Is MIT Prof. Lewin wrong about Kirchhoff's law?
  • Context: Undergrad
  • Thread starter Thread starter sarumonkee
    Law Mit
347 replies · 84K views
hikaru1221 said:
Okay, for the original version of KVL (sum of emf = sum of ohmic drop IR), we don't even need the term voltage. I'm still thinking about how we define emf here. Emf, in the common sense, is somewhat like a "charge pump". Then how should we explain the "emf" of a capacitor?
Good question.
If we follow the modern description of Kraus, then it makes sense to view the electric field in the capacitor as a conservative field in the context of providing a potential drop, albeit a negative one sometimes. You could also call this a positive EMF without offending too many people. The math works out either way.
If we used the original definition from Maxwell, we would be forced to call this potential an EMF, since the concept of potential (which Maxwell was of course well aware of) is not mentioned in this particular definition. It is an EMF because it is a negative potential drop capable of driving the movement of charges and EMF is anything that looks like voltage and can provide energy to separate opposite charges or force like charges together.
If I hold a PP3 battery in my hand there is EMF, but no magnetic flux and therefore Faraday's Law is not applicable.
There is, of course, no circuit at this stage either.
If I now connect two identical batteries ( or carefully adjusted power supplies) in opposition in a circuit, perhaps including resistance, there is still no magnetic flux as there is no current.
Kirchoff's law can be applied to this situation as we can sum the opposing EMFs meaningfully.
@yungman: Thanks. The point I would like to point out is, the wire has little effect compared to the resistors, and this is why though we have 1 volt around the loop, this 1 volt is mostly on the resistors.
@stevenb: Okay, so original KVL is equivalent to Faraday's law. Kirchhoff was brilliant to put everything in a closed-loop form.
Is it?
What about my last post?
I look at the wire as a Voltage source induced by the magnetic field. If you consider the voltage source in the loop, KVL held.
cabraham said:
I meant time varying fields present in the circuit loop. Time varying fields on the interior of the inductor is modeled by circuit theory, w/o the need to consider fields.
That is a good way to put it (better than my number 3). If you had written this then I would not have objected.
cabraham said:
The Lewin paper explicitly stated the field inside the circuit loop, not that on the interior of an inductor. Did you read the paper by Dr. Lewin?
Yes, I read it. In the paper, despite how he drew it, he is considering the field inside an inductor. The example in the video is better on that count.
cabraham said:
As far as a cap having " no net charge", this is very semantical. "Charge" as used by the science community implies "differential". An "uncharged cap" has lots of charge, but zero difference. A "charged cap" has the same total absolute charge but is displaced forming a differential. If you define "net charge" as total charge on both plates, then of course there is no "net charge" in either case, energized or not. Whan I say "charge" in ref to a cap, I infer the differential quantity, not the absolute total which you define as "net charge".
Dr. Lewin is correct on all counts. He simply illustrated how non-conservative fields differ from conservative. You're trying to look for reasons to poke holes in his case by bringing in arbitrary arguments based on your own semantics.
It is not my own semantics, it is the standard meaning of the term "net charge". Your objection here is a little excessive.
cabraham said:
In the final analysis Dr. Lewin states the following.
1) With conservative E fields, KVL holds, & the potential from a to b is independent of the path.
2) With non-conservative E fields, KVL does not hold, & the potential from a to b is dependent on the path.
Introducing hyperbole does not alter this basic tenet. Is there any issue with the above 2 statements?
Yes, they are wrong for the same reason as above. As written they would apply to the apply to the fields within the interior of an inductor and not only to fields in the circuit loop.
Here are my 2 cents. Maxwell's equations and the Lorentz force equation are the governing equations for classical electromagnetics and they describe all classical EM behavior. However, they are a pain to work with, so we have many approximations which are valid in certain cases: Coulomb's law, Biot-Savart, KVL, KCL, etc. All of these are approximations to Maxwell's equations that only apply in certain circumstances and you need to learn when they apply and when they do not apply along with the equations themselves. Once you learn their domain of applicability they are all very useful and correct approximations.
Once you learn their domain of applicability they are all very useful ...
I agree 110% with this.
But that does not account for my example (post#32) where the only law from your list plus Faraday's law that applies is KVL.
