Is it possible to generate lift without thrust?
  • Thread starter Thread starter chizwoz
    Lift Thrust
The discussion centers on whether it's possible to generate lift without thrust, particularly in the context of a video game scenario where a character can dive and then ascend using a cape. Participants argue that while lift can be generated through speed and shape, true upward movement without thrust is theoretically impossible unless aided by external factors like updrafts. The conversation highlights that a character could temporarily gain altitude by exchanging speed for lift, but this is not the same as achieving upward movement without any thrust or drag. Additionally, the physics of gliding and the potential for utilizing wind turbulence in urban environments are considered. Ultimately, the consensus leans towards the idea that while the game's portrayal may not be realistic, it does not entirely violate the laws of physics.
chizwoz
I'm having a bit of a disagreement with someone and I hope some of you can enlighten us.
It sounds rather silly but the debate is around the physics used in a video game (Batman Arkham City). In this game, the character can jump off buildings and shape his body into a downwards dive (much like a skydiver trying to gather speed). He can then open his cape and this not only slows his descent but he can also supposedly use the resistance of his cape to then fly back upwards.
My understanding of physics tells me this is in principle impossible, unless there is something like a huge upward gust of wind which provides more upward force than that provided by his (downward) weight and since the character can do this anywhere at will, it's safe to assume no such gust is present.
I hope a few of you can weigh in (giggle) on the issue.
Welcome to PF!
In this case, thrust is provided by gravity during the descent, but then it is lost. The glider has to build up speed, which it later exchanges for altitude via conservation of energy. So he can only glide upward until he's lost so much kinetic energy/speed that his wings can no longer provide lift.
Well, in theory he turns himself into a glider.
Given that, he can use forward speed to generate lift, up to the limit of the kinetic energy available. That is, he will be able to regain height up to a significant fraction of the drop he just took - but no higher.
However, in a cityscape he could quite possibly use the wind turbulence around buildings to pick up lift.
If you've ever watched a seagull in flight, they are absolute masters of this trick and make it look like they can fly wherever they please without so much as a flutter of their wings.
So maybe Batman is just concealing his secret.
I have a problem with threads about something that just came out of a fiction writer's head. I frequently dream about flying and this is always achieved (in my dreams) by holding my body in a particular way and sort of launching off. . . . .
Would there really be any percentage in discussing the possible Physics of this?
I realize I am being a grumpy old man about this but my issue is that these days, Science, Magic and Science Fiction are just one blur for most young people (and a number of old ones too). I am sure that Matrix -type and other computer generated activities are taken as real and the Star Trek 'science' is considered very very seriously by those who should know better.
The rules of PF actually forbid speculative and unfounded topics yet we keep getting posts about how computer game simulations can be made 'realistic'. It worries me.
I guess I should point out that this particular thread is far less questionable than many you can find here.
I think the thread is ok here because it isn't speculating about non-mainstream physics, it is merely asking if the physics demonstrated in a game is accurate. It isn't a science fiction question or a crackpottery question, it is a question about if something presented in fiction is actually real.
My first thought on seeing this question was this:
https://www.youtube.com/watch?v=ypMX9ApF77s
Assuming that updrafts could be found within the city, the main issue would be the lift to drag ratio. Perhaps if the cape was replaced by a hang gldier setup. Wiki article:
wiki_glide_ratios.htm
Well with all do respect, what I was trying to do with this question was actually clarify the difference between fact and fiction, not blur the line.
And thanks for the answers people.
I don't think this has anything to do with updrafts since the OP is talking about a no-thrust situation and an updraft enables gravity to provide thrust.
True - but then the answer is simply a boring 'no'.
For a glider in a steady descent with respect to the air, gravity always provides some thrust = force in the direction of flight (assuming lift to drag and corresponding glide ratio is not ∞). An updraft only changes the situation with respect to the ground, so I don't get your point here.
Getting back to the op
Yes in the case where the caped person could temporarily gain altitude in exchange for reduction in speed. If the question was "is it possible to generate lift without drag", then the answer would be no, but this is not the same thing.
Um...no, it isn't. The answer is yes.
The OP is not talking about a glider in a steady descent, the OP is talking about a glider swooping upward.
Not in a steady state situation, since in the real world, there's always some drag associated with producing lift, so some "thrust" (forwards force in the direction of flight with respect to the air) is required to overcome the drag. As mentioned previously, speed can be built up and then momentum of the aircraft allows it to produce lift without thrust as it slows down.
This is not the same as asking if the caped person could temporarily gain altitude in exchange for speed... [emphasis added]
Right: so the steady state is not what the OP was asking about. The OP was asking if what he saw in the video game was accurate. From his description, it sounds like the answer is yes.
rcgldr said:
This is not the same as asking if the caped person could temporarily gain altitude in exchange for speed, or to gain altitude if an updraft is greater than the sink rate of the "aircraft".
russ_watters said:
The OP is not talking about a glider in a steady descent, the OP is talking about a glider swooping upward. Right: so the steady state is not what the OP was asking about. The OP was asking if what he saw in the video game was accurate. From his description, it sounds like the answer is yes.
My fault, my last edit to my previous post didn't take (sometimes physics forums locks up on me). I corrected it to read: Yes in the case where the caped person could temporarily gain altitude in exchange for reduction in speed. If the question was "is it possible to generate lift without drag", then the answer would be no, but this is not the same thing.
Sure. Lift has nothing to do with "thrust". It's just a function of your airspeed and shape. If you have enough speed (kinetic energy) you can always convert it into height (potential energy). See this video at 2:30:
https://www.youtube.com/watch?v=iS6p6sgwElI
Here he gets the kinetic energy from the plane and has no initial downward speed to reverse, so it is "simple". But theoretically the KE could also come from a long fall with arms and legs retracted. I'm not sure if such a wingsuit (or a cape) can be made efficient enough to then cancel downward speed, and go upwards. But it wouldn't violate any law of physics. A more rigid wingsuit would definitely allow this.
Assuming no wind: If he started the fall with zero speed, he could never get higher than he started.
chizwoz said:
...unless there is something like a huge upward gust...
Interestingly you don't need updrafts to gain energy. An efficient glider can use a downdraft to gain extra kinetic energy during the fall, and then convert it back into potential energy outside of the downdraft in still air, ending up higher(but same speed) than he started:
http://www.icarusengineering.com/Dynamic-Soaring-and-SE.htm
