Mentor
- 23,905
- 11,362
...also, have you guys ever had a pot or dinner plate attach itself to the drain in your sink?
sophiecentaur said:The model of having the rod passing through a frictionless, sealed hole in the bottom of the tank seems to be the easiest one which will eliminate any effect from or on the floor.
No. As you said, "the downward water pressure on the support has removed". That's it. Downward pressure has been removed does not equal upward force, it equals zero force.Mapes said:To those saying that the buoyant force completely disappears if liquid is excluded from the bottom of the cylinder, please consider again my diagram in post #20, where no liquid contacts the cylinder bottom, but I predict a measurable upward displacement and associated force. Is there an error in this reasoning?
[separate post]I made a diagram with similar reasoning to Studiot. Consider an object with a strain gauge attached, rigidly attached to the container bottom (welded or epoxied, say, so that no liquid can get underneath). I've marked the downward water pressure that acts on the top face of the object; of course, water pressure is exerted on the other faces also.
Now attach an empty cylinder to the object (rigidly by welding or epoxy, so that no water can get underneath). The downward water pressure on the support has now been removed. The support and strain gauge will therefore elongate due to this change in stress.
Does this not represent and measure the buoyant force of the empty cylinder?
My guess, either they didn't figure that the ground underneath the tower was for all intents and purposes liquid. Either that or there was a large pipe underneath the tower that again was buried in the ground under the reservoir and it floated. This would be similar to what happens to a pool if it is left empty or a septic tank if it doesn't have a mound on top of it: it floats.stewartcs said:Archimedes principle doesn't apply. If there is no pressure acting on the bottom of this perfectly vertical cylinder then there will be absolutely no buoyant force.
In all of the examples given, pressure has found some way to get under the cylinder and thus provide and upward force. If it does not, there will be no upward force.
CS
agtee said:Hi all,
If i attach a cylinder at the bottom of the water tank such that some of its part is out out of water. So in this case what would be the buoyancy force acting on the cylinder?
-agtee.
russ_watters said:No. As you said, "the downward water pressure on the support has removed". That's it. Downward pressure has been removed does not equal upward force, it equals zero force.
There are configurations (like my diagram in #20) where the water can push sideways (laterally) and cause the vertical extent of a solid support to increase through the Poisson effect. This is equivalent to a buoyant force, since it doesn't occur until the empty cylinder has been attached.
russ_watters said:Mapes, boyancy is an actual upwards force, not a lack of downward force.
Studiot said:If this were indeed a contributory factor then any bouyancy force would depend upon the structural configuration of the support, rather than the Archimedean principle of the volume of displaced water. You can't have it both ways.
Studiot said:I understand and agree with it, with one proviso: It is not a source of bouyancy, indeed it will act in addition to any bouyancy force.
Studiot said:But the reaction force between the base and the support block must equal the weight of the support plus whatever it is supporting. So all your gauge is measuring is the weight of the second box as I said before.
Mapes said:It is an upward force... It is caused by water displacement... The force is essentially equal to the weight of the water that would have filled the cylinder (assuming a lightweight cylinder)... Does any reference define this phenomenon as anything other than buoyancy? If so, I'd like to look at it; I'm not excluding the possibility that I'm wrong.
For simplicity, I was ignoring the weight of the empty cylinder compared to the weight of the water that it displaced. But yes, to be super precise, the stress state in the support is
[tex]\left[\begin{array}{ccc}<br /> -\rho g h(1-\frac{z}{h}) & 0 & 0\\<br /> 0 & -\rho g h(1-\frac{z}{h}) & 0\\<br /> 0 & 0 & -\rho g h-\frac{W_\mathrm{supp}}{A}(1-\frac{z}{t_\mathrm{supp}})<br /> \end{array}\right][/tex]
in the first case (left side of the diagram) and
[tex]\left[\begin{array}{ccc}<br /> -\rho g h(1-\frac{z}{h}) & 0 & 0\\<br /> 0 & -\rho g h(1-\frac{z}{h}) & 0\\<br /> 0 & 0 & -\frac{W_\mathrm{cyl}}{A}-\frac{W_\mathrm{supp}}{A}(1-\frac{z}{t_\mathrm{supp}})<br /> \end{array}\right][/tex]
in the second case (right side of the diagram), where [itex]\rho[/itex] is the water density, [itex]g[/itex] is gravitational acceleration, [itex]h[/itex] is the depth to the container floor, [itex]W_\mathrm{supp}[/itex] and [itex]t_\mathrm{supp}[/itex] are the weight and height of the support, respectively, [itex]A[/itex] is the cross-sectional area of the cylinder and support, [itex]z[/itex] is the vertical distance from the container floor, and [itex]W_\mathrm{cyl}[/itex] is the weight of the empty cylinder.
I believe it has been assumed in this entire thread that the empty cylinder weighs less than an equal volume of water.
The attachment of the empty cylinder thus corresponds to the addition of a normal tensile stress [itex]\rho gh-W_\mathrm{cyl}/A[/itex] in the vertical direction. This is buoyancy.
stewartcs said:Mapes,
Are you saying that the hydrostatic pressure is "squeezing" the support thus causing it to push the cylinder up?
CS
Mapes said:The hydrostatic load in the x- and y-directions is a constant [itex]-\rho g h(1-z/h)[/itex]. However, with the lessening of compressive stress [itex]\sigma_z[/itex] from
[tex]-\rho g h-(W_\mathrm{supp}/A)(1-z/t_\mathrm{supp})[/tex]
to
[tex]-(W_\mathrm{cyl}/A)-(W_\mathrm{supp}/A)(1-z/t_\mathrm{supp})[/tex]
(shown in post #44), a shrinking of the support dimensions in the x- and y-directions is predicted if the support material has a Poisson's ratio [itex]\nu>0[/itex] (as essentially all solid materials do). In this sense, the support is squeezed. But I wouldn't say that the cylinder is being pushed up; I would say rather that its buoyancy pulls on the support.
