Is quantum field theory really lorentz invariant?
32 replies · 12K views
Sam_Goldberg
Hi guys,
Before responding to my post, please note that I am only familiar with the mathematics of nonrelativistic quantum mechanics, and don't know any quantum field theory. All I have is this vague idea that quantum field theory is the union of special relativity and quantum mechanics, where the number of particles is not definite and both electrons and photons are described as excitations of a quantum field. The dynamics of the electrons and photons are, apparently, lorentz invariant.
Anyway, my question is this: there seem to be certain elements in nonrelativistic quantum mechanics that I can't see how to make lorentz invariant. No matter what interpretation one uses, it seems as if we have an irreparable violation of lorentz invariance. Take the Copenhagen interpretation, with its wavefunction collapse. The process of wavefunction collapse blatantly violates lorentz invariance, and I do not see how one could suitably modify it in such a way that it becomes lorentz invariant. Have they have figured out how to extended wavefunction collapse to quantum field theory such that it is lorentz invariant?
Even if one uses an interpreation without wavefunction collapse I don't see how one could still have lorentz invariance due to the nonlocality of quantum mechanics (EPR experiment). For example, in Bohmian mechanics, a many particle system is guided by the wavefunction. Since the wavefunction lives in configuration space, the guiding equation for the particles is nonlocal and in violation of lorentz invariance.
I am only familiar with the Copenhagen and Bohm interpretations, and I don't see how either can be extended to obtain lorentz invariance. Maybe quantum field theory does this, and I am simply not aware of it. Or it might be that there is an interpretation of quantum mechanics that is readily extendable to ensure lorentz invariance. To be honest, I am doubtful that a different interpretation of quantum mechanics will really make a difference. I have only heard of the many worlds interpretation and have not studied it in detail, but it seems that the branching of a universe into many other universes is also in violation of lorentz invariance (just like wavefunction collapse), and it does not seem easy to fix it. So I'm really stuck.
Or perhaps quantum field theory isn't lorentz invariant?
Despite nonlocality, there is a way to make Bohmian interpretation Lorentz invariant, even without quantum field theory. For a non-technical explanation of how is that possible, see
http://xxx.lanl.gov/abs/1002.3226 [to appear in Int. J. Quant. Inf.]
For a generalization to quantum field theory see also
http://xxx.lanl.gov/abs/1007.4946
Measurement is inherently not covariant, because you need an observer, who then defines preferred time-slicing of spacetime. However, everything else is just fine --- the dynamics, etc. can be generated in such a way as to leave the measurement process as the only non-relativistic element in the theory.
In quantum electrodynamics, the measurable quantites are field averages over spacetime regions, rather than fields at spacetime points. So the assumption of temporal ordering of measurements in non-relativistic quantum mechanics can no longer be upheld, since such an orering is possible only when the time intervals of the corresponding regions do not overlap. Thus, there are new features of complementarity of description involved.
genneth said:
Measurement is inherently not covariant, because you need an observer ...
I would refrain from using the term "observer". It is philosophically misleading. Observer is not needed. Measuring and registering the results apparatus is needed. We can measure the temperature on the other side of the Moon even if no one is there.
Sam_Goldberg said:
Anyway, my question is this: there seem to be certain elements in nonrelativistic quantum mechanics that I can't see how to make lorentz invariant. No matter what interpretation one uses, it seems as if we have an irreparable violation of lorentz invariance. Take the Copenhagen interpretation, with its wavefunction collapse. The process of wavefunction collapse blatantly violates lorentz invariance, ...
It seems that way to most. The Multi World Theory (MWT) proponents think they should get around this by replacing objective wavefuction collapse with subjective wave function collapse.
However, I am very sure that MWT is not required, and that the seeming nonlocality of quantum mechanics is false, as Einstein and Schrödinger would have it dispite J. S. Bell's ingenious argument.
Can you define Einstein locality?
The process of wavefunction collapse blatantly violates lorentz invariance​
Are you sure?
http://arxiv.org/abs/quant-ph/9906034"
Authors: Asher Peres
(Submitted on 10 Jun 1999 (v1), last revised 7 Feb 2000 (this version, v2))
Abstract: If several interventions performed on a quantum system are localized in mutually space-like regions, they will be recorded as a sequence of ``quantum jumps'' in one Lorentz frame, and as a different sequence of jumps in another Lorentz frame. Conditions are specified that must be obeyed by the various operators involved in the calculations so that these two different sequences lead to the same observable results. These conditions are similar to the equal-time commutation relations in quantum field theory. They are sufficient to prevent superluminal signaling. (The derivation of these results does not require most of the contents of the preceding article. What is needed is briefly summarized here, so that the present article is essentially self-contained.)​
Do you see the deductive dissonance you've introduced in your argument? "Observer is not needed" is followed by a statement about "We" as observers--we who measure.
The distinction to be made is not between measuring devices and observes, but coherent and decoherent systems.
