I Is it possible for a non-natural number to be a number base?
  • I
  • Thread starter Thread starter swampwiz
    Base
The discussion explores the feasibility of using non-natural numbers, such as π, as a number base. While some participants argue that it is mathematically possible, they emphasize its impracticality and the confusion it introduces, particularly with negative or fractional bases. Examples illustrate how negative bases can represent numbers differently, but they also highlight the complexity and potential for infinite representations. The consensus leans toward viewing non-integer bases as mathematically interesting yet ultimately unhelpful for practical applications. The conversation concludes with a general sentiment that using π as a base is seen as absurd due to the complications it creates.
Mathematics news on Phys.org
swampwiz said:
A commenter at Quora said that is possible for there be something like
12π
which would evidently be ( π + 2 ). This seems ridiculous.
It is possible. And it is not ridiculous, just incredibly impractical. And for ##b<1## or negative ##b## things become confusing, too. I guess negative numbers won't work, but I haven't elaborated it.
So basically, it's a mathematical curiosity like the gamma function.
It's mathematically useless, as well as practically useless. The gamma function is not.
Likes swampwiz
By the way, ##12_\pi = (2+\pi)_{10}## could as well be ##12_\pi=C_{16}=12_{10}## since we will never have on overflow, so all numbers are one digit numbers. Of course we would soon run out of symbols ...
Negative radix works fine and eliminates the need for unary negation.
So ##27_{10}=300_{-3}## and ##-27_{10}=1000_{-3}\,?##
fresh_42 said:
So ##9_{10}=9_{-3}## and ##-9_{10}=100_{-3}\,?##
Allow me to illustrate with base -2.
The "one's" place has its usual meaning. Position 0, place value (-2)0 = 1.
So ##0_{-2} = 0## and ##1_{-2}## = 1.
The "two's" place is in position 1 with place value (-2)1 = -2.
So ##10_{-2} = -2## and ##11_{-2}## = -1.
The "four's" place is in position 2 with place value (-2)2 = 4.
So ##100_{-2}## = 4, ##101_{-2}## = 5, ##110_{-2}## = 2 and ##111_{-2}## = 3
[I am assuming a convention where each digit falls in the range from 0 to the ceiling of the absolute value of the radix minus one]
See my example for base -3.
The positive values for odd powers of the base have then to be added lower even powers, which exceed the usual representation symbols 0,1,…,b−10,1,…,b−1.
For base -2 we would have 8−2=408−2=40, right? And the higher the odd power the more symbols we need. What is ##2^{9}_{-2}\,?##
##1000_{-3}## would denote -81 + 0 + 0 + 0.
You would want ##1200_{-3}## to denote -81 + 54 + 0 + 0 = -27.
Edit: Blundered. ##1000_{-3}## is indeed -27 + 0 + 0 + 0.
But ##1000_{-3}=1\cdot (-3)^3 + 0\cdot (-3)^2 + 0\cdot (-3)^1 + 0\cdot (-3)^0 =-27_{10}## not ##-81_{10}##.
Likes jbriggs444
I am not sure why you are insisting on making this difficult. The alphabet for a radix -n digit-string representing a natural number is {0, 1, ..., n-1}.
Sorry, I seem to have slipped a digit, you are correct.
You said a negative base makes a unary minus sign unnecessary. So what are ##-9_{10}## in base ##-3## and ##2^9_{10}## in base ##-2\,?##
We need to add copies of ##(-3)^1## up to three, so it is ##30_{-3}## and copies of ##(-2)^8##. The result are more ciphers than ##0,1,\ldots , b-1\,.## And I get ##+27_{10}=300_{-3}##.
O.k., I see, the minus sign results in an additional digit ##b##.
Likes jbriggs444
Ahhh, I had not understood the expected convention when you wrote ##2_{10}^9##. It seemed that you were intending ##2^9## as a single digit with value ##512_{10}##. But, in fact, you were trying to write ##2_{10}## raised to the ninth power. [With a single digit literal, the radix subscript adds nothing but confusion]So let's go down the place values.
0 = 1
1 = -2
2 = 4
3 = -8
4 = 16
5 = -32
6 = 64
7 = -128
8 = 256
9 = -512
10 = 1024
So to get ##-512_{10}## we need ##11000000000_2## = -1024 + 512 = -512.
