Is there a delay of 1 or 2 seconds in generation of back emf in a dc motor
The discussion revolves around the behavior of back electromotive force (back EMF) in a DC motor, particularly whether there is a delay in its generation after the motor starts. Participants explore the relationship between back EMF, applied EMF, and the mechanical dynamics of the motor during startup.
  • Some participants suggest that back EMF should appear immediately as the motor starts moving, aligning with the generator principle and Lenz's law.
  • Others argue that the back EMF depends on the rotor's angular velocity and may appear to have a delay due to the motor's mechanical response time.
  • A participant notes that measuring back EMF with an oscilloscope might show low readings initially, but this is attributed to the motor's acceleration rather than a true delay in back EMF generation.
  • One participant discusses the influence of load on the time it takes for back EMF to reach its maximum, indicating that a loaded motor may take longer to stabilize compared to an unloaded one.
  • Another participant highlights that the time constants related to the motor's windings and mechanical inertia affect the response time of back EMF.
  • There is a suggestion that routing back EMF into another circuit might be impossible, as it would contradict established principles of energy conservation and efficiency in motors.
  • Some participants mention the efficiency of modern brushless motors and the role of back EMF in generator operation.
  • Discussion includes the impact of magnet strength on back EMF generation and motor efficiency, with varying opinions on how this affects performance.
Participants express differing views on whether there is a delay in back EMF generation, with some asserting immediate response and others suggesting a finite delay influenced by mechanical factors. The discussion remains unresolved regarding the exact nature of this delay and its implications.
Participants acknowledge that the response of back EMF is influenced by various factors, including mechanical inertia, load conditions, and the characteristics of the motor's windings and magnets. These variables complicate the discussion and prevent a straightforward conclusion.
mix609
Does the back emf in a dc motor start to appear after a slight delay(say 1 or 2 seconds) after starting up the motor?
I have had this simple doubt for a long time.According to the "generator principle" both applied emf and back emf will always exist simultaneously.Also it would be in violation of lenz's law for such a delay to take place.Would'nt it?
Back EMF should depend entirely on phase and angular velocity of the rotor for any given motor. It's not a direct response to the applied EMF. So if it takes a bit of time for the motor to spin up, you might see something that looks like a delay in response. But this has more to do with mechanics than electrodynamics.
thanks k^2
So if i were to measure the waveform using an oscilloscope or some other relevant device,i would see that the back emf reading remains close to zero during at least the 1st second of operation of the dc motor after starting it up.
Consider a small DC motor connected to a large heavy flywheel. Might take 20 seconds for the system to reach full speed. The back emf takes the same time to reach a maximium. The current during that time can be very high but reduces as the motor speeds up.
Same motor, no load it will reach max speed very much faster.
In both cases the back emf starts increasing the instant the motor starts moving.
Precisely. Oh, and it doesn't matter what causes the motor to spin, so measuring back EMF might actually be easier without applying the voltage, and spinning up the motor by other means.
CWatters is correct. In the case of a sensor based brushless dc motor controller, during startup, after the first 3 or so steps (in case the first step goes the wrong direction), the controller can start using the back emf as feedback. This usually takes less than 1/10th of a second for a typical dc motor, depending on the load.
Back EMF is directly dependent on the angular velocity of your motor's rotor. Whatever rate your rotor is rotating at in any instant of time will directly relate to the back EMF generated at that instant of time. The time for your motor to reach a given angular velocity depends on the resistance and inductance of your windings that will create a time constant slowing down the time that the applied EMF is attained, and then even when this has been reached, there is another mechanical time constant of the inertia and friction of the motor and its load that will slow down the time that the angular velocity reaches steady state (and so, back EMF too).
So your thread question is completely dependent on all of these variables to where the direct answer would be no, not 1-2 seconds necessarily, but it is a finite, non-zero, time delay for back EMF to reach any value after an applied EMF in a DC motor.
thanks all,
my doubt has been cleared :)
Also i was wondering if the back emf from the dc motor could be routed into another circuit using a diode;just like using a flyback diode on an inductor to prevent the sudden build up of counter emf when supply to the inductor is switched off.
This must be impossible because if it were true, that one could somehow "recapture" back emf or simply prevent it from countering the applied emf then people would have done it and made motors very efficient in the process- possibly by also using the motor as both a motor and generator simultaneously.
obviously this has nothing to do with regenerative braking or any such mechanism.
Actually its a very simple experiment because motors and diodes are well understood.yet by doing a google search for routing back emf to an external ckt, all i found was just a large number of "free energy" patents talking about "recapturing" back emf and recharging source batteries instead of dissipating it.i am sure all those claims are false otherwise electricity would cost a lot less & there would be no energy crisis.
Modern brushless motors ARE very efficient. Some have been made that are over 95% efficient. Remaining losses are down to winding resistance, bearing friction, air drag on the rotor etc
Generators rely on backemf to work.
It might be worth understanding how the power of the magnets in a permanant magnet DC motor can effect efficiency...
Lets say you want your motor to run at a particular speed when a fixed voltage is applied. Recall that these motors basically accelerate until the backemf is close to the applied voltage. The backemf depends on the power of the magnets and the number of turns (think generator).
So if you have a motor with weak magnets the rotor will need to have more turns to generate the same backemf. More turns = more resistance in the windings = greater losses.
Swap the magnets for nice strong samarium cobalt magnets. Now you need fewer turns to achieve the same backemf. Fewer turns = lower resistance = lower losses.
An interesting fact is that if you overheat this type of motor and partly demagnitise the magnets the no-load speed goes up not down. It has to spin faster to generate the same backemf.
13K
  • · Replies 16 ·
  • · Replies 16 ·
