Is the principle of energy a tautology ?
  • Thread starter Thread starter motion_ar
    Energy Principle
In classical mechanics, energy conservation holds even when acceleration is not constant, provided the potential energy does not explicitly depend on time. The discussion emphasizes that energy is a result of time translation symmetry, as per Noether's theorem. It is noted that both kinetic and potential energy can be defined in terms of work done, leading to the conclusion that T + V = constant. The conversation also highlights that energy can be conserved in systems where momentum is not, illustrating the distinction between the two concepts. Overall, the principles of energy conservation are robust, even in non-standard scenarios.
motion_ar
In classical mechanics, if we consider a force field (uniform or non-uniform) in which the acceleration \vec{a}_A of a particle A is constant, then
{\vphantom{\int}} \vec{a}_A = \vec{a}_A\int \vec{a}_A \cdot d\vec{r}_A = \int \vec{a}_A \cdot d\vec{r}_A{\vphantom{\int}} \Delta \; {\textstyle \frac{1}{2}} \; \vec{v}_A^{\;2} = \Delta \; \vec{a}_A \cdot \vec{r}_A{\vphantom{\int}} \Delta \; {\textstyle \frac{1}{2}} \; \vec{v}_A^{\;2} - \, \Delta \; \vec{a}_A^{\vphantom{^{\;2}}} \cdot \vec{r}_A^{\vphantom{^{\;2}}} = 0{\vphantom{\int}} m_A^{\vphantom{^{\;2}}} \left( \Delta \; {\textstyle \frac{1}{2}} \; \vec{v}_A^{\;2} - \, \Delta \; \vec{a}_A^{\vphantom{^{\;2}}} \cdot \vec{r}_A^{\vphantom{^{\;2}}} \right) = 0{\vphantom{\int}} \Delta \; T_A + \, \Delta \; V_A = 0{\vphantom{\int}} T_A + \, V_A = constant
where
T_A = {\textstyle \frac{1}{2}} \; m_A^{\vphantom{^{\;2}}}\vec{v}_A^{\;2}V_A = - \; m_A^{\vphantom{^{\;2}}} \; \vec{a}_A^{\vphantom{^{\;2}}} \cdot \vec{r}_A^{\vphantom{^{\;2}}}
If \vec{a}_A is not constant but \vec{a}_A is function of \vec{r}_A then the same result is obtained, even if Newton's second law were not valid.
{\vphantom{aat}}
{\vphantom{aat}}
Why? if acceleration were not constant, it looks like the energy is not conserved.
Speaking more generally, energy in classical mechanics is conserved if the sum of the potential energies is not explicitly time dependent. For example, for an object falling in a constant gravitational field, energy is conserved.
Now speaking even more generally, energy is simply a symmetry that arises due to invariance of the system under time translation. (I think its to do with Noether's theorem, or something like that).
Where do you get the left hand side of this?
In the 1d case:
\frac{d \frac{1}{2} \dot{x}^2}{dx}
Is equal to:
\dot{x} \frac{d \dot{x}}{dx}
Which is equal to:
\frac{dx}{dt} \frac{d \dot{x}}{dx}
And using the chain rule is equal to:
\frac{d \dot{x}}{dt}
Which is simply \ddot{x}. So the integral of \ddot{x} with respect to x gives \frac{1}{2} \dot{x}^2. Now, I'm not sure if this applies for the 3d case..
This is essentially called the work energy theorem. If you assume the work energy theorem then energy conservation is indeed a tautology. More to the point, energy is a defined quantity and that definition is constructed so that it is conserved, so in that sense it is, by design, tautological that energy is conserved.
For example, if we consider only the vertical motion of a particle in the Earth's gravitational field (one dimension), then
{\vphantom{\int}} a = a\int_a^b a \cdot dr = \int_a^b a \cdot dr\int_a^b a \cdot dr = \int_a^b \frac{dv}{dt} \cdot {v}\;{dt} = \Delta\:{\textstyle \frac{1}{2}}\:v^{2}\int_a^b a \cdot dr = a \int_a^b dr = a\:\Delta\:r = \Delta\:a\:r{\vphantom{\int}} \Delta\:{\textstyle \frac{1}{2}}\:v^{2} = \Delta\:a\:r{\vphantom{\int}} \Delta\:{\textstyle \frac{1}{2}}\:v^{2} - \Delta\:a\:r= 0{\vphantom{\int}} m \; \left( \Delta\:{\textstyle \frac{1}{2}}\:v^{2} - \Delta\:a\:r \right) = 0{\vphantom{\int}} \Delta\:{\textstyle \frac{1}{2}}\:m\:v^{2} - \Delta\:m\:a\:r = 0{\vphantom{\int}} \Delta\:T + \Delta\:V = 0{\vphantom{\int}} T + V = constantwhere
T = {\textstyle \frac{1}{2}}\:m\:v^{2}V = - m\:a\:ra=g=constantr=y
BruceW: It is possible that this is related to Noether's theorem.
