Is the variation of the metric ##\delta g_{\mu\nu}## a tensor?
  • Context: Graduate
  • Thread starter Thread starter Kostik
    Metric
The discussion revolves around the nature of the variation of the metric tensor, specifically whether the variation ##\delta g_{\mu\nu}## can be classified as a tensor. Participants explore the implications of different equations related to the variation of the metric and the conditions under which these variations retain tensorial properties.
  • Some participants present equations relating to the variation of the metric tensor, questioning whether ##\delta g_{\mu\nu}## and ##\delta g^{\mu\nu}## are tensors based on their index manipulation.
  • Others argue that the Leibniz rule must be applied when calculating variations, suggesting that this impacts the tensorial nature of the variations.
  • A participant states that under variation, while ##g_{\mu\nu}+\delta g_{\mu\nu}## is a tensor, the individual components ##g_{\mu\nu}## and ##\delta g_{\mu\nu}## are not tensors.
  • Another participant suggests that the presence of an extra minus sign in the equations does not affect the tensorial transformation properties.
  • There is a discussion about how to distinguish which of the presented equations holds for each tensorial quantity, indicating uncertainty about the implications of the minus sign in the context of tensor variations.
Participants express differing views on whether ##\delta g_{\mu\nu}## is a tensor, with some asserting it is not, while others maintain that it is. The discussion remains unresolved, with multiple competing interpretations of the equations presented.
Participants reference specific equations and rules for raising and lowering indices, but there is a lack of consensus on the validity of these applications in the context of variations. The discussion highlights the complexity of tensor calculus and the nuances involved in variations of the metric tensor.
  • #31
weirdoguy said:
physicists with their sloppy use of language would :wink:
Yes, and this is the relativity forum, not one of the math forums, so physics sloppiness wins out here. :cool:
  • #32
anuttarasammyak said:
Thanks. Even with this general caution, may we take it obvious that in tensor division of
$$ \bar{g}_{\mu\nu} := g_{\mu\nu}+\delta g_{\mu\nu} $$
all ## \bar{g}_{\mu\nu}## , ##g_{\mu\nu}## and ##\delta g_{\mu\nu}## are tensors in the world of metric undertaking variation ?
Yes.
  • #33
I will summarize what I have written.
The index-raising and -lowering relation for the metric tensor
$$ g_{\mu\nu}=g_{\mu\alpha}g_{\nu\beta}g^{\alpha\beta} ,$$
holds for a varied metric tensor as
$$\bar{g}_{\mu\nu}=\bar{g}_{\mu\alpha}\bar{g}_{\nu\beta}\bar{g}^{\alpha\beta} $$
where
$$ \bar{g}_{\mu\nu} := g_{\mu\nu}+\delta g_{\mu\nu} .$$
$$ \bar{g}^{\mu\nu} := g^{\mu\nu}+\delta g^{\mu\nu} .$$
Equation (*) in the OP follows from this.
I agree with the OP that if ## \delta g_{\mu\nu} ## were a tensor, then equation (**) in the OP would hold.
A tensor satisfying (*) remains a mystery to me.
  • #34
where
As @haushofer remarked in #18, it is the behavior under coordinate transformations that determines whether something is a tensor. If Weinberg says ##~\delta g_{\mu\nu}~## qualifies, I'd take it seriously.
I think the notation is misleading. I'll repeat my argument from #25 in a slightly modified form: consider a regular spacetime with a (single!) metric ##~g_{\mu\nu}~## . Suppose we have a smooth symmetric tensor field ##~A_{\mu\nu}~## which has the same signature as the metric at every point. Suppose further that there is also a symmetric tensor field ##~B^{\mu\nu}~## satisfying the same signature condition, such that ##~B^{\mu\rho}A_{\rho\nu}=\delta^\mu{}_\nu~## . Would you necessarily expect ##~B^{\mu\nu}=A^{\mu\nu}~~##?
Edit: added "symmetric"
  • #35
Going back to basics, Dirac's textbook defines a tensor as follows:
$$ T^{\alpha'\beta'}_{\gamma'}=x^{\alpha'}_{,\lambda}x^{\beta'}_{,\mu}x^{\nu}_{,\gamma'}T^{\lambda\mu}_{\nu}
\ \ \ (3.6)$$
How exactly should I perform coordinate transformations to investigate the quantity I'm considering? Or is there a more obvious way to check?
