Is it possible to find orbital velocity depending on time?
Determining the orbital period of a satellite requires knowledge of its radius, as per Kepler's Law, and cannot be calculated with only the gravitational constant (G) and Earth's mass. The relationship established by Kepler indicates that the square of the orbital period is proportional to the cube of the radius. When calculating Earth's mass using the moon's orbit, it is suggested to subtract the moon's mass from the total to achieve a more accurate result. The calculation provided shows that after accounting for the moon's mass, Earth's mass is approximately 5.99E+24 kg. Accurate calculations are essential for precise astrophysical measurements.
hmvince
A satellite is in orbit around earth,
(you know G, mass of earth, etc. but NOT the radius)
is it possible to find orbital period?
If only G and mass are all that is known, then No. According to Kepler's Law you must know the radius to get the orbital period, (or vice versa). All you can determine with only G and M is the ratio of the orbital period squared to the radius cubed...which is equal to 4(pi)^2 / GM.
Creator
Sorry about the late reply, but thankyou very much.
If it's not too much trouble, when calculating the mass of the Earth using the moon as a reference and Kepler's 3rd Law, is it correct to subtract the moon's mass after completing the sum:
Code:
m[SUB]e[/SUB] = (4*(pi)[SUP]2[/SUP]*r[SUP]3[/SUP]) / (G*t[SUP]2[/SUP])
m[SUB]e[/SUB] = (4*(pi)[SUP]2[/SUP]*385000000[SUP]3[/SUP]) / (G*2358720[SUP]2[/SUP])
m[SUB]e[/SUB] = 6.07[SUB]E[/SUB]+24
Should I be subtracting the moons mass to get:
Code:
m[SUB]e[/SUB] = 6.07[SUB]E[/SUB]+24 - 7.36[SUB]e[/SUB]+22  =   5.99[SUB]E[/SUB]+24
I know its not a big difference but I would like to be doing this correctly.
Thanks very much
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