I like your working. It is very concise. You've essentially created a definition of energy which is constant with time for this system.
An interesting point is that we could say that horizontal momentum is also conserved, so maybe we could equally well have defined that as energy, since it is also conserved with time. I think this is where the bit about 'energy corresponds to an invariance of the system with respect to time translation' is important. And to show if something fits this definition, we would need to be more rigorous than simply showing it is conserved with time.
BruceW:
Thanks for your suggestions and comments. I write little because my English is very bad.
In the previous example, the horizontal momentum (mv_x and mv_z) is conserved since a_x = 0 and a_z = 0. However, in other cases, \vec{a} can be constant, but a_x, a_y and a_z can be different to zero.
Consequently, I will incorporate your suggestions in my next post.
In classical mechanics, if we consider the motion of a particle of mass m, then
m=constant\vec{v}=d\vec{r}/dt\vec{a}=d\vec{v}/dt\vec{j}=d\vec{a}/dt\ldots
Definition of Momentum (\vec{M})
\vec{M} \; = \int_a^b m\;\vec{a}\;dt \; = \int_a^b m\;d\vec{v} \; = \Delta \; m\;\vec{v}If \quad \vec{a} = 0 \: \; \rightarrow \; \: \int_a^b m\;\vec{a}\;dt = 0 \: \; \rightarrow \; \: m\;\vec{v} = constant \: \; \rightarrow \; \: \vec{P} = constant
Definition of Momentum 2 (\vec{M}_2)
\vec{M}_2 \; = \int_a^b m\;\vec{j}\;dt \; = \int_a^b m\;d\vec{a} \; = \Delta \; m\;\vec{a}If \quad \vec{j} = 0 \: \; \rightarrow \; \: \int_a^b m\;\vec{j}\;dt = 0 \: \; \rightarrow \; \: m\;\vec{a} = constant \: \; \rightarrow \; \: \vec{P}_2 = constant
Definition of Work (W)
W \; = \int_a^b m\;\vec{a} \cdot d\vec{r} \; = \int_a^b m\;\frac{d\vec{v}}{dt} \cdot \vec{v}\;dt \; = \Delta \; {\textstyle \frac{1}{2}}\;m\;\vec{v}^2If \quad \vec{a} = constant \: \; \rightarrow \; \: \int_a^b m\;\vec{a} \cdot d\vec{r} = \Delta \; m\;\vec{a} \cdot \vec{r} \: \; \rightarrow \; \: {\textstyle \frac{1}{2}}\;m\;\vec{v}^2 + \left(- \; m\;\vec{a} \cdot \vec{r}\right) = constant \: \; \rightarrow \; \: T + V = constant
Definition of Work 2 (W_2)
W_2 \; = \int_a^b m\;\vec{j} \cdot d\vec{v} \; = \int_a^b m\;\frac{d\vec{a}}{dt} \cdot \vec{a}\;dt \; = \Delta \; {\textstyle \frac{1}{2}}\;m\;\vec{a}^2If \quad \vec{j} = constant \: \; \rightarrow \; \: \int_a^b m\;\vec{j} \cdot d\vec{v} = \Delta \; m\;\vec{j} \cdot \vec{v} \: \; \rightarrow \; \: {\textstyle \frac{1}{2}}\;m\;\vec{a}^2 + \left(- \; m\;\vec{j} \cdot \vec{v}\right) = constant \: \; \rightarrow \; \: T_2 + V_2 = constant
If \vec{a}, \vec{j}, \ldots are not constant but \vec{a}, \vec{j}, \ldots are functions of \vec{r}, \vec{v}, \ldots respectively, then the same final result is obtained; even if Newton's second law were not valid (even if \sum \vec{F} \ne m\;\vec{a})
Hmm, whenever you write \vec{a} or anything else instead of a, it does a weird box thing instead of doing a vector line above the letter like it should. It makes all the writing difficult to read. Is this some setting on my computer that is wrong, or I dunno?