  • #36
JimWhoKnew said:
consider a regular spacetime with a (single!) metric gμν . Suppose we have a smooth symmetric tensor field Aμν which has the same signature as the metric at every point. Suppose further that there is also a symmetric tensor field Bμν satisfying the same signature condition, such that BμρAρν=δμν . Would you necessarily expect Bμν=Aμν ?
I am sorry I don't understand "the same signature". If A is g itself, I think that B = A = g.
A=mg, B=1/m g where m is a real number ##\neq 0## satisfy the relation.
I am sorry not to be smart enough to relate A ##\neq## B with the discussion.
  • #37
\ \ \ (3.6)$$
So what @haushofer and I said above is in agreement with Dirac's definition. A little nitpicking: if you write ##~T^{\lambda\mu}_\nu~## , then after raising the ##\nu## index, you don't know the order of ##~\{\nu,\lambda,\mu\}~## from left to right.
In general, you'll need more information. For example: we know that the connections (##\Gamma##'s) are not tensors, because we know how they should be transformed. In the example of #34 we assume that ##~A_{\mu\nu}~## is a tensor field, so it follows that ##~A_{\mu\nu}\pm g_{\mu\nu}~## are also tensor fields.
Given a specific inertial frame in Minkowski spacetime, ##~C(x)_{\mu\nu}:=\delta_{\mu\nu}~## is a symmetric invertible smooth tensor field whose signature is different from that of ##~\eta_{\mu\nu}~##. So the signature assumption is needed in the example of #34.
That's correct, but I want to consider the general case, not only trivial cases. As I said in #34, I find that the notation in OP (following Weinberg and others) obscures the property of "sameness" as pointed in #25. That's why I use A and B instead.
A=mg, B=1/m g where m is a real number ##\neq0## satisfy the relation. I am sorry not to be smart enough to relate A##\neq##B with the discussion.
No need to get personal.
If ##~A_{\mu\nu}=m~g_{\mu\nu}~## then ##~A^{\mu\nu}=m~g^{\mu\nu}\neq g^{\mu\nu}/m=B^{\mu\nu} ~~##.
What does this example imply when we write ##~\bar{g}_{\mu\nu}:=m~g_{\mu\nu}~## (and still use g to raise and lower indices)?
Hint: equation (**) in OP is wrong, while (*) is correct to first order in ##\delta g~##.
I hoe this study is on a right track.
I don't understand your example. If your manifold is 1D (the ring), it should be charted by a single coordinate. If it is a 2D Euclidean as in the drawing, the line element should contain terms proportional to ##~drdr, drd\theta, d\theta d\theta~~##. In 2D Euclidean space, you can easily see that a short arrow tangent to the constant r ring (in your lower drawing) is not necessarily tangent to the constant r' curve (meaning it may have a radial component in the primed coordinates).
  • #38
First of all, thanks @JimWhoKnew
So in general cases which could include ##\delta g^{\mu\nu}##, do we need further information or condition to say it is a tensor or not, though the answer of #32 was affirmative ?
JimWhoKnew said:
In the example of #34 we assume that Aμν is a tensor field, so it follows that Aμν±gμν are also tensor fields.
I agree that the sum of tensors is a tensor. And sum of no tensors could be sometimes a tensor.
JimWhoKnew said:
What does this example imply when we write g¯μν:=m gμν (and still use g to raise and lower indices)?
Well, the metric under variation $$\bar{g}^{\mu\nu}=g^{\mu\nu}+(m-1)g^{\mu\nu}=g^{\mu\nu}+\delta g^{\mu\nu}$$
$$ \delta g^{\mu\nu} = (m-1)g^{\mu\nu} $$
from (*)
$$ \delta g_{\mu\nu} = -(m-1)g_{\mu\nu} $$
I may be wrong and/or missing the point. Your further coaching would be appreciated.
  • #39
@haushofer has already addressed this question in #11. I don't want to get into it here. You'd better consult a textbook (d'Inverno has a nice treatment, despite a little sign inconsistency). Very sloppily: under a coordinate transformation ##~T(x)\rightarrow T'(x')~~##. If ##~T(x)~## is a tensor field, so are ##~T'(x')~## , ##~T'(x)~## and ##~T'(x)-T(x)~~##. Now, we know that the metric is a tensor field, therefore ##~\delta g^{\mu\nu}~## is a tensor field too (we have to be careful with this economic notation).
from (*)
With ##~A_{\mu\nu}=m~g_{\mu\nu}~## and ##~B^{\mu\nu}=g^{\mu\nu}/m~##
1) Find ##~\hat{\delta}_{\mu\nu}:=A_{\mu\nu}-g_{\mu\nu}~## (as a function of g and m).
