Is Light Truly Massless if It Can't Penetrate Walls?
  • Context: Undergrad
  • Thread starter Thread starter bodhi
    Light Mass
The discussion revolves around the nature of light, specifically whether photons are truly massless given their inability to penetrate walls. Participants explore the implications of masslessness, energy, and interaction with matter, raising questions about the relationship between these properties and the behavior of light in various contexts.
  • Some participants question the premise that being massless should allow photons to penetrate walls, suggesting that masslessness and penetration are not correlated.
  • Others argue that photons, while massless, possess energy and momentum, which influence their interactions with matter.
  • A participant proposes that characteristics of particles cannot exist without mass, challenging the concept of massless particles.
  • Some participants assert that passing through objects is more about interaction than mass, citing neutrinos as an example of particles with mass that can penetrate matter effectively.
  • There is a discussion about the relationship between energy, mass, and the probability of passing through barriers, with differing views on how these factors interact.
  • One participant suggests that the frequency of light affects its ability to pass through materials, referencing various electromagnetic waves and their interactions with walls.
  • Another participant emphasizes the importance of not making unfounded claims, urging caution in presenting speculative ideas as facts.
Participants express multiple competing views on the relationship between mass, energy, and the ability of light to penetrate walls. The discussion remains unresolved, with no consensus reached on the implications of masslessness for the behavior of photons.
Some arguments rely on assumptions about the nature of mass and energy, and the discussion includes references to specific physical phenomena that may not be universally accepted or understood.
bodhi
please tell me if a photon of light is considered massless,then it should penetrate even walls,but that does not happen,then how can you consider light as massless??
Science news on Phys.org
Though massless, photons still have energy and momentum. But why in the world do you think that being massless implies penetrating walls?
"massless" and "penetrate walls" are two properties that have NOT been shown to correlate with each other.
Unless you are able to show such correlation, then your question is moot and is based on a false premise. I'm sure you'll understand that it is impossible to try to explain something based on a false premise.
Zz.
thats because if you have no mass then nothing can block you.
also if a particle is showing characteristics it can't be zero,i don't think there is any thing in world which has characteristics and still carry no mass.
According to what? Pokemon battle rules?
bodhi said:
thats bcoz if you have no mass then nothing can block you.
You appear to be making up your own rules and physical laws.
Zz.
Zz.
well i have observed a basketball go through the net but it can't go through the hole used in golf,whereas a marble can easily go through the golf hole.obviously the dimensions matters
now why dosent this apply to light if mass is zero it musthave dimensions equal to hence even the smallest hole is big enough for it ,hence it must pass through it,but that does not happen,hence i think photon might have some mass.
please correct me if i am wrong.
If light had no mass (no energy) it would pass through objects sure. But it does have mass. You read that it can be treated as a particle with zero rest mass, this would mean that if it were at relative rest it would have no mass. As soon as it has any relative velocity it has energy and therefor is treated as a massive particle with momentum. Though most photons have such little mass (energy) that it does pass through walls.
Think of it this way, the more times it oscillates as it passes through the wall the less probability it has of making it to the other side. The energy (mass) is proportional to the rate of oscillation.
bodhi and LostConjugate, I would recommend that you both read the following FAQ entries:
http://www.desy.de/user/projects/Physics/ParticleAndNuclear/photon_mass.html
https://www.physicsforums.com/showthread.php?t=511175
Passing through objects has nothing to do with mass. It has to do with interaction. Neutrinos have more mass than photons but penetrate much deeper through ordinary matter because they interact only very weakly.
A neutrino has more total energy than a photon of say visible wavelength?
This is wrong.
Light has momentum, but no mass, as in invariant mass that we are familiar with. Do not make things up like this.
Passing through walls have nothing to do with having a mass or not. Neutrinos have mass, but they pass through the Earth with very little interaction!
Zz.
ZapperZ said:
This is wrong.
Zz.
True, invariant mass doesn't have anything to do with passing through objects.
However even though bodhi may not be saying it the proper way. He is not wrong by thinking of mass as the limitation of passing through objects. The lower your energy the higher the probability of passing through an object without disturbing it.
It certainly can depending on its speed, but regardless of the total energy it always has more mass.
This is incorrect as well.
I can show you a band-pass filter in which a lower frequency of light will NOT pass through.
You are making things up.
Zz.
He is wrong, and the statement that the lower the energy the higher the probability of passing through is not true in general. If it were true then absorption spectra would be monotonically decreasing with increasing wavelength instead of displaying peaks.
EDIT: ZZ is faster on the draw!
Zz.
Ok ok, I stand corrected. I was thinking on a more fundamental level I suppose.
A simple potential barrier and a particle. The probability of passing through is proportional to a Gaussian of the energy.
Also was thinking of EM waves. A radio wave happily passes through the walls of your house while the EM wave coming from your lamp does not, and a X-ray tears it's way through. All of this of course the expectation value of a great number of photons meeting a great number of different potentials.
Edit: so maybe I don't stand corrected?? I don't know.
If you don't know, let me give you a strong advise: don't make things up and offer them as answers. Your original response was given with such certainty as if you know these things intimately. Instead, you're guessing!
People look up to this forum because it has a higher signal-to-noise ratio than other forums. Do NOT add to the noise.
Zz.
Again, what is important is the interaction. Suppose you have a thick block of scintillator crystal, then the x-ray will be strongly absorbed, the visible light somewhat absorbed, and the radio wave not absorbed very much, but instead suppose you have a large but very thin sheet of metal (or a wire mesh) then the radio wave will be completely absorbed, the visible light somewhat absorbed, and the x-ray will not be attenuated much at all. Completely opposite behavior because the interactions are different.
Zz.
Ok was not planning on making anything up.
17K
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 207 ·
15K
  • · Replies 17 ·