I need to sort out my settings, or this is just going to annoy me in other threads. It must be some settings my browser has..
BruceW: I believe that the equations are better shown in the new post,
Physics Forums > Physics > Classical Physics > Definitions of Momentum and Work
Do you mind explaining this part ?
ok, dextercioby:
In classical mechanics, if we consider the motion of a particle of mass m and with acceleration \vec{a}, then
{\vphantom{\int_a^b}}\vec{a} = \vec{a}\int_a^b \vec{a} \cdot d\vec{r} = \int_a^b \vec{a} \cdot d\vec{r}
\int_a^b \vec{a} \cdot d\vec{r} = \Delta \; {\textstyle \frac{1}{2}}\vec{v}^{\, 2}
Now, if \vec{a} \ne constant but \vec{a} is function of \vec{r}; for example, if \vec{a} = k \; \vec{r}, where {k} = constant, then
\int_a^b \vec{a} \cdot d\vec{r} = \int_a^b k \; \vec{r} \cdot d\vec{r}
\int_a^b \vec{a} \cdot d\vec{r} = \Delta \; {\textstyle \frac{1}{2}} k \; \vec{r}^{\, 2}
Therefore,
\Delta \; {\textstyle \frac{1}{2}}\vec{v}^{\, 2} = \Delta \; {\textstyle \frac{1}{2}} k \; \vec{r}^{\, 2}
\Delta \; {\textstyle \frac{1}{2}}\vec{v}^{\, 2} - \Delta \; {\textstyle \frac{1}{2}} k \; \vec{r}^{\, 2} = 0
m \; \left( \Delta \; {\textstyle \frac{1}{2}}\vec{v}^{\, 2} - \Delta \; {\textstyle \frac{1}{2}} k \; \vec{r}^{\, 2} \right) = 0
\Delta \; {\textstyle \frac{1}{2}} \, m \, \vec{v}^{\, 2} - \Delta \; {\textstyle \frac{1}{2}} \, m \, k \; \vec{r}^{\, 2} = 0
\Delta \; T + \Delta \; V = 0
T + V = constant
where:
T = {\textstyle \frac{1}{2}} \, m \, \vec{v}^{\, 2}V = - \; {\textstyle \frac{1}{2}} \, m \, k \; \vec{r}^{\, 2}
Consequently, the same (final) result is obtained, that is:
T + V = constant
Even if Newton's second law were not valid, that is:
If \Sigma \; \vec{F} = m \, \vec{a} then T + V = constant; but if \Sigma \; \vec{F} \ne m \, \vec{a} then also T + V = constant
{\vphantom{k}}
I still don't see the proof of <assume ΣF⃗ ≠ma⃗ , then also T+V=constant>
In the previous example, I do not assume that: \Sigma \; \vec{F} \ne m \, \vec{a}, neither that: \Sigma \; \vec{F} = m \, \vec{a}
If we consider a particle with acceleration \vec{a} = 0 = constant and whit velocity \vec{v} = 0 = constant relative to a inertal frame S, then
{\textstyle \frac{1}{2}} \, m \, \vec{v}^{\, 2} - \; m \, \vec{a} \cdot \vec{r} = constant
T + V = constant
But, from a non-inertial frame S´with acceleration \vec{a}_{s´} = constant relative to the inertial frame S,
T + V = constant
There is no (real) force acting on the particle, then \Sigma \; \vec{F} = 0
{\vphantom{k}}
In Lagrangian mechanics (which is a particular form of classical mechanics), Energy is conserved as long as the potential doesn't depend explicitly on time. And momentum is conserved as long as the potential doesn't depend on the absolute position of particles.
So it is possible to have energy conserved, even though momentum is not conserved. For example, we can say for a single particle, the potential is V=-mgz and its KE is \frac{1}{2}mv^2 In this case, energy is conserved, but vertical momentum is not conserved. Of course, this is only a model, and we could instead make a model including the earth, in which case momentum would be conserved. But you can see the point that we can conceive of systems where energy is conserved but momentum is not.
So I agree that we don't need Newton's second law to have a system where energy is conserved. But this doesn't mean energy is conserved in all conceivable systems (unless we define energy to be a quantity that is conserved in all conceivable systems).
