- 50,435
- 26,497
In other words, you are stipulating that Alice's description in the OP is correct?Gamma Anon said:The crate is to be launched at speed of ~0.70711c at an azimuth angle of 45° relative to the ground.
PeterDonis said:But the OP has not stipulated that. He thinks there's some sort of paradox involved, because he thinks that his OP is describing a single scenario. But it isn't, and there isn't any paradox here at all. There is just a failure on his part to stipulate which of two distinct scenarios (the one that Bob's description in the OP is a valid description of, and the one that Alice's description in the OP is a valid description of) he wants to discuss.
As specified above, this is insufficient information. Even without special relativity, whether it goes in or not depends on orientation. The new thing with special relativity is Wigner rotation.Gamma Anon said:All they know is that the Assassins intend to launch the crate (500mm x 500mm x 500mm) in the North East direction (Azimuth angle 45°) at a speed of 0.70711c (or exactly (0.5c)^0.5 ).
In such a way that their setup matches Bob’s setup would be the obvious answer.Gamma Anon said:If they are distinct scenarios and thus Alice and Bob shouldn't be comparing them. How should the assassins orientate the the crate prior to launch so the plot will be successful?
It's not a matter of opinions or frames of reference. The initial conditions for how the crate is launched need to be properly specified. Right now, as your OP stands, they are not. "Properly specified" means "a specification that can be translated into invariant terms, i.e., terms that do not depend on any choice of frame of reference". There is no such specification in your OP as it stands now.Gamma Anon said:Alice and Bob form their respective opinion based on different frames of reference
Angle 45 degrees relative to what? Speed of 0.70711c relative to what? Ideally these things would be specified relative to some actual object, not just a "frame", and the object's own state of motion would be specified as well.Gamma Anon said:All they know is that the Assassins intend to launch the crate (500mm x 500mm x 500mm) in the North East direction (Azimuth angle 45°) at a speed of 0.70711c (or exactly (0.5c)^0.5 ).
And their assumptions are inconsistent with each other, so they do not describe the same scenario, they describe different scenarios. That is why they are coming up with different answers.Gamma Anon said:In each of their opinions they have made assumptions about the orientation of the crate relative to the window.
To abbreviate some of the replies (somewhat excessively), Bob and Alice are not describing the same scenario, so the outcomes are different, thus problem solved.Orodruin said:Please reread all of the replies you have obtained. The scenario you are describing here is not the same scenario that Bob is describing.
What is not clear in this description?Gamma Anon said:If the scenarios are different, then it has to do with differences in the crate's launch conditions, but what those differences are has not been well explained (At least not well enough for me to have a good understanding of why these are two different scenarios)
Orodruin said:The point is that Alice’s box is launched with a Lorentz boost such that the north/south sides were perpendicular to the north/south direction before the boost. Bob’s box is instead launched from an orientation such that those sides are perpendicular to the north/south orientation after the boost.
Others have done that. I don't like long narratives that inevitably hide key details in elaborate descriptions. Physics is about events with well-defined coordinates in a given frame of reference. If you specify your frame of reference and coordinates of every event then transform to any other frame correctly, then there are no paradoxes and all is clear.Gamma Anon said:I've thought about this, but I'm not sure how it will come into play and allow the box to pass through the window. I'd really appreciate you read the whole thing and provide a clear resolution if you can. Thanks
So, we may as well move to the train frame at this stage. In which the train and hancar are stationary.Gamma Anon said:Let's consider a more well defined launch scenario:
The assassins intend to launch the crate in a two step process, with each of the faces starting at an initial orientation, while stationary to the ground. The orientation is that one of the vertical faces is pointed due North, with the three other vertical faces pointed South, East and West respectively.
In the first step, the Assassins intend match the train's Northbound velocity, while traveling on a parallel track in a handcar, and line up the crate with the window.
Let's take the crate's velocity to be in the ##x## direction.Gamma Anon said:In the second step, they launch the crate Eastwards at ~0.577c (velocity relative to the handcar).
It's better to do a full position and velocity transformation from the train-handcar frame to the ground frame here. The crate has four corners, each of which has an initial position in the train-handcar frame and begins moving simultaneously in this frame.Gamma Anon said:For an observer stationary to the ground, the crate will be traveling at ~0.70711c with motion at an azimuth angle of 45°
Because of the relativity of simultaneity. The different corners are launched at different times in the ground frame. The bottom corners first, then the top corners. The edges remain straight lines in the ground frame.Gamma Anon said:Why won't a line drawn between the South Western edge of the crate and North Eastern edge of the crate have an azimuth angle of 45°, according to an observer that is stationary to the ground, once the launch sequence is complete?
It would change things, in the sense that the relativity of simulatenity would apply differently. In this case, the rear (westward) corners would be launched first, then the front (eastward) corners.Gamma Anon said:Also, would reversing the order of adding velocity to the crate change the outcome (Handcar Eastwards at 0.5c then crate launched Northwards at ~0.577c)?
Yes it is clear.Orodruin said:What is not clear in this description?