None of the others will yield a correct, or indeed any, answer.
Faraday'a Law, FL always applies, under all conditions. KVL does not always apply. I think the disagreement is one of logic, not e/m theory. With conservative E fields, KVL always holds. What if the E field is non-conservative? The negative of always is not the same as never. With a non-con E field, KVL does not always hold. That does not mean KVL never holds.
The interior of an inductor is one case where KVL holds, but there are others. If a time varying E field is distributed in space, & I wish to compute Vab along various paths, can KVL hold? Of course. Two differing paths can enclose the same flux resulting in the same potential. Closing said loop on these paths results in zero potential around the loop, which makes KVL valid under said conditions.
If Dr. Lewin would have stated that KVL can never hold w/ time varying mag fields, I would have disagreed. He simply stated that KVL is valid conditionally, whereas FL is valid unconditionally. Scientific observation backs this claim.
Of course, if we add a generator to the loop representing the induced emf/mmf voltage/current, then KVL will hold. That is because we are accounting for induction in the circuit model. But in reality if we trace E around the loop, we get a non-zero value, which voids KVL. We can keep KVL intact only by adding a generator into the circuit model.
Dr. Lewin is among the world's most qualified instructors regarding this material. I'm a little surprised at the EEs (or non-EEs) in the industrial community who are bashing Dr. Lewin. Those who do make me wonder how much e/m field theory they've had. Nothing personal, but will the critics of Dr. Lewin please state explicitly the errors in Dr. Lewin's teachings? He's a prof at MIT, an institution world renowed. Who are these critics anyway? What are their credentials? I'm just wondering.
In his accompanying paper Dr. Lewin explains how the inductor interior fields are covered in circuit theory by v(t) = L*di(t)/dt. If you measure v(t) by integrating E*dl inside the conductor, you get a different answer. The E field is indeed non-con, leading to differing potentials across two points, depending on the integrating path.
I spent years designing inductors, xfmrs, RLC filters, SMPS, regenerative braking, motor drives, etc. I learned much about this topic beyond what I learned in e/m fields back in undergrad EE. But the undergrad EE curriculum was very good. I just needed to practice e/m, which I did.
If anyone wishes to address a specific topic, I'll do that. But bashing Dr. Lewin does not make you right. I'll discuss anything politely using science. Peace.
Claude
Sure, I agree, I have said as much at least twice in this thread. But the example Dr. Lewin presents in his notes is one where KVL holds.
Claude
How can anyone who walks around with a plastic banana in his shirt pocket be "among the world's most qualified instructors"?! :smile:
I have to say that I am also disappointed to see what appears to be some out of place bashing of Prof. Lewin. Personally, I think he is an outstanding teacher and is dedicated to not only teaching the material well, but inspiring students to appreciate the beauty of electromagnetics and physics in general. I've watched every one of his lectures in this series (more than once) and can't see any major issues with anything he teaches. He stresses concepts and provides experimental demonstrations to solidify those concepts in the students mind. The one minor issue I have is in this one lecture where he chooses a definition of KVL that I feel is not the best one, but I don't view this as a big deal because he clearly defines his meaning. If this were a more advanced class, then I would expect him to give a more comprehensive overview of KVL along the lines of Kraus, but this is a freshman level class (many of the students not even targeting EE or physics) which is likely the first high level exposure these students have to the subject. The quality of this course, for the level it targets, and the quality and dedication of the Professor, are absolutely outstanding in every way.
Unfortunately, it was not truly exceptional, merely outstanding, because he failed to wear his banana! :smile:
BTW, is there any video where he is really wearing a banana - or is that an urban legend, like KVL? :-p
So which of my comments do you consider "bashing"?
1) He teaches correct physics
2) He describes KVL as "MISLEADING" and "DEAD WRONG" (emphasis in original)
3) He justifies his assertions using a strawman definition of KVL
4) The usual definition of KVL is correct under standard circuit theory conditions
What points have I made besides these, or which of these points is "bashing"?
Personally, I don't consider any of your comments bashing. I never felt you were speaking ill of him at all. There is a difference from having a technical disagreement and crossing the line to an insult. I can't say I noticed you cross that line.
