Is the Huygens principle incomplete when applied to real waves?
  • Context: Graduate
  • Thread starter Thread starter marts
    Huygens Principle
The discussion centers around the application of Huygens' principle to real waves, particularly in the context of light and water waves. Participants explore the implications of the principle, its extensions, and the behavior of waves in various scenarios, including double-slit experiments and reflections.
  • One participant questions whether Huygens' principle is incomplete when applied to real waves, noting that light from a source should theoretically spread out behind it, which does not align with observed phenomena.
  • Another participant introduces the Huygens-Fresnel principle, mentioning the obliquity factor defined by Kirchhoff, which accounts for angular dependence and eliminates the concept of "backwards" waves.
  • A different participant suggests that the obliquity factor is an ad-hoc fix and discusses Kirchhoff's theory, which complicates the simplicity of Huygens' principle by introducing two types of sources without a physical analog.
  • One participant raises a question about the implications of Huygens' principle for reflection, noting that the proof does not depend on the physical properties of a mirror, leading to confusion about the absence of reflected waves in certain scenarios.
  • Another participant inquires about the behavior of water waves, specifically whether the sources at the slits in a two-slit diffraction setup generate isotropic secondary waves and if they produce backwards waves.
  • A later reply expresses confusion about the relevance of the previous posts to their own inquiry regarding water waves and their behavior under Huygens' principle.
Participants express differing views on the completeness of Huygens' principle and its extensions, with some supporting the obliquity factor and others questioning its validity. The discussion remains unresolved regarding the behavior of real waves and the implications for reflection and diffraction.
There are limitations in the assumptions made about the applicability of Huygens' principle to different types of waves, as well as the definitions of sources in Kirchhoff's theory. The discussion also highlights the complexity introduced by real wave phenomena compared to idealized models.
marts
Hi all
"The Huygens-principle recognizes that each point of an advancing wave front is in fact the center of a fresh disturbance and the source of a new train of waves; and that the advancing wave as a whole may be regarded as the sum of all the secondary waves arising from points in the medium already traversed." (source: Wikipedia)
Applying this principle would mean that that the light coming from a source (eg. a laser) quickly spreads out even behind the source. One would also expect to see inteference-patterns on a screen placed behind and not infront of a double-slit.
Obviously this is not the case (or is it??).
So is there any extended huygens-principle which describes at which angle the elementary waves emit or that gives some other explanation??
Thanks in advance!
Science news on Phys.org
obliquity factor
Absolutely! Fresnel, who extended Huygens's principle into the Huygens-Fresnel principle, recognized the need for an angular dependence of the secondary waves. Kirchhoff nailed it down, defining an obliquity factor = (1/2)(1 + \cos\theta). The angle is with respect to the normal of the primary wavefront. This eliminates the bogus "backwards" wave. (Look up "obliquity factor" in any decent optics book for more.)
This very issue drove me nuts when I was first learning about Huygens's principle. So I feel your pain. :wink:
Thanks Doc Al, that really sets my mind free again.
I had been searching for days without any descent result, so I didn't expect to get such a quick and precise answer at all.
Hi there.
Interestingly, the introduction of the obliquity factor is an ad-hoc fix by Fresnel.
In 1886 Kirchoff gave a full mathematical description which accounts for the behaviour that we see. The obliquity factor falls out of this theory as a limiting case.
Within Kirchoff's theory, there are two types of source, and so the simplicity of Hugens' principle is lost. In addition, there is no physical analog for Kirchoff's sources...
All in all a very fascinating problem. I'd recommend reading this paper:
http://www-ee.stanford.edu/~dabm/146.pdf
Or D. Miller, "Huygens’s wave propagation principle corrected," Opt. Lett. 16, 1370-1372 (1991). if the link doesn't work.
Good luck!
I always wondered how this affects the explanation of reflection.
If you consider the reflection line representing the mirror, actually none of the physical properties of a mirror enters the proof at any point. The proof therefore applies to any imagined line.
So why aren't there reflected waves all over the place?
How does this change for real waves? What I mean by real waves is something like water waves, where there is actually something that is vibrating, so that the sources on the wave-front are real: do these sources generate secondary waves that are isotropic?
Take 2-slit diffraction of water waves. The screen blocks the waves, but the slits can be seen as sources for a new wave because there is actually water at the slits that vibrate (like dipping your finger in a pond at the slits). Do the water at the slits generate backwards waves?
I am somewhat lost. Was this related to my post?
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 22 ·
