Do I Need a Buffer for My ADC When Sharing a Bus with NAND Flash?
  • Thread starter Thread starter quantum8000
    Buffer
Using a buffer between a bus and an ADC is recommended to minimize noise feed-through and potentially enhance ADC accuracy by reducing power dissipation. In projects where an ADC shares a 16-bit bus with NAND flash, a buffer is crucial to match impedance and prevent damage from signal mismatches. There are two main types of buffers: current and voltage, both of which are important for isolating noise. Additionally, maintaining separate ground planes for analog and digital circuits is essential to further reduce noise coupling. Consulting the manufacturer's PCB layout recommendations is vital for ensuring optimal performance and acceptable noise levels for the ADC.
quantum8000
somebody says put a buffer between a bus and an ADC .even if the ADC has an internal buffer. it iminimises the noise feed through,and may improve ADC accuracy by lowering power dissipation.
in the project i am working on,the ADC must share 16bit BUS with a nand flash.the bufer is necessary? and what is the meaning of the buffer?
Buffers are primarily used to match inpedance whether from voltage, current or RF.
http://en.m.wikipedia.org/wiki/Buffer_amplifier
an impedance mismatch in the case of signals and RF can cause damage to sensitive circuitry such as ADC's. A mismatch in RF for example creates reflective waves and inducing reflective voltages.
There are two main types of buffers. Current or voltage.
Mordred has answered the question for the analogue side. But the digital side can also be important.
A digital buffer can help isolate digital bus noise from the ADC chip. However, there should be separate ground planes for the analogue and digital sides of the chip. The ADC chip should have some form of differential analogue input that will minimise digital noise coupling into the analogue and reference inputs.
The manufacturer will provide a recommended PCB layout for operation, and will specify conditions for measurement of conversion noise. You will need to consult those details before you can decide on an acceptable noise environment for the ADC chip in your application.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