To get ##-9_{10}## we need ##1200_3## = -27 + 18 + 0 + 0 = -9
0 = 1
1 = -2
2 = 4
3 = -8
4 = 16
5 = -32
6 = 64
7 = -128
8 = 256
9 = -512
10 = 1024
So to get ##-512_10## we need ##11000000000_2## = -1024 + 512 = -512.
To get ##-9_10## we need ##1200_2## = -27 + 18 + 0 + 0 = -9
Yes, a negative overflow compensated by additional lower terms will do. But we could as well add ##b## to the set of digits and avoid the overflow: ##-9_{10}=1200_{-3}=30_{-3}##.
You could go that way, but now you are no longer using the canonical representation and you have lost radix efficiency. Obviously there are lots of ways to slice and dice if one is building a convention from scratch.
The support for non-canonical representations is one inelegance with non-integer radices.
Depends on the preferred interpretation. If we have a negative base, then my thought was, that the gaps become longer between two useful powers, i.e. an additional sign ##b## is needed. With your classical view, the numbers will be longer. I find it a bit artificial to go knowingly in the wrong direction and compensate the mistake, rather than adding what actually contributes.
Likes jbriggs444
Elegance is in the eye of the beholder, of course. I take the opposite view.
Likes fresh_42
By the way,
12π
Nope. The hexadecimal numeral C, often written as 0xC, is equal to the decimal numeral 12, but ##12_\pi## means ##1 \cdot \pi + 2 \cdot 1 \ne 12_{10}##.
Right. In the programming world, a base b is a positive integer larger than 1, such as base-2, base-8, base-16, and base-64. All of these bases are in common use. For a given base, the digits are 0, 1, 2, ..., (b - 1).
I would even go so far as to say using ##\pi## as a base is ridiculous. In any number system that uses a positive integer base b, with b > 1, any integer is a finite sum of multiples of powers of b. How would you represent 253, for example, in base-##\pi##?
Likes swampwiz
Calling non-integer bases "ridiculous" is going a bit far.
Let us convert 253 to base pi. The log of 253 to base pi is 4.833... So we will need to start with five digits to the left of the radix point -- in the position with place value pi4 ~= 97.
So we divide 253 by pi4 and truncate to the next lower integer. The result is 2.597... which rounds down to 2.
So the first digit is 2.
We subtract 2pi4 from 253 yielding 58.181817931995...
Now it is just a matter of rinsing and repeating. We need to convert 58.181817931995... to base pi. We already know that the next digit will be in the pi3 place. So we divide by pi3 yielding 1.87... which rounds down to 1.
So the second digit is 1.
We subtract pi3 from 58.181817931995... yielding 27.17554125...
We repeat the process, dividing this by pi2 yielding 2.75... which rounds down to 2.
So the third digit is 2.
We subtract 2pi2 from 27.17554125... yielding 7.4363324495...
We repeat the process, dividing this by pi yielding 2.3670581356...
So the fourth digit is 2
We subtract 2pi from 7.4363324495... yielding 1.15314714233...
We repeat the process, dividing this by pi0 = 1 yielding 1.15314714233...
So the fifth digit is 1.
so ##253_{10}## ~= ##21221_{\pi}##.
We could continue the process indefinitely, populating further positions to the right of the radix point.
But there is no reason to calculate with powers of ##\pi##. Normally we write ##1,2,3,\ldots ,b-1## until ##b## marks the overflow from ##b^0## to ##b^1##. But with ##b=\pi## we will never reach an overflow by counting. Therefore we need for all numbers different from ##\pi^n## an extra sign. This is ridiculous. If we use your method instead, which is by the way the method you rejected for ##b < 0## since it accumulates regardless of an overflow, then all integers are infinitely long. This also can be called ridiculous.
I find we get funny notations for bases ##b=\frac{1}{n}##. I won't call them ridiculous, but a transcendental base is for some reason; even an irrational one is, since neither creates natural overflows.
Likes swampwiz
It is the base pi expansions which are infinite, not the integers. And it is not all integers. Almost all.
That was my reason for not treating base/radix ##\pi## seriously.
Likes swampwiz