2) Find ##~\tilde{\delta}^{\mu\nu}:=B^{\mu\nu}-g^{\mu\nu}~##.
3) Find ##~\hat{\delta}^{\mu\nu}~##.
4) Assume ##m=1+\epsilon~## where ##|\epsilon|\ll 1~##. Expand the results of (2) and (3) above to first order in ##\epsilon##. Compare with equation (*) in OP.
The important point in my posts: ##~A^{\mu\nu}\neq B^{\mu\nu}~## in general (and therefore equation (**) in OP is wrong).
  • #40
JimWhoKnew said:
With Aμν=m gμν and Bμν=gμν/m
1) Find δ^μν:=Aμν−gμν (as a function of g and m).
2) Find δ~μν:=Bμν−gμν .
3) Find δ^μν .
4) Assume m=1+ϵ where |ϵ|≪1 . Expand the results of (2) and (3) above to first order in ϵ. Compare with equation (*) in OP.
Thanks. I will restate it to confirm my understanding. Here I try not to refer controversial (at least to me) tensor and concentrate on what I found in making use of this example.
The metric
$$ \bar{g}_{\mu\nu}=mg_{\mu\nu} $$
With
$$ \bar{g}_{\mu\alpha} \bar{g}^{\alpha\nu} =\delta^{\nu}_{\mu}$$
$$ \bar{g}^{\mu\nu}=\frac{1}{m}g^{\mu\nu} $$
Say A which satisfies the equation
$$ A_{\mu\nu}=\bar{g}_{\mu\alpha} \bar{g}_{\nu\beta}A^{\alpha\beta} $$,
##\bar{g}_{\mu\nu}## is A as easily confirmed in this example. The old metric ##g_{\mu\nu}## is not A, actually,
$$ mg_{\mu\nu}=\bar{g}_{\mu\alpha} \bar{g}_{\nu\beta}\frac{1}{m}g^{\alpha\beta} $$
Let us rewrite this equation as
$$ g_{\mu\nu}+\delta g_{\mu\nu}=\bar{g}_{\mu\alpha} \bar{g}_{\nu\beta}(g^{\alpha\beta}+\delta g^{\alpha\beta} )$$
where
$$\delta g_{\mu\nu}=(m-1)g_{\mu\nu}$$
$$\delta g^{\mu\nu}=(\frac{1}{m}-1)g^{\mu\nu}$$
Expecting the variation to be small
$$m=1+\epsilon,\ \ |\epsilon|<<1$$
$$\delta g_{\mu\nu}=\epsilon g_{\mu\nu}$$
$$\delta g^{\mu\nu}=-\epsilon g^{\mu\nu}+0(\epsilon^2)$$
Both ##g_{\mu\nu}## and ##\delta g_{\mu\nu}## are not A. Their sum ##g_{\mu\nu}+\delta g_{\mu\nu}## is A. ##\delta g_{\mu\nu}## and ##\delta g^{\mu\nu}## is introduced to be so. We should not be surprised to see such a conventional quantity satisfies the peculiar equation (*).
Equation (*) holds by changing ##g## to ##\bar{g}##. We can regard one metric original and the other varied and vice versa.
In case that A and B are metric, A=B. I used it.
  • #41
The metric
I intentionally defined ##\hat{\delta}## and ##\tilde{\delta}~##. g is the only metric in this example, and should be used to raise and lower indices. I expected answers to the 4 simple steps as stated.
Edit:
If later on you want to rename ##g## as ##\bar{g}## and regard it as the "new" metric, it doesn't matter, as long as you are consistent and unambiguous. In such a case, the "old" metric will take the form of A and B, which will not represent the same tensor.
  • #42
To me the point is two metrics: original and varied. In varied metric world what kind of things or relations remain and what does not ?
  • #43
Let's look at it step by step. Point out where you disagree.