There are other comments in this thread made by someone else that I do feel cross the line, but I really don't want to point to specific people and comments, because that is a job for moderators. But, I've been planning to make a general positive comment to counter the negative ones, and cabraham's comment opened the door to that, so I step in.
Claude
As I pointed out over and over again that his assertion the KVL was not correct with his so call experiment that was fraud. No if and buts about it. When you start out wrong, there is absolutely no point of talking about all his equation and theory. I am sure his equation and the non conservative nature were correct, but all meant nothing when the reasoning on attacking KVL is fraud. You cannot just over look the fraud of his experiment and keep moving into his derivation. I am not even trying to defend KVL, it could have problem in other cases, BUT not from his fraud experiment, and to me that is everything.
I am particularly hard on him because of his arrogance on calling people wrong when he was actually the stupid one that he did not understand the first thing about electronics. This is not even hard to spot for anyone with REAL life experience designing switching power supply. Just because he was a good lecturer do not gave him the right to blast others and particular to that degree of arrogance and stupidity. You said you designed transformer, you should know exactly what I am talking about. If you jack up the frequency you get more efficiency until the point the core loss become obvious. We use around 100KHz and we got really good result. We managed to wind a transformer with about 30V to 30V 15KV isolation for the 24V to 24V DC to DC converter and we use fiber optic to serve as feedback from HV side down to ground level to close the control loop. The transformer core was only about 1.5"X1.5" size so we can only put less than 10 turns ( I don't remember exactly). We got over 100W up onto 12KV. In his case, I take that he did not have a core ( air core), saturation is not even a problem, you got the power to pump in the create the magnetic field, you can really crank out some voltage. I am not a transformer expert, my engineer was and we talked a lot about this.
I know most of you don’t want to engage me on this because I kept talking about the experiment instead of all the theory that you are interested. Unless you can prove me wrong, this whole talk are all based on some fraud observation. I can assure you that I can produce more than 1V with just one turn as I said over and over again in the DC to DC converters we designed. He just miss the whole transformer effect on his experiment.
Hey Hikaru, I think the wire is important as if we look at the impedance of an inductor (which totally exists, (at least Yungman and I know exists), we have s*L. The s is proportional to frequency, and a step function (switch turning on), has some high frequency components in it. This means the inductance of the line could act like a pretty big impedance at higher frequencies.
I want Prof. Lewin to show two more volt meters, one going from both probes of the first two meters on the "D" "node" and another between the "A" "node" points. I put "node" in quotes because I believe his circuit model is flawed, as Yungman has stated (missing inductance).
How much voltage you measure across an inductor depends upon how you route the probe wires. Does this help confuse things? :devil:
Well, it doesn't actually apply in this situation, I think. Maybe specify a little more if I missed you point please. The voltmeter (an O-scope in this case) has a huge resistance, probably in the range of 10MΩ), so the current in the voltmeter probe wires will be small. This means the volt meter probe wires hopefully won't pick up too much EMI compared to his circuit of wire and resistors.
Hi, I didn't manage to see trough all the posts written here, I appology for that. Just wanted to offer intuitive explanation. Walter H. G. Lewin have been explaining the experiments through calculations and he admitted it is not intuitive at all. But I think one can expain it, assuming there is additional loop of wire in series with one voltmeter/oscilloscope.
http://img573.imageshack.us/i/fvsk.png/
I think third diagram is equivalent of the first one, but not the last one.
If you've hooked up both oscilloscopes on one side of the circuit you would have identical readings.
I think, DaleSpam has lent clarity to all this, and he would be worth re-reading. Apply Faraday's law with Maxwell's correction and you should have a classically indisputable form of Kirchhoff's voltage law.
Now, I don't know what situation you are referring to. There are a lot of posts!
Take an inductor with a small number of turns like one turn around a high permeability material, to make things evident. How many rounds your meter probes make through the core determines the voltage measured.
Phrak said:
I think, DaleSpam has lent clarity to all this, and he would be worth re-reading. Apply Faraday's law with Maxwell's correction and you should have a classically indisputable form of Kirchhoff's laws.
Are you referring to a current measurement? The point of Prof. Lewin's experiment was not about voltmeter measuring errors, it was to supposedly show measuring across different points of two "nodes" can give you different voltages. I don't think they were actually "nodes" as inductance was not included.
