Is the Biot-Savart Law reversible?
- Context: Graduate
- Thread starter Subhra
- Start date
The discussion centers around the reversibility of the Biot-Savart Law, particularly whether the presence of a magnetic field can imply the motion of a charged particle. Participants explore the implications of equations related to the Biot-Savart Law and the Lorentz force, examining both theoretical and physical aspects of the relationships between electric charges and magnetic fields.
- Debate/contested
- Conceptual clarification
- Technical explanation
- Some participants question the validity of equation (2) in the context of the Biot-Savart Law, suggesting that while the magnitude may be correct, it may not hold true quantitatively.
- There is a discussion about whether the statement "if there be a magnetic field, there be a motion of a charge" can be inferred from the Biot-Savart Law.
- Participants express uncertainty about the meaning of the radius vector in the context of inversion and the implications of a many-to-one relationship in the magnetic field.
- Some argue that a charged particle at rest will not experience a force from a static magnetic field, while others clarify that motion is required for a force to act according to the Lorentz force law.
- There is a debate about the applicability of the Biot-Savart Law in dynamic situations, with some asserting it is only valid under magnetostatic conditions.
- Participants discuss the challenges of establishing a unique solution for the velocity of a charged particle when considering the cross product in the context of the Biot-Savart Law.
- Some participants propose that the causality relationship between magnetic fields and charged particle motion remains unresolved, emphasizing the need for further exploration of this relationship.
Participants do not reach a consensus on the reversibility of the Biot-Savart Law or the implications of magnetic fields on charged particle motion. Multiple competing views and uncertainties remain throughout the discussion.
Limitations include the dependence on specific conditions such as magnetostatic situations and the assumptions made regarding the motion of charges and the nature of magnetic fields. The discussion highlights the complexity of the relationships involved without resolving the mathematical or conceptual challenges presented.
- 1,910
- 216
Hint: start by verifying that the magnitude is correct/incorrect.
- 24
- 0
If B=B(v), can it be infered that v=v(B)?
To put it in another way,
If eqn(1) implies that "if there be a charge in motion there be a magnetic field", can it also infer that "if there be a magnetic field, there be a motion of a charge"?
- 1,910
- 216
When the "inversion" takes place it is not so clear what the meaning of r is; there are many points in the field B, but only one velocity for the charge q at anyone of them.
That is, it seems to require a many-to-one inversion. So I am not at all clear on what it is supposed to mean.
Perhaps more context for the problem would clarify this.
- 24
- 0
My question is very simply: If a moving charged particle can create a magnetic field, can a charged particle move in a magnetic field?
- 1,910
- 216
Subhra said:My question is very simply: If a moving charged particle can create a magnetic field, can a charged particle move in a magnetic field?
Sure ... the field created by the particle is independent of the field that it is moving in; that is, it doesn't "feel" the field which it creates.
- 24
- 0
- 1,910
- 216
Subhra said:I am sorry, I didn't understand you. Consider a charged particle at rest. Now place a bar magnet close to it. What will be the equation of motion of the particle due to the applied magnetic field?
The Lorentz force law: F = qv x B.
There is no force if the charges are stationary, and if the magnetic field is static. But when you move the magnet, their is a relative velocity, so there will be a force.
- 24
- 0
- 36,903
- 15,882
The Lorentz force law and Maxwell's equations are the general (classical) laws. When Biot Savart disagrees with them (and it does sometimes) then Biot Savart is wrong.
- 24
- 0
- 4,048
- 372
- 24
- 0
- 4,048
- 372
How did you "invert" the Biot-Savart law?
- 24
- 0
I don't find any way to "invert" the Biot-Savart Law MATHEMATICALLY and that's why I didn't defend equation (2). I am just trying to find the causality relationship between the magnetic field and the motion of a charged particle. In this regard, Biot-Savart law tells us that if a charge particle moves, it will create a magnetic field and I wish to know whether the reverse is true or not i.e. can a magnetic field move a charged particle or not.
- 126
- 0
Subhra said:I didn't even tried to understand the meaning of r. This probably implies that if there be a magnetic field at a point P1 and the charge at P2 such that P2-P1=r, the velocity of the charged particle will be v due to the field at P1.
That's right. There are always two charges. To solve for more than two, force is calculated between each pair. To calculate force on P1 use B field of P2. Then "reverse", that is calculate force on P2 by using B field of P1.
P1 moves in B field of P2, and P2 moves in B field of P1.
- 126
- 0
Subhra said:Due to the cross product, there might not be any unique solution for the velocity of the charged particle. Yes, I agree to it. If this is so, there should be at least one non-zero value of the velocity.
There is always unique solution. If B field of P2 is zero (zero velocity), then P1 will simply not experience any force/acceleration relative to P2, but P2 will experience force relative to P1 if B filed of P1 is greater than zero (non-zero velocity).