We have the original metric ##g## and the varied ##\bar{g}~##. Is it legitimate to take the difference$$g_{\mu\nu}=\bar{g}_{\mu\nu}-\delta g_{\mu\nu}\quad ? \tag{1}$$If the answer is "no", the discussion in OP is irrelevant. So let's explore the other option. Now we ask whether there is a meaning to raising the indices of ##~\delta g_{\mu\nu}~##. Again, if the answer is "no", the discussion in OP is irrelevant. If "yes", then we are faced with the question how should it be done? We may attempt to preserve symmetry between the metrics by raising one index by ##g## and the other by ##\bar{g}~##. But now we have to choose which one raises the left index, which breaks the symmetry. Moreover, the contravariant form will not be symmetric, which is an undesired feature. The other (and more logical) option is to raise both indices with the same metric. Without loss of generality, we may choose ##\bar{g}~## ("the varied world"). But this choice breaks the symmetry between the metrics, making ##~\bar{g}~## the preferred one. With this choice, the RHS of (1) is raised by ##~\bar{g}^{\mu\nu}~## , so to maintain consistency, the LHS must also be raised by ##~\bar{g}^{\mu\nu}~##. But now we get the inevitable result that the contravariant form ##~\bar{g}^{\mu\rho}g_{\rho\sigma}\bar{g}^{\sigma\nu}~## is not the inverse of the covariant form ##~g_{\mu\nu}~## (assuming ##~\delta g_{\mu\nu}\neq0~~##), and this was my point all along.
Edit:
The OP (following Weinberg) defines ##~\delta g^{\mu\nu}:=\bar{g}^{\mu\nu}-g^{\mu\nu}~## , where ##~g^{\mu\nu}~## is the inverse of ##~g_{\mu\nu}~## . In the framework of the above discussion, where ##~\bar{g}~## was chosen as prefered, this ##~\delta g^{\mu\nu}~## is not the contravariant form of ##~\delta g_{\mu\nu}~## (so equation (**) in OP is inconsistent under the above assumptions, while (*) is satisfied).
  • #44
My bad. I withdraw it.
  • #45
JimWhoKnew said:
We may attempt to preserve symmetry between the metrics by raising one index by g and the other by g¯ . But now we have to choose which one raises the left index, which breaks the symmetry. Moreover, the contravariant form will not be symmetric, which is an undesired feature. The other (and more logical) option is to raise both indices with the same metric.
I agree that index raise- lower operation should be done using one same, old or new, metric for all the indexes of all the entities in equations.
  • #46
JimWhoKnew said:
The OP (following Weinberg) defines δgμν:=g¯μν−gμν , where gμν is the inverse of gμν . In the framework of the above discussion, where g¯ was chosen as prefered, this δgμν is not the contravariant form of δgμν (so equation (**) in OP is inconsistent under the above assumptions, while (*) is satisfied).
$$\bar{g}_{\mu\nu} - g_{\mu\nu} = \delta g _{\mu\nu} = - \delta \bar{g}_{\mu\nu} $$
##\bar{g}_{\mu\nu}## is a tensor in the world where metric is ##\bar{g}_{\mu\nu}## itself.
##g_{\mu\nu}## is a tensor in the world where metric is ##g_{\mu\nu}## itself.
Their difference ##\delta g _{\mu\nu} = - \delta \bar{g}_{\mu\nu} ## belong to neither or both the worlds. I observe that minus sign in (*) , which is shared in both the worlds, comes from this ambivalence.
  • #47
The minus sign in (*) follows from the definitions which are used, and from the requirement that ##~g^{\mu\nu}~## and ##~\bar{g}^{\mu\nu}~## are the inverse of ##~g_{\mu\nu}~## and ##~\bar{g}_{\mu\nu}~## respectively (in both worlds, assuming its legitimacy as addressed in #43). Since only terms up to first order in ##~\delta g~## (same as your ##~-\delta \bar{g}~~##) are maintained, it is trivial to note that (*) is invariant under "barring".
  • #48
Yes. For
$$g_{\mu\nu}= g_{\mu\alpha} g_{\beta\nu} g^{\alpha\beta},\ g^{\mu\alpha} g_{\alpha\nu}=\delta^\mu_\nu $$
symbolically I write
$$ 1=1*1*1,\ 1*1=1 $$
and for all barred things
$$ 1+\epsilon=(1+\epsilon)(1+\epsilon)(1-\epsilon),\ (1+\epsilon)*(1-\epsilon)=1 $$
in first order of ##\epsilon##. When one becomes fat, the other becomes thin.
