Is the symbol dx equivalent to Δx in these situations?
  • Thread starter Thread starter karkas
    Symbol
The symbols Δx and dx represent different concepts in mathematics and physics. Δx denotes a finite change in position (xfinal - xinitial), while dx signifies an infinitesimal change. In the context of speed, both v = Δx/Δt and v = dx/dt can be correct under specific conditions, such as when acceleration is absent. However, dx/dt is preferred for its precision, while Δx/Δt requires clarification of the interval used. Understanding these distinctions is crucial for accurately interpreting equations in differential calculus and physics.
karkas
I have seen the symbol dx in differential equations, but recently I saw it appear in various other equations that I previously thought included Δx instead of dx.
Are those two symbols the same? I mean, is Δx = dx = xfinal - xinitial ?
This may be the wrong thread, but I am still a newcomer, and plus I thought I saw another such question around here before!
Thanks
Mathematics news on Phys.org
Welcome to PF!
Hi karkas! Welcome to PF! :smile:
∆x is an actual difference.
dx is an infinitesimal difference.
dx/dt = lim{∆x(t)/∆t} = lim{[x(t+∆t) - x(t)]/∆t}.
(for linear functions, of course, it makes no difference)
So Δx = xfinal - xinitial is correct :smile:
but dx = xfinal - xinitial is wrong :cry:
Thanks Tiny - tim!
Yet I still don't understand something (probably it's because we're taught everything in Greek and I am still not adept with English terminology).
If I say that the speed is v = Δx/Δt and v = dx/dt is the same thing if there is no force disrupting the linear movement?
karkas said:
Thanks Tiny - tim!
hmm … mathematical symbols should be an international language! :smile:
Yes, v = dx/dt is always correct …
but if there's no acceleration, then v = ∆x/∆t is also correct.
However, when you write dx/dt, you don't need to explain it,
but when you write ∆x/∆t, you need to specify a particular interval. :wink:
In physics and engineering, cap delta is frequently used to denote a finite change, a little bit of something. Thus cap delta x denotes a finite change in x.
It is common in setting up a problem to write things in terms of finite differences before passing to the limit when these differences, in the form of ratios, become derivatives.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