In any case, descriptions like "squeezing" and "pulling" are less precise and more likely to cause confusion than a straightforward look at the equations.
stewartcs said:OK let's try this: Imagine the support is perfectly rigid and cannot be compressed (idealized case). What upward force is being applied to the cylinder now? Just a normal reaction equal to the air weight of the cylinder. Thus the support is completely supporting the cylinder.
If you try to pick up the cylinder the force required would be equal to the air weight of the cylinder (same as the reaction force prior to lifting it off). At the infinitesimal moment you lift the cylinder off of the support that reaction force is no longer there and the force required to move it up (until the hydrostatic pressure started acting on it) would be the air weight of the cylinder.
Mapes said:I can tell you haven't looked at the equations closely, because you're talking about "picking up" the cylinder. You can't "pick up" the cylinder, because it's pulling up with a buoyant force of
[tex]\rho g A(h-t_\mathrm{supp})-W_\mathrm{cyl}\approx\rho g Ah[/tex]
(for [itex]t_\mathrm{supp}\ll h[/itex] and [itex]W_\mathrm{cyl}\ll \rho g h A[/itex]). This is the change in the stress state that the comparisons above tell us. Regardless of strongly felt intuition, is there a problem with these calculations, acquired by free-body diagram?
Part of the problem is that you're thinking of the weight of cylinder in terms of what it would mean at the water's surface. At the surface, an empty cylinder on a support would just produce a net downward force of [itex]W_\mathrm{cyl}[/itex] on the top of the support. But at the bottom of the liquid, you need to compare it with the alternative, a huge hydrostatic pressure [itex]\rho g (h-t_\mathrm{supp})[/itex] on the top of the support. Replacing it with the weight of the cylinder means you've reduced the pressure on the top of the support. This is equivalent to a buoyant force.
When you say "Thus the support is completely supporting the cylinder.", remember that while it is supporting a downward pressure of [itex]W_\mathrm{cyl}/A[/itex], before the empty cylinder was attached it supported a downward pressure of [itex]\rho g (h-t_\mathrm{supp})[/itex]. Again, this a reduction in compressive stress, and the magnitude of the reduction is [itex]\rho g (h-t_\mathrm{supp})-W_\mathrm{cyl}/A[/itex]. It is exactly the same as if, by another means, you applied a buoyancy force of [itex]\rho g A(h-t_\mathrm{supp})-W_\mathrm{cyl}[/itex] on the surface of the support.
I'm not quite able to visualize your second thought experiment, the one with the spring scale inside the rigid cylinder. A diagram would help. But please, think about the current thought experiment before switching to a new one, so I can see which specific equation or calculation you disagree with.
Mapes said:I'm not quite able to visualize your second thought experiment, the one with the spring scale inside the rigid cylinder. A diagram would help. But please, think about the current thought experiment before switching to a new one, so I can see which specific equation or calculation you disagree with.
stewartcs said:No, I've not bothered looking closely at the equations because there is no need to.
stewartcs said:Whether the cylinder or supports are elastic or perfectly rigid is irrelevant with respect to buoyant force. A perfectly rigid member that has pressure acting on the bottom surface will still have a buoyant force. If the pressure isn't acting on the bottom it will not (presuming no other pressure ledges again).
stewartcs said:Remove the elastic members from your example and make them rigid. Do your equations still hold?
stewartcs said:Are you still arguing that if there is no hydrostatic pressure acting on the bottom of the cylinder that it will experience a buoyant force?
Mapes said:Wow. Well, there's nothing I can do about that.
Agree, agree, respectfully don't agree.
Yes; the equations do not include the stiffness of any components.
Yes, it's what I showed in post #42 and in more detail in post #44 with stress states calculated via a free-body diagram (not shown).
Mapes said:EDIT: Perhaps we're getting away the main issue here. My only point is that it's not sufficient to say "The water has nowhere to push up, so no buoyant force can exist." There are configurations (like my diagram in #20) where the water can push sideways (laterally) and cause the vertical extent of a solid support to increase through the Poisson effect. This is equivalent to a buoyant force, since it doesn't occur until the empty cylinder has been attached.
Studiot said:As a result of the poisson effect is there a bouyancy force tending to lift the material above the section away (upwards) from the material below?
stewartcs said:By rigid I mean the shape doesn't change which means there is no Poisson's Effect. Take away that effect and take another look at your position.
Studiot said:Your suggestion is tantamount to saying that a T shaped support would experience a bouyancy force equal to the weight of fluid in its entire volume, not just the exposed flange.
stewartcs said:The problem I have with your argument is that it puts a material dependency on the buoyant force when there is none. What happens if the material properties change? Does the buoyant force change as well?
CS
Mapes said:Yes, exactly. The buoyant force depends on the volume of water displaced, not on the shape of the cylinder or its orientation or attachment method. Otherwise you could create an non-conservative force at will simply by attaching it or detaching it, or by rotating it effortlessly. This would constitute a perpetual motion device.
Mapes said:Asked and answered in post #42. The buoyant force that I argue exists is independent of the support stiffness or of any material properties except for cylinder weight. No material properties of the support appear in the buoyant force prediction [itex]\rho g A(h-t_\mathrm{supp})-W_\mathrm{cyl}\approx\rho g Ah[/itex].