Only up to first order is the rule on variation though I do not want to argue it is trivial or not.
  • #49
An example of my point.
Say light is passing on element ##dx^\mu##, i.e.,
$$ g_{\mu\nu}dx^\mu dx^\nu = 0 $$
After variation of metric
$$ \bar{g}_{\mu\nu}dx^\mu dx^\nu \neq 0 $$
The light changes its course and ##dx^\mu## means something different from the light path.
##dx^\mu## is a 4-vector in the sense of invariance under coordinate transformation in the old metric world. It is also a 4-vector in the sense of invariance under coordinate transformation in the new metric world. May we say it that the metric change has nothing to do with 4-vector property of ##dx^\mu## ?
  • #50
Yes. For
With "the requirement that ##~g^{\mu\nu}~## and ##~\bar{g}^{\mu\nu}~## are the inverse of ##~g_{\mu\nu}~## and ##~\bar{g}_{\mu\nu}~## respectively", expand the RHS of$$0=\bar{g}^{\mu\rho}\bar{g}_{\rho\nu}-g^{\mu\rho}g_{\rho\nu}=\bar{g}^{\mu\rho}\bar{g}_{\rho\nu}-\left(\bar{g}^{\mu\rho}-\delta\bar{g}^{\mu\rho}\right)\left(\bar{g}_{\rho\nu}-\delta\bar{g}_{\rho\nu}\right)\quad.$$Since the result is already first order in ##~\delta\bar{g}~## , we can now get rid of the ##~\bar{g}^{\mu\rho}~## by using either ##~\bar{g}_{\sigma\mu}~## or ##~g_{\sigma\mu}~##.
Equally, we could have expressed the middle term by the un-barred quantities to derive (*). Not trivial?
  • #51
How about the following? ##\delta g_{\mu\nu}## is a tensor, but ##\delta g^{\mu\nu}##, defined as
$$\delta g^{\mu\nu} \equiv - g^{\mu\alpha} g^{\nu\beta} \delta g_{\alpha\beta}$$
is not dual to ##\delta g_{\mu\nu}##. Instead, its dual is
$$(\delta g)^{\mu\nu} \equiv g^{\mu\alpha} g^{\nu\beta} \delta g_{\alpha\beta}$$
which is a different object from ##\delta g^{\mu\nu}##. Does it make sense?
  • #52
weirdoguy said:
Yes, but still some people wouldn't call those tensors "the same object". Especially most mathematical physicists/mathematicians that I know, including myself. But yes, physicists with their sloppy use of language would :wink:
Well, J.L. Synge also considered them the same object in the presence of a metric; and only in the presence of a metric is the exact vertical placement of indices important to track 'slots' on one object that can have upper or lower indices for each slot. Note, he was first and foremost a mathematician.
  • #53
After some thinking, I believe it's only a problem in notation. To make the explanation simpler, I find convenient to use an index-free matrix notation. Thus ##g_{\mu\nu}## are components of the matrix ##g##, while ##g^{\mu\nu}## are components of its inverse ##g^{-1}##, so we have
$$g^{-1}g=1.$$
This implies ##\delta (g^{-1}g)=0##, i.e.
$$(\delta g^{-1})g + g^{-1} \delta g =0,$$
so multiplying with ##g^{-1}## from the right, we obtain
$$\delta g^{-1} = -g^{-1} \delta g \, g^{-1}. \;\;\; (1)$$
Now let us define dual tensors. For any tensor ##T## with components ##T_{\mu\nu}## we define the dual tensor ##\overline{T}## with components ##T^{\mu\nu}## as
$$\overline{T} = g^{-1} T g^{-1}.$$
In particular, for ##T=g## we have
$$\overline{g} = g^{-1} g\, g^{-1} = g^{-1},$$
so (1) can be written as
$$\delta \overline{g}= -g^{-1} \delta g \, g^{-1}. \;\;\; (1')$$
On the other hand, if we take ##T=\delta g## we obtain
$$\overline{\delta g} = g^{-1} \delta g\, g^{-1}. \;\;\; (2)$$
Now we see that there is no contradiction between (1') and (2) because ##\delta \overline{g}## is not the same thing as ##\overline{\delta g}##. In the original notation both quantities have been denoted by the same symbol ##\delta g^{\mu\nu}##, which was the source of confusion.