There is also a critique of this paper:
http://xxx.lanl.gov/abs/quant-ph/0109120 [Phys.Rev. A64 (2001) 066101]​
arkajad said:
It is a very weak critique. The author is not even quoting all relevant papers, probably because he is not aware of them.
In a short comment on a specific paper, it is not appropriate to cite all indirectly relevant papers. Do you have a concrete objection on the arguments used in the Comment?
Yes, I do. He talks about "wave functions":
"In his approach (as well as in the approaches of many others), the wave function, described by quantum mechanics, is not a material object, but only a mathematical tool for calculating probabilities. and then uses density matrices."
Wave functions evaporated. No distinction is made between individual systems and statistical ensembles. The critique should be addressed differently.
Moreover, I wonder how the referee of this paper could let the main argument be published:
"Therefore, it would be a miracle if the unique nonrelativistic definitions of KA and LA would give the relativistic equation (7). It is not shown in [2] that this miracle happens. We have shown explicitly that this miracle certainly does not happen for N = 1."
Simply stated: "I can't show that this paper is wrong, but I strongly believe it must be wrong".
The way I see it, "wavefunction collapse" is only needed if you make two unjustified assumptions on top of QM: a) that the wavefunction describes (i.e. represents the properties of) a physical system, and b) that there's only one world. If you don't make both of those assumptions (which are not part of QM by the way), you don't need to make a third assumption to try to solve the problems caused by the first two. (I also strongly doubt that the collapse axiom actually solves those problems, but that's another story).
The alternative to a) is to assume that the wavefunction represents the statistical properties of an ensemble of identically prepared systems (the ensemble interpretation/statistical interpretation) or to not make any assumptions at all (the "shut up and calculate" interpretation).
My point is that the collapse axiom has much bigger problems than Lorentz invariance, but I also think that it either makes both non-relativistic and special relativistic QM inconsistent, or neither. The "instantaneousness" of it all isn't a problem since it can't be used to send FTL messages.
No, simply stated it means the following: "I can't show that this paper is wrong, but the author (Peres) of the criticized paper also cannot show that his paper is right."
I think this is a sufficient reason for criticism of the Peres paper.
Also, there is a reply by Peres himself (not on the arXiv, but published in PRA), and his response to the criticism of his paper does not share your views at all.
So, if he can't prove that the paper is wrong, why to write a paper at all? As a joke? As a proof that the referees are asleep? Well, he succeeded.
As for Peres he does not have to share my views the same way I do not have to share his.
Wait. Measurable quantities are the only quantities which must be covariant. We don't necessarily require purely theoretical quantities to obey relativity or anything else (e.g., conservation laws) as long as the predicted observable quantities do since theoretical quantities may only be artificial and not correspond to anything in reality at all.
You always have to choose a particular reference frame to compare with experiment/observation, whether classical or quantum. But your measured quantity better transform to other frames as some representation of the Lorentz group.
Measurable quantities are covariant, but what may NOT be covariant is a PHYSICAL PROCESS (like wave-function collapse) that gives measurable quantities definite values.
Of course, if there is no such process (no-reality interpretations of QM), then there is nothing to be non-covariant.
To point out some weaknesses of the Peres paper, to motivate him (Peres) to better develop his theory in a next paper?
That is a good subject for a private email but not for a paper in a peer-reviewed journal with a high impact status. Nicolic did not do his homework and reports his failure. The referees did not do their job.
Hi Demystifier,
I read your suggested article on Bohmian relativistic QM and I'm still not convinced. Nicolic defines a parameter s for the world lines of all the particles in the system, but the question of how to make the parametrization seems ambiguous. It is clear that different parametrizations produce different results. Even if we say ds = d(proper time) for each particle, it is still unclear at which point in a given particle's world line we say s = 0. And which point we select matters.
Next, for everybody, I have a question on the Copenhagen interpretation's dealing of the EPR experiment. I would like to recall Einstein's actual quote: "If, without in any way disturbing the system, we can predict with certainty (i.e. with probability equal to unity) the value of a physical quantity, then there exists an element of physical reality corresponding to this physical quantity."
If I understand this, it would mean that when we make a measurement and go from a superposition of spin-correlated states |u,D> + |d,U> to a single one, that is, either |u,D> or |d,U>, then even though our measuring device is near the lowercase particle, since we know the value of the upercase particle's spin with certainty, it's a variable with physical reality. But this would mean that the physically real quantities are not lorentz invariant!
One could refute this argument by saying that we did not directly measure the uppercase particle's spin and that therefore it never gained any physical reality. This would be saying that Einstein's criterion of reality is wrong. Then the physically real quantities are lorentz invariant. So the lesson is that only what we directly measure gains physical reality, and further, that the physically real quantities must be covariant.