Reformulation:
Definition of Impulse \vec{I}
\vec{I} \; = \int_a^b m \, \vec{a} \; dt \; = \Delta \; m \, \vec{v}
\vec{I} \; = \Delta \; \vec{P}
where:
\Delta \; \vec{P} \; = \Delta \; m \, \vec{v}
If \; \vec{a} = 0
\rightarrow \; \; \Delta \; \vec{P} \; = 0
\rightarrow \; \; \vec{P} \; = constant
Definition of Work W
W \; = \int_a^b m \, \vec{a} \cdot d\vec{r} \; = \Delta \; {\textstyle \frac{1}{2}} \, m \, \vec{v}{\: ^2}
W \; = \Delta \; T + \Delta \; V \; = \int_a^b m \, \vec{a}_{n\vec{r}} \cdot d\vec{r}
where:
\Delta \; T = \Delta \; {\textstyle \frac{1}{2}} \, m \, \vec{v}{\: ^2}
\Delta \; V = - \int_a^b m \, \vec{a}_{\vec{r}} \cdot d\vec{r}
\vec{a} = \vec{a}_{\vec{r}} + \vec{a}_{n\vec{r}}
\vec{a}_{\vec{r}} \; \; \; is \; \; function \; \; of \; \; \; \vec{r}
\vec{a}_{n\vec{r}} \; \; \; is \; \; not \; \; function \; \; of \; \; \; \vec{r}
If \; \vec{a}_{n\vec{r}} = 0
\rightarrow \; \; \Delta \; T + \Delta \; V \; = 0
\rightarrow \; \; T + V \; = constant
If \; \vec{a} = 0
\rightarrow \; \; \Delta \; T \; = 0
\rightarrow \; \; T \; = constant
So you're saying that if the acceleration is a function of position, then the energy of the system is constant? I don't think this is enough.
In Lagrangian mechanics, if we have:
\frac{\partial V}{\partial t} = 0
Then the energy is conserved (since we are assuming the kinetic energy is 1/2 mv^2). Here's a rough way to show it, starting with the Euler-Lagrange equation (for a particle in 1D):
L = \frac{1}{2}m \dot{x}^2 - V
(Where L is the Lagrangian of the system and the dot on the x means the derivative of x with respect to time). And the Euler-Lagrange equation for this system is:
\frac{\partial L}{\partial x} = \frac{d}{dt} \frac{\partial L}{\partial \dot{x}}
I don't think there is a way to derive the Euler-Lagrange equation from anything more fundamental, so I'm just going to have to assume it is true here. Now, I'll also assume that the potential depends only on time and position, (not on speed), and do the calculation for the Euler-Lagrange equation:
- \frac{\partial V}{\partial x} = m \ddot{x} \ \text{ (equation 1)}
(Where I also assumed that the mass did not depend on time). We can use this equation later. For now, the energy is:
E = T + V = \frac{1}{2}m \dot{x}^2 + V
And so differentiating the energy with respect to time will tell us how the energy of the system depends on the position and time coordinates of the particle:
\frac{dE}{dt} = \frac{\partial E}{\partial \dot{x}} \frac{d \dot{x}}{dt} + \frac{\partial E}{\partial x} \frac{dx}{dt} + \frac{\partial E}{\partial t}
(Which is the full differentiation using partial derivatives). Now, we can use our definition of E, to get:
\frac{dE}{dt} = m \dot{x} \ddot{x} + \frac{\partial V}{\partial x} \dot{x} + \frac{\partial V}{\partial t}
And we can use the useful equation from before (equation 1), to put in something more useful for the middle term:
\frac{dE}{dt} = m \dot{x} \ddot{x} - m \ddot{x} \dot{x} + \frac{\partial V}{\partial t}
So two of the terms disappear, and we end up with:
\frac{dE}{dt} = \frac{\partial V}{\partial t}
Which means that energy is conserved as long as the potential is not explicitly time dependent. (And I also assumed that the mass was constant and that the potential did not depend on the speed of the particle).
This result can be extended to 3 dimensions, and for multiple particles. But the Euler-Lagrange equation for several particles in 3D is more complicated, so I don't have the energy to write that all out!
This equation is the definition of potential energy V, where \vec{a}_{\vec{r}} is a function of \vec{r}.
If the acceleration \vec{a}_A of a particle A is a function of their position \vec{r}_A, then the energy ( \, T_A + V_A \, ) is conserved.