Next note that (1') and (2) can also be inverted as
$$\delta g= -g \delta \overline{g}\, g$$
$$\delta g= g \overline{\delta g}\, g$$
Again, there is no contradiction because ##\delta \overline{g} \neq \overline{\delta g}##.
Finally, note that the inequality ##\delta \overline{g} \neq \overline{\delta g}## can be expressed in words as the claim that the variation of the dual is not the dual of the variation. Indeed, since the dual of ##g## is defined as ##\overline{g}=g^{-1} g g^{-1}##, we have
$$\delta \overline{g} = (\delta g^{-1}) g g^{-1} + g^{-1} (\delta g) g^{-1} + g^{-1} g (\delta g^{-1}).$$
Now we use ##g g^{-1}=g^{-1} g =1## and ##\delta g^{-1}=\delta \overline{g}##, so the equation above becomes
$$\delta \overline{g} = \delta \overline{g} + g^{-1} \delta g\, g^{-1} + \delta \overline{g},$$
which implies
$$\delta \overline{g} = - g^{-1} \delta g\, g^{-1}$$
which, in turn, is nothing but a different derivation of (1').
  • #54
Yes, and I don't know him (in person, since I was talking about people I know in person) and I still wouldn't call those tensors "the same object". But I know I am overly pedantic when it comes to those things.
  • #55
Demystifier said:
Again, there is no contradiction because δg―≠δg―.
To put it simply
$$ \bar{\delta g}=-\delta \bar{g} $$
May I understand that ##\{\delta g, \bar{\delta g}\}=\{\delta g, -\delta \bar{g} \}## are tensor indeces up-down pair but ##\{\delta g, \delta \bar{g}\}## are not that pair which does not follow ordinary indeces up-down transformation but with additional minus, and this distinction in variation does not take place for other tensor T than metric tensor g, i.e.
$$ \bar{\delta T}=\delta \bar{T} $$ ?
  • #56
To put it simply
I don’t see why you would expect that last to be true in general. Starting from T with indexes down, in one case you have the metric raising indexes outside of the variation, in the other are, inside. Why would you expect these to be the same?
  • #57
@anuttarasammyak in general ##\delta \overline{T} \neq \overline{\delta T}##. (By the way, in LaTeX use the command \overline, not \bar, to get a line over the whole object such as ##\overline{\delta T}##.) Since ##\overline{T}=g^{-1}Tg^{-1}##, we have
$$\delta \overline{T} = (\delta g^{-1})Tg^{-1} + g^{-1}(\delta T)g^{-1} + g^{-1}T(\delta g^{-1}).$$
Using
$$\overline{\delta T}=g^{-1}(\delta T)g^{-1},$$
$$\delta g^{-1}=\delta\overline{g}=-g^{-1}(\delta g)g^{-1},$$
the expression above simplifies to
$$\delta \overline{T} = \overline{\delta T} - g^{-1}\delta g\, \overline{T}-\overline{T}\delta g\,g^{-1}.$$
Thus we see that ##\delta \overline{T} \neq \overline{\delta T}##, unless ##\delta g=0##. But yes, the metric ##g## is special, because it is involved in the definition of the dual ##\overline{T}=g^{-1}Tg^{-1}##.
  • #58
  • #59
Now I know that
$$ (\delta g)^{\mu\nu}=g^{\mu\alpha}g^{\nu\beta}(\delta g)_{\alpha\beta} $$
$$ \delta g^{\mu\nu}=-g^{\mu\alpha}g^{\nu\beta}\delta g_{\alpha\beta} $$
Here I have a question. Is
$$(\delta g)_{\alpha\beta}=\delta g_{\alpha\beta}$$
$$(\delta g)^{\alpha\beta}=-\delta g^{\alpha\beta}$$
a convention alternative of which with coefficient -1 can be
$$(\delta g)_{\alpha\beta}=-\delta g_{\alpha\beta}$$
$$(\delta g)^{\alpha\beta}=\delta g^{\alpha\beta}$$
  • #60
Yes, I think that's right. But the first convention is not completely arbitrary. In a sense ##g_{\mu\nu}## is more elementary than ##g^{\mu\nu}##, because the tangent space is more elementary than the cotangent space. Or at least that's how I think intuitively about differential geometry.
  • · Replies 16 ·
  • · Replies 38 ·
