example problem remains unanswered and possibly unanswerable. Ultimately, the discourse emphasizes the need for clarity in mathematical discussions to facilitate understanding and resolution.
mustang19
Heres an example.
Let G(s) be the moving average of all previous values of f(s).
G(s) and F(s) intersect at multiple points. Is it possible to prove that the intersections happen periodically?
Mathematics news on Phys.org
Could you explain what the 1 over infinity is supposed to be?
Likes mustang19
That's the summation term from 1 to infinity. The software garbled it.
Like this?$$F(s) = \sum_{n=1}^{\infty} \frac{1}{n^{s i +2}}$$
What do you mean by "moving average over all previous values", and does f(s) mean F(s)?
Do you have a proof that they intersect at all? With complex numbers this is not trivial.
Likes mustang19
I just graphed the functions. If you don't know what a moving average is then look it up.
As I suspected this problem seems very difficult or impossible to solve.
I know what a moving average is, but the definition is not unique (average over which range?), and your description doesn't make sense.
Did you plot both the real and imaginary part?
Currently the problem is not even well-defined.
Likes mustang19
I plotted both the real and imaginary parts.
The range is over the entire function, or if your software does not support that, then try from the origin to S.
That doesn't make sense either.
How did you define G(s), can you show the formula?
And they had intersections at the same point?
Likes mustang19
How did you define G(s), can you show the formula?And they had intersections at the same point?
I don't have the formula handy. You just average all the previous points.
They intersected at different points. I want to know if either or both of the graphs are periodic.
Im not too concerned about the specifics. If you can answer anything related to this question then that would be interesting. I am just asking if its always possible to prove whether a function is periodic.
That would work as description if there would be a finite set of those points, but you don't have that. Average from 0 to s? Is your function defined for negative s? Make some limit procedure to "average" from -infinity to s? Something else?
Which means the functions do not intersect. Only their real and imaginary parts.
A clear no. You can construct functions that are periodic if and only if some turing machine halts, and there is no algorithm that can determine this for all turing machines (halting problem). Those function definitions will look weird, however (like "f(x)=sin(x) if this turing machine halts, f(x)=x if it does not").
Likes mustang19
Yes
Yes
Which means the functions do not intersect. Only their real and imaginary parts.A clear no. You can construct functions that are periodic if and only if some turing machine halts, and there is no algorithm that can determine this for all turing machines (halting problem). Those function definitions will look weird, however (like "f(x)=sin(x) if this turing machine halts, f(x)=x if it does not").
Is that a proof? Are you sure they never intersect?
You seem to be claiming I claimed they always intersect at different points. No, I said they intersected at some points and the parts intersected at others.
Anyway you basically answered my questions to a good enough level with your last paragraph.
No, but you claimed they would intersect, and I don't see evidence for that so far.
An intersection of two functions requires that the function values are identical - for complex numbers, this means both real and imaginary part have to be identical.
mfb said:
No, but you claimed they would intersect, and I don't see evidence for that so far.An intersection of two functions requires that the function values are identical - for complex numbers, this means both real and imaginary part have to be identical.
I really don't see how that helps. If you have any more questions about the function let me know, but it seems pretty well defined for me. Cant you just use the moving average feature in matlab? I really don't see where the ambiguity was, I am able to graph the function fine.
It is well-defined now, after 10 posts with multiple rounds of questions how it is defined.
The range of definition and the range you average over.
In addition, the first post had the (probably wrong, but certainly not backed by evidence) claim that the functions intersect.
Likes mustang19
So basically, the example problem is well defined and unanswerable.
Nothing in this thread has indicated that the example problem (as clarified in #11) is unanswerable. Only that it is unanswered and that it might be unanswerable.
Likes mustang19
So its unanswerable, as far as anyone knows.
And it's answerable, as far as anyone knows. Might be answerable, might not be. We do not know. Trying to spin it one way or the other does not change that.
Please dial back the attitude.
People give help here out of the kindness of their hearts -- none of us gets paid for this. Also, I guarantee that @mfb knows what a moving average is, but that's not what he asked:
mfb said:
What do you mean by "moving average over all previous values"?
Your question was unclear from the start, and it took 11 posts to figure out what you were asking. It's not the responsibility of responders to go "look it up" -- it's your responsibility to ask a question that makes sense, and with as much information as you can provide.
Likes mfb