So you want to know if the voltmeters were connected at exactly the same two points?
@atyy: Yes, that's what I want to know. He didn't really go into detail about his setup, and from the look of the video, the probes were separated by about 4" on both sides of the circuit of wire and resistors. From my experience, that kind of layout can lead to some inductances that matter in switching situations.
If the probes were actually touching each other, I rescind all my previous comments, and will probably go read an E&M book from cover to cover.
I hope that is not the point of his confusion because it's clear that the scopes are effectively tied to the same point, and such a small inductance is irrelevant on these time scales. You can take the same voltmeter or scope, pick it up, move it to the other side and the reading will change. You could swap the meters and their reading would also swap.
If the OP is in doubt of this, then he needs to do his own experiments and re-study Faraday's Law. This is all straightforward stuff. The meter probes themselves form an additional loop that is closed through the meter's internal resistance. The fact that the resistance is very high and the current in the probe wires is low has no affect on Faraday's Law. When the meter is moved, the loops change their encirclements of the internal flux change.
This is exactly the thing that makes the experiment non-intuitive to the uneducated and the educated alike.
OK, this is the issue then. Definitely restudy Faraday's Law, but more importantly do your own experiments. You need to see it to believe it. These experiments are really fun actually. You don't really need to do his exact experiment to get a feel for Faraday's law. You can wire up a large coil and drive it with triangle waves of current. Then make loops and take measurements.
The funny thing is that you can do these experiments and show them to your friends, and many will still think it's a trick of some type.
@sarumonkee: I see. Lewin's experiment was just for a lecture, not to convince a skeptic, so yes, his experiment was not done totally properly. However, if his errors were significant, his results should be different from what his calculations predict using Faraday's law in the big loop as the major effect (he predicts that the ratio of the voltmeter readings should be related to the ratio of the resistances). I haven't watched enough to know whether he got what he predicted.
Anyway, I agree with stevenb - go and do the experiment yourself - unless some kind soul or Lewin himself would be so kind as to redo it and post it here.
I'm not arguing with you about KVL. It's about what you are trying to say, that his experiment & his explanation are all a fraud. Would you kindly show me quantitatively that the transformer effect has that gravity to refute Prof. Lewin's explanation?
Sorry, I didn't see your post when I posted.
When Faraday deduced his empirical law, he did experiments with closed loops. The Faraday's law we have referred to so far is also in his integral form. This is why we cannot apply Faraday's law for an open circuit, because the law only applies to closed circuit. But KVL is also not applicable.
Now for your example of 2 oppositely-connected batteries, both Faraday's law and KVL apply:
_ KVL: [tex]- e + e + e_{B}= IR[/tex] where [tex]e_B[/tex] is the emf due to the magnetic flux change, which is zero.
_ Faraday's law: [tex]- e + e + IR = \oint Edl = -d\phi/dt = 0[/tex]
This is why I asked for a qualitative explanation. Inductance exists everywhere. It's just that whether it's significant enough.
There is always a way, without thinking deeply, one can run a second set of wire closely tie to the original wire loop and serve as the loop to pickup what ever voltage generated by the magnetic field and do a common cancellation. Yes it would involve some thinking, but it is absolutely doable. I am less interested in making the experiment than to challenge the experiment. Point is there is a way to cancel the magnetic effect on the probe that hook onto the two end of the wire and I am sure it is not hard, nothing more than breadboard a differential amp or play with the meter connections.
If you have the two probs of the meter connect one onto one end of the wire loop, you form a secondary loop which is from say probe E to one end of the wire, then to probe F which connect to the meter and back to probe E through whatever internal resistance of the meter. That can pickup the magnetic field from the setup. It become a one turn transformer also!
As I say, using the technique of common mode cancellation would be an easy to solve this problem.
Another simpler way that might or might not be good enough, use a twist pair to connect the meter. One side of the twisted pair solder to one end of the wire loop in the setup, the other wire twist onto the wire from where the first twisted wire solder on, follow the wire of the setup to the other end before soldering on the the wire loop. What I am doing is to minimumize the loop area of the probe. The smaller the loop area, the less magnetic flux pass through, the error might be small enough to be acceptable. But the common mode cancellation is the way to go if you want accurate measurement.
