Is the Product of Expectation Values Always True in Quantum Mechanics?
daudaudaudau
In quantum mechanics, when is this true
<br /> \langle\psi|AB|\psi\rangle=\langle\psi | A|\psi\rangle\langle\psi |B|\psi\rangle<br />
? In probability theory, when the two variables are independent, the mean value of the product is the product of the mean values. What about QM?
It is true if |\psi\rangle is a normalized eigenstate of both A and B because then
<br /> \langle \psi|AB| \psi\rangle=a_\psi b_\psi<br />
The equation
<br /> \langle \psi|AB|\psi\rangle = \langle \psi|A|\psi\rangle \langle \psi|B|\psi\rangle \ \forall \psi<br />
also leads to [A,B]=0. But assuming that [A,B]=0 and that both are usual Hermitian observables does not seem to imply the above equation for general states, even though any state can be expanded as a linear combination of common eigenstates: this would require
<br /> \sum_i a_ib_i|c_i|^2 = \sum_{i,j} a_i b_j |c_i|^2 |c_j|^2<br />
for
<br /> |\psi\rangle = \sum_i c_i |\psi_i \rangle.<br />
So I don't have an answer to your question but I wrote anyway :) But
<br /> \langle AB \rangle = \langle A \rangle \langle B \rangle<br />
of course means that in the particular configuration, the operators are uncorrelated and there is e.g. no Heisenberg uncertainty in measuring both observables "simultaneously".
Yeah, it is not enough for the operators to commute, because A commutes with A, but
<br /> \langle\psi|A^2|\psi\rangle\neq\langle\psi | A|\psi\rangle\langle\psi |A|\psi\rangle<br />
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