It's called a Wigner Rotation and it's a fundamental insight into the nature of spacetime. In mathematical terms, boosts do not form a sub-group of the Lorentz group of boosts and rotations. I.e. the composition of two boosts will be (in general) a boost plus a rotation.Gamma Anon said:It's confusing, that a two step boost would have a different outcome to a one step boost, but maybe I'm wrong about that.
A two step boost is not a pure boost but a boost plus a rotation so it would not be equivalent to a single step boost. This rotation is known as a Wigner rotation as mentioned earlier in the thread.Gamma Anon said:But as expressed in my most recent post, a two step boost seems to allow for the crate's initial orientation to be as Alice assumed, but for the outcome to be as Bob predicts.
@Gamma AnonOrodruin said:A two step boost is not a pure boost but a boost plus a rotation so it would not be equivalent to a single step boost. This rotation is known as a Wigner rotation as mentioned earlier in the thread.
No, you haven’t. You have guessed at the math. Doing the math entails doing what @Nugatory described and what I actually calculated. If you had done the math you would see that the assassins do have a shot according to the ground frame, contrary to Alice’s reasoning.Gamma Anon said:I've done the math
That isn’t the important line to consider.Gamma Anon said:While this line will be shortened
This! @Gamma Anon pay attention to this.PeroK said:If you specify your frame of reference and coordinates of every event then transform to any other frame correctly, then there are no paradoxes and all is clear.
As I mentioned earlier, the boosts do not form a group. A pair of non-colinear boosts is not a boost but a rotation and a boostGamma Anon said:It's confusing, that a two step boost would have a different outcome to a one step boost, but maybe I'm wrong about that.
Your thoughts would be greatly appreciated.
Side note: This should be expected ... Dr. Mount Doom. Supervillain right there.Orodruin said:Conclusion: If I am the criminal mastermind plotting this deed then Alice better listen to Bob.![]()
Orodruin said:Edit 2: Conclusion: If I am the criminal mastermind plotting this deed then Alice better listen to Bob.![]()
Look at it in the train frame. If it can fit in the train frame then it can fit in the ground frame too. Just describe it fully in the train frame and then transform to the ground frame.Sagittarius A-Star said:I thought it would be easier for Alice to throw a sphere (with radius R) instead of a crate, that fits through the window, with speed c2 at 45°. But now I am not sure.
Dale said:Look at it in the train frame. If it can fit in the train frame then it can fit in the ground frame too. Just describe it fully in the train frame and then transform to the ground frame.
You have an arithmetic error here somewhere. Considering that ##R/\sqrt{2} < R##, it follows thatSagittarius A-Star said:##x(\varphi) = R \cos(\varphi)##
##y(\varphi) = R \frac{\sqrt{2}}{2} \sin(\varphi)##
##d = \sqrt{x(135°)^2+y(135°)^2}=R \frac{\sqrt{3}}{2}##
Orodruin said:You therefore clearly cannot get a result larger than ##R##.
Yes, that was clearly a brain fart on my part. Ok, new try: The argument 135 degrees does not correspond to the line d that you drew. It is the vertical line in the circle rest frame but is tilted in the ground rest frame. This probably has something to do with the resolution. You need the point on the ellipse with the largest vertical projection.Sagittarius A-Star said:My ##d = R \frac{\sqrt{3}}{2}## is smaller than ##R##. The window is length contracted by the same factor. But there must be an arithmetical error.
Oh yes, Alice and Bob were police people, not assassins. The story has too many characters for me to follow.Orodruin said:The question is not whether Alice and Bob know about Wigner rotation. The question is if the assassins do. If they do then they can make the plot work by launching the box in the appropriate orientation. If they don’t, they will fail. So whether Alice or Bob will be right will depend on the assassins’ knowledge of relativity.
Orodruin said:Yes, that was clearly a brain fart on my part. Ok, new try: The argument 135 degrees does not correspond to the line d that you drew. It is the vertical line in the circle rest frame but is tilted in the ground rest frame. This probably has something to do with the resolution. You need the point on the ellipse with the largest vertical projection.
Sagittarius A-Star said:##a=R##
##b=R/\gamma(\frac{c}{\sqrt{2}}) = R \frac{\sqrt{2}}{2}##.
As I said earlier, there is nothing really wrong with the formulas. The wrong assumption is that the angle ##\varphi = 135^\circ## corresponds to the vertical line. This is true only in the rest frame of the ellipse.Sagittarius A-Star said:I think I found my error (after a long time). It has nothing to do with relativistic effects, because I calculated only in the ground frame. I simply wrote wrong formulas for an ellipse.
Contains wrong formulas:Correct formulas:
##(x, y) = (a \cos(t), b \sin(t))\ \ \ \ \ ## Here ##0 \leq t \leq 2\pi## is a parameter, but not the angle to a point on the elipse.
Polar form relative to center:
##r(\varphi) = \frac{ab}{\sqrt{((b \cos(\varphi))^2 + ((a \sin(\varphi))^2}}##
Source:
https://en.wikipedia.org/wiki/Ellipse#Polar_form_relative_to_center