Example A (for a particle in 1D)If a_x = k \; x^0, where k = constant = 0, then
\Delta \; V = - \int_a^b m \, k \; x^0 \; dx \; = - \Delta \; m \, k \; x \; \; \; \rightarrow \; \; \; V = - \; m \, k \; x
Since a_x is a function of x, then
T + V = constant{\textstyle \frac{1}{2}} \; m \; v_x^2 - \; m \, k \; x = constant
Therefore, in this example A, the energy ( \, T + V \; \, ) is conserved, and V \; is constant (since k = constant = 0)
Example B (for a particle in 1D)If a_x = k \; x^0, where k = constant \ne 0, then
Therefore, in this example B, the energy ( \, T + V \; \, ) is conserved, but V \; is not constant (since k = constant \ne 0, then a_x \ne 0, therefore x is not constant)
hmm, I see what you mean. You're essentially defining the change in potential energy to be negative of the change in kinetic energy, so that the total energy change is always zero. Right? In this case, energy conservation is a tautology, because energy is defined as something which is conserved with time.
But suppose we used some other definition for the potential energy. Then in this case, the total energy may not be conserved.
I still do not translate your last post.
I am interested in the Euler-Lagrange equation.
I think that this equation can be deduced from another fundamental equation, but I still do not know.
However, (for a particle in 1D)
If a_x is a function of x, then T_x + V_x is constant.
Therefore, I think the following points:
V_x is a function of v_x, and v_x is a function of x and t
I should have been more specific. I meant that I assume the potential doesn't depend explicitly on speed of the particle. In other words:
\frac{\partial V}{\partial \dot{x}} = 0
(while keeping t and x constant).
If \vec{a} is a function of \, \vec{r}
\rightarrow \; \; T + V \; is conserved.
\rightarrow \; \; T \; is a function of \, \vec{v}
\rightarrow \; \; V \; is a function of \, \vec{v}
\rightarrow \; \; \vec{v} \; is a function of \, \vec{r}
Only if V is defined to change in an opposite way to T. And we can model a system where this is not true. For example, where there is an external field acting on the particle.
Definition of W
W \; = \int_a^b \; m \; \vec{a} \cdot d\vec{r} \; = \Delta \; {\textstyle \frac{1}{2}} \, m \; \vec{v}^2
Definition of T
\Delta \; T = \Delta \; {\textstyle \frac{1}{2}} \, m \; \vec{v}^2
Definition of V
\Delta \; V = - \int_a^b \; m \; \vec{a}_{\vec{r}} \cdot d\vec{r} \; \; \; ( where \vec{a}_{\vec{r}} is a function of \vec{r} )
If \vec{a} is a function of \vec{r} then \vec{a}=\vec{a}_{\vec{r}}
\rightarrow \; \; \Delta \; T = - \Delta V
\rightarrow \; \; \Delta \; T + \Delta V = 0
\rightarrow \; \; T + V = constant
For example, in a inertial frame we have: \vec{a}=\sum \vec{F}/m, then
W \; = \int_a^b \; m \sum \vec{F}/m \cdot d\vec{r} \; = \int_a^b \sum \vec{F} \cdot d\vec{r} \; = \Delta \; {\textstyle \frac{1}{2}} \, m \; \vec{v}^2
If \sum \vec{F}_{\vec{r}} is a sum of conservative forces (\; \rightarrow \; \sum \vec{F}_{\vec{r}} is a function of \vec{r} \; \rightarrow \; \vec{a}_{\vec{r}} is a function of \vec{r}) then
\Delta \; V = - \int_a^b \; m \sum \vec{F}_{\vec{r}}/m \cdot d\vec{r} = - \int_a^b \sum \vec{F}_{\vec{r}} \cdot d\vec{r}
Therefore, if the forces acting on a particle are only conservative forces then \sum \vec{F} = \sum \vec{F}_{\vec{r}} (\; \rightarrow \; \vec{a}=\vec{a}_{\vec{r}} \; \rightarrow \; \vec{a} is a function of \vec{r})
Consequently, if the forces acting on a particle are only conservative forces then T + V \; is conserved ( this is a tautological statement )
T \; is a function of \; \vec{v}
V \; is a function of \; \vec{r}
If \; T \, + \, V \, = \, constant then
T \, = - \, V \, + \, constant \; \; \; \rightarrow \; \; \; T \; is also a function of \; \vec{r}
V \, = - \, T \, + \, constant \; \; \; \rightarrow \; \; \; V \; is also a function of \; \vec{v}