I feel, however, that there is a problem with the idea that only what we "directly" measure gains physical reality. In the Copenhagen interpretation, we make a cut between our quantum system and our classical measuring apparatus, and where we place the cut is, according to Bohr, arbitrary. Let's say we are measuring the position of an electron. If we say that only the electron is part of the quantum system, then after the measurement, the electron position is a physical reality, since we directly measured it. However, let's say we include a pointer (that correlates with the electron position) in the quantum system as well. Then in the new system-apparatus framework, the electron and the pointer are entangled, and we "directly" measure not the electron, but the pointer. It is clear that the pointer gains a position, and this is a physical quantity. However, this situation is very similar to EPR, and with similar reasoning, one would have to say that the electron did not gain a position. One would have to say that only when we "directly" measure the electron it gains an element of physical reality.
So this is really problematic. If we assume that the particle we don't directly measure gains an element of physical reality (as Einstein says), then we must say that physical quantities are not lorentz invariant. But if we assume that the particle we don't directly measure does not gain an element of physical reality, then we have the problem mentioned in the previous paragraph: by placing the cut between system and apparatus differently, our electrons will never gain definite positions, spins, etc.
There is no ambiguity, in the sense that the trajectory in spacetime does not depend on s at all. See e.g. Eq. (30) in
http://xxx.lanl.gov/abs/quant-ph/0512065
We do not have a freedom to say that. It can be shown that s is NOT the proper time, but rather a generalized proper time. See the appendix in
http://xxx.lanl.gov/abs/1006.1986
That is true, but this property is a virtue, not a drawback. When we are ignorant about the exact spacetime position at s=0, all we can say is that the probability of a given spacetime point at s=0 is given by |psi|^2. In this way deterministic Bohmian mechanics reproduces probabilities from the "standard" purely probabilistic interpretation.
Well, if you insist, there is always one additional reason to publish a paper in a peer-reviewed journal with a high impact status: It is the PUBLISH OR PERISH principle. :biggrin:
And this principle is not invented by those who obey it.
I know the principle. I used to be guilty of this myself. It is partly because of this principle that we are really reading less and less papers. Comparing the quality of so called scientific publications 100 years ago and now - the emerging picture is not very encouraging. But that's another subject. Good thing is that now I have Nicolic's "Superluminal velocities" paper on my desk and it looks like it's going to be an interesting read.
With that I agree! :approve:
Is this really true? I have read in the Bohm and Hiley book why the probability density approaches |psi|^2 in nonrelativistic quantum mechanics, and it is due to the chaotic dynamics in most physical situations. I would really like to see a proof the statement you just made for relativistic quantum mechanics, or at least some intuitive hand-waving that will help me understand.
Furthermore, if the probability of a given spacetime point at s=0 is |psi|^2, then what is the probability of a given spacetime point at s=1 or s=2? I seriously doubt that it is also given by |psi|^2. But then we have a problem, since the time evolution of psi is given by the Klein-Gordon or Dirac equation, which don't have s anywhere. Then, wouldn't the probability for every value of s be |psi|^2?
This is one possible explanation, but not the only one.
But it is.
Exactly!
Sam_Goldberg said:
Hi guys,
Before responding to my post, please note that I am only familiar with the mathematics of nonrelativistic quantum mechanics, and don't know any quantum field theory. All I have is this vague idea that quantum field theory is the union ?
The question to what it comes down to: can measurements between two space-like separated points causally affect each other? In QM that is very well possible, in QFT it is not, which makes the theory lorentz invariant. Read chapter two in the standard QFT text of Peskin and Schroeder, where it is very well explained (you can skip the math if you like, they explain it also nice in words).
That the collapse is instaneously if you mak one measurement (which is the case in both QM and QFT!), is not relevant for the theory to be relativistic or not. But is faster than light communication between two events/ measurement possible or not, that matters!
kexue said:
which makes the theory [QFT] lorentz invariant
and, one should add, as Feynman has noticed, for non-trivial interactions, mathematically inconsistent.
Professor Nikolic, I have just one more question. In your papers you emphasize that the relativistic wavefunction is a function on the 4n dimensional configuration space. However, in nonrelativistic mechanics, it appears as if the wavefunction lives in 3n dimensional configuration space and evolves in time according to the Schrödinger equation. Specifically, at low energies it appears as if the wavefunction on 4n dimensional configuration space has a nonzero value only when the time coordinates for all the particles are equal, and I'm still not clear how that mathematically arises. I still don't have a clear picture how the relativistic case reduces at low energies to nonrelativistic Bohmian mechanics.
Thanks for helping me out.
That is a good question. The answer is that even nonrelativistic QM can be formulated in the 4n-dimensional configuration space. I have explained that in some of my papers, but this result is in fact much older than I am. For an old reference see
S. Tomonaga, Prog. Theor. Phys. 1, 27 (1946).
The usual single-time nonrelativistic QM is just a special (coincident) case of the more general many-time nonrelativistic QM.
For example, if you want to calculate the expectation values of products of observables measured at DIFFERENT times, the many-time formulation of nonrelativistic QM is a very convenient way to do this.
By the way, thanks for not writing my name as "Nicolic", which for some reason many people do. :-)
