Is Partition Theory Concerned with Multiples of a Number?
  • Thread starter Thread starter MathematicalPhysicist
    Partition Theory
Partition theory primarily focuses on the ways to express a number as a sum of positive integers, rather than on the multiples of a number. The discussion highlights that while partitioning involves counting distinct sums, factorization pertains to how numbers can be expressed as products of their factors. The participants clarify that the partition of a number, such as 4, is determined by the different combinations of integers that sum to it, totaling five distinct partitions. Additionally, they mention formulas related to partition functions, including contributions from notable mathematicians like Hardy and Ramanujan. Ultimately, the consensus is that partition theory does not directly address multiples of a number.
does p.t concern also with the multiples of a number, for example: the multiples of 4 are 2*2 and 4*1 meaning two?
p.s
i know that partition theory is concerned in the sums of a number (the partition of 4 is 5).
Mathematics news on Phys.org
p.s
Loop, could you simply just refresh our memories about ordinary ADDITION partition theory?
Like, how do you figure out how many ways there are to write the number seven as a sum?
You are jumping ahead too fast. I cannot even remember the addition part.
I think that you would call the multiplication analog of that a theory of "factorization"
like how many ways can you factorize the number 24?
and I think that the main results having to do with factorization are theorems about prime numbers and prime factorization.
It would be a separate thing from the additive business you call "partitioning".
Partitioning is interesting in its own right. Even if you allow zero as a number and even if you count 2+3 and 3+2 as two separate partitions of 5. That is, you take account of the the order. I assume you know the "binomial coefficient" written as two numbers N and k in parens
and pronounced "N choose k"
/N\
\k/
and calculated N!/(k!(N-k)!)
You say "the partition of 4 is 5". How do you calculate that?
I don't happen to know a formula. Am not altogether sure what is meant either
4, 1+3, 2+2, 1+1+2, 1+1+1+1
well that is 5 all right
1 partition into one piece
2 partition into 2 pieces
1 partition into 3 pieces
1 partition into 4 pieces
adds up to 5 in all
you happen to know a formula?
partition theory doesn't account for order and you are right about the partition of four.
there are two formulas (or at least that's what i understand from this webpage: http://www.google.co.il/search?q=cache:yyMgmLqywAgJ:www.iwu.edu/~mdancs/teaching/m389/lecture_notes/Lecture_03_24.pdf+formula+in+partition+theory&hl=iw&ie=UTF-8 ):
1. an explicit formula given by hardy and ramanujan (which is given in the webpage above).
2. the second one is: p(n){the number of partitions}=p(n-1)+p(n-2)-p(n-5)-p(n-7)+p(n-12)+p(n-15)-p(n-22)-p(n-26)+...
that's all for now...
Thanks, it is an interesting topic
I went to the webpage you suggested----lecture notes
by Michael Dancs for a number theory course
http://www.iwu.edu/~mdancs/teaching/m389/
and also tried a google search myself [formula partition function]
coming up with Eric Weisstein's MathWorld
Great people like Euler and Ramanujan have worked on the
partition function---most facts about it seem hard. But one source mentioned an easy fact. Did you see this?
"The number of partitions of N into exactly m parts is the same
as the number of partitions of N into parts with maximum size m."
There are 2 partitions of 5 into 2 parts, namely (4+1, 3+2)
and also 2 partitions of 5 with maximum=2, namely (2+2+1, 2+1+1+1)
There are 4 partitions of 7 into 3 parts, namely (5+1+1, 4+2+1, 4+1+1+1, 3+3+1)
and also 4 partitions of 7 with max=3, namely (3+3+1, 3+2+2, 3+2+1+1, 3+1+1+1+1)
I calculated the first 10 partition numbers to see if I could detect a pattern, but I could not see one:
P1 = 1
P2 = 2
P3 = 3
P4 = 5
P5 = 7
P6 = 11
P7 = 15
P8 = 22
P9 = 30
P10 = 42
there's a "semi-pattern" from p(2) to p(6) the partitions are prime numbers.
so marcus, you didnt answer my original question:"does p.t concern also with the multiples of a number"? do you know?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
