Is the Auto-Ionization of Water Exothermic or Endothermic?
  • Thread starter Thread starter STEMucator
    Water
The auto-ionization of water, represented by the equilibrium reaction H2O(L) + H2O(L) ↔ H3O+(aq) + OH-(aq), is an endothermic reaction. The equilibrium constant, Kw, increases with temperature, indicating that higher temperatures favor the formation of products. As temperature decreases, Kw decreases, leading to a shift in equilibrium towards the reactants, confirming that the forward reaction absorbs heat. Thus, the auto-ionization of water is definitively an endothermic process.
  • Understanding of chemical equilibrium and Le Chatelier's principle
  • Familiarity with the concept of Kw in aqueous solutions
  • Knowledge of acid-base chemistry, specifically hydronium and hydroxide ions
  • Basic thermodynamics related to exothermic and endothermic reactions
  • Study the implications of Le Chatelier's principle on chemical equilibria
  • Research the thermodynamic properties of water at varying temperatures
  • Explore the role of temperature in acid-base equilibria
  • Examine the effects of pressure and concentration changes on Kw
Chemistry students, educators, and researchers interested in thermodynamics and chemical equilibria, particularly those focusing on aqueous solutions and acid-base reactions.
STEMucator
Homework Helper
##K_w## and auto-ionization of water
The ##K_w## value decreases as the temperature decreases. Is the auto-ionization of water an exothermic or endothermic reaction in the forward direction?
Water is able to auto-ionize into ##H_3O^{+1}## and ##OH^{-1}## in an equilibrium reaction:
##H_2O_{(L)} + H_2O_{(L)} \leftrightharpoons H_3O^{+1}_{(aq)} + OH^{-1}_{(aq)}##
The equilibrium constant for this reaction is defined as ##K_w = [H_3O^{+1}][OH^{-1}]##. It is known that the ##K_w## value increases as the temperature increases and decreases as the temperature decreases.
If ##K_w## is decreasing because temperature is decreasing, it means that the concentration of products is decreasing and so the reaction must move forward to produce more products and restore equilibrium. This means that heat must be a by-product of the reaction and therefore the overall reaction must be exothermic so that the equilibrium will shift right as the temperature decreases.
Is this reasonable?
The autoionization of water is an endothermic reaction.
If we increases the temperature Kw increases and the equilibrium shifts towards the products. Because an increase in temperature favors the endothermic side (the products, in this case) we can conclude that the forward reaction is endothermic and not exothermic.
But it doesn't shift right.
Think in terms of LeChatelier's principle.
Ah so I should think of it the other way around.
If ##K_w## is decreasing because temperature is decreasing, it means that the concentration of products is decreasing BECAUSE the reaction is shifting to the left to compensate for the heat loss. While this shift occurs, it is clear that products become reactants.
Since we added heat and the equilibrium shifted left, we can conclude the overall reaction is endothermic.
Thanks guys :)