Calculate Lorenz force for P1 by using Biot-Savart law for P2. Then "reverse" and calculate Lorenz force for P2 by using Biot-Savart for P1.
- 24
- 0
- 126
- 0
Subhra said:The point is misunderstood here. Let's have a magnet at point A. Now put a charge at point B near A. Now come to the question: Will the charge move?
Lorenz force of that charge is proportional to its velocity, so the charge will experience acceleration only if its velocity is greater than zero. But note the charge will experience the same B field regardless of its own velocity and only relative to distance. Direction of acceleration will depend on cross product between B field of the magnet and velocity vector of the charge.
- 24
- 0
- 24,488
- 15,060
A moving charge does not provide a stationary current, and thus you have to use the retarded potentials or Jefimenko's equations for the fields (which are also retarded solutions).
For the special case of a charge moving with constant velocity, you can use a Lorentz boost to the restframe of the particle, solve the then electrostatic problem there and boost back to the original frame to get the electromagnetic field of a uniformly moving point charge.
- 1,330
- 75
Subhra said:If you consider Lorentz force Law, no force will act. Is it so if you consider Biot-Savart Law or in this case equation (2)?
UltrafastPED answered your question in post #8. Due to the Lorentz force law for magnetic field
\mathbf F = \mathbf v\times \mathbf B,
no matter what the form of the magnetic field ##\mathbf B## is, the magnetic force on stationary charged particle is zero. The particle will begin to move only if there is electric field or another force. Only those can accelerate stationary particle.
- 126
- 0
Subhra said:So, according to you a charge at rest will remain at rest even if there be a magnetic field?
According to Lorenz force.
http://en.wikipedia.org/wiki/Lorentz_force
Because there must be two charges the equation should go like this really:
1. Force on P1: F(p1) = q(p1)[E(p1) + v(p1) X B(p2)] "normal"
2. Force on P2: F(p2) = q(p2)[E(p2) + v(p2) X B(p1)] "reverse"
B field in Lorenz force equation is always of the other charge and proportional to that other charge velocity.
- 24
- 0
According to Biot-Savart Law if there be a charge in motion, it will create a magnetic field. (Look into Heaviside's electrodynamics to confirm the existence of this law for point charges). If the motion be uniform, the magnetic field will be static, else dynamic. The nature of the magnetic field is not important here.
Now, if a charge particle be placed in a magnetic field, will it move? To put it in another way, is the velocity of the charged particle dependent on the applied magnetic field?
- 126
- 0
Subhra said:Please find the attachment and comment about equation (2).
DOCX: "This will mean that if a charged particle be in magnetic field, it will be in motion."
That is not correct. It should say magnetic field of a charge is proportional to its velocity. Biot-Svart law is not about a charge being in magnetic field, it's about it creating its own B field, it does not experience it itself. Lorenz force equation is about charge experiencing magnetic field of another charge.
- 4,048
- 372
Subhra said:The question is very simple. I repeat:
This question has been answered many times already. A static charge in a static magnetic field will not move.
- 1,330
- 75
Only if the uniform motion refers to motion of constant electric current in a circuit. If you mean uniform motion of one charged particle, its magnetic field will not be static. It will move along with the particle.Subhra said:If the motion be uniform, the magnetic field will be static, else dynamic.
No, No. If the particle is put at rest into the applied magnetic field of other sources, it will not move, because the magnetic force vanishes.
- 24
- 0
So, Biot-Savart law is about creating its own B field due to its motion. This means MOVING CHARGE ->B. I just want to check:
B->MOVING CHARGE
- 24
- 0
Matterwave said:This question has been answered many times already. A static charge in a static magnetic field will not move.
Then tell me whether the magnetic field in Biot-Savart law is "static".
- 24
- 0
Jano L. said:Only if the uniform motion refers to motion of constant electric current in a circuit. If you mean uniform motion of one charged particle, its magnetic field will not be static. It will move along with the particle.
I am sorry, I used the term "uniform" loosely. You are right in this regard.
Jano L. said:No, No. If the particle is put at rest into the applied magnetic field of other sources, it will not move, because the magnetic force vanishes.
Can you please clarify, how does the magnetic force vanish?
- · Replies 5 ·
- Replies
- 5
- Views
- 2K
- · Replies 13 ·
- Replies
- 13
- Views
- 2K
- · Replies 8 ·
- Replies
- 8
- Views
- 2K
- · Replies 0 ·
- Replies
- 0
- Views
- 2K
- · Replies 21 ·
- Replies
- 21
- Views
- 5K
- · Replies 12 ·
- Replies
- 12
- Views
- 2K
- · Replies 1 ·
- Replies
- 1
- Views
- 4K
- · Replies 7 ·
- Replies
- 7
- Views
- 3K
- · Replies 12 ·
- Replies
- 12
- Views
- 5K
- · Replies 1 ·
- Replies
- 1
- Views
- 2K
