Is there a limit to wind power?
139 replies · 16K views
Skeptik22
Is there a limit to the amount of energy which can be extracted from the wind?
There are a huge number of windfarms springing up around the world.. all taking energy from the wind.
The assumption seems to be that this is limitless and "free".
Clearly this is not possible.
The question is (I think) - how will the transfer of energy (from the wind) manifest itself on the climate, and could the impact be measured?
The only research I have seen to date, relates to finding the "best" location for a windmill, and some on the effect on local weather conditions.
So far we extract wind energy near to the ground, which is equivalent to putting up some high obstacles, like trees.
Agreed ... the question still remains .. how much energy can you extract before it has an effect ... one could argue that any energy extracted must have some effect... but that it would be so insignificant that it cannot be detected .. the question is still ... if one continued to extract more and more ..at what point could the effect be detected?
Also agree that the immediate effect would be at ground level.. but there must be some point at which perturbations at ground level have an effect on the overall system?
My analogy would be of throwing pebbles into a river .. a couple would go unnoticed .. a lorryload would have some effect..
On a global scale, that energy is extracted from the wind anyway by interaction with the ground / natural obstacles. On a local scale though, you change where it is extracted, and where and it gets dissipated as heat.
Sorry to be pedantic .. but the windfarm has been specifically added to the environment to extract N gigawatts which previously would have been involved in the climate system..
In the river analogy, the pebbles are added to the existing riverbed .. altering the flow..
...and dissipated somewhere else. All the energy that goes into creating wind, is also dissipated by interaction with the surface/obstacles. Regardless what the obstacles are. The question is just where it and when it happens.
Adding a layer of pebbles, which is only a tiny fraction of the river depth, will not have much effect on the river globally. Also, you have to consider all the wind obstacles humans have already removed and will keep removing by deforestation.
The energy can be absorbed from windpower until the wind exists. So the limit depends only by weather condition, firstly the global warming, since the impact of wind farms on it, also if they slow down the speed of air particles assorbing kinetic energy, is still probably too small to detect, like it happens with other masses of obstacles, or to make some previews. So I've really more interest about the risk of a global warming increase and I think the principal negative impact for a wind farm is still the rumour.
Technically, you can't beat Betz! Someone (named Betz) did the math and found that you cannot extract more than approx. 60% of the energy of wind. ie do a mass flow problem with a circular area of where the wind propeller operates and the maximum amount of energy that can be extracted is not quite 60% theoretical. In reality, it is less, usually a LOT less.
And most (if not ALL) turbines have to feather (turn off and turn sideways) so as to not overload their power output capabilities once wind speeds exceed a certain value. This is because it is no longer safe to operate the turbines due to wind shear stress on their structure or buckling of their foundations. Wind speed energy is a cubic function. At low to moderate wind, there is very little energy to be harvested. Once the wind speed is above 15 mph, it starts to become attractive (lower winds can generate energy, but most turbines are underutilized with these breeze speeds). I believe 30-40 Mph is the typical cut out (turn off) speeds for most wind turbines, but you should reference other sources before you quote that. At 30 mph most turbines are running well over their design output ratings (ie in danger of burning up or wearing out their bearings, if they were operated for extended times)
That is why there needs to be a certain distance between large wind turbines for best energy capture (and safety, nobody wants to play dominos on a large scale).
Thanks A.T. I have edited to correct.
CalcNerd said:
Technically, you can't beat Bets!
Betz
Yes, there is, but it's due to factors which have nothing to do with the amount of wind.
When the tax incentives and subsidies propping up the financial side of wind farms are removed, they tend to become an uneconomical means of power generation.
http://www.telegraph.co.uk/news/ear...m-plans-in-tatters-after-subsidy-rethink.html
Maybe my pebble analogy is not entirely valid .. I saw the lorryloads as piles rather than a thin uniform layer ... maybe a windmill is not such a barrier.
I have seen Betz before in another discussion and maybe I misunderstand ... If you have a wind hitting a mill what is the difference between the air prior to the mill and that downstream?
If N gigawatts have been removed .. is it slower ? denser? higher pressure?
Pierce610 said:
http://www.telegraph.co.uk/news/ear...can-cause-climate-change-finds-new-study.html
yes, thanks, I'm just watching it: the kinetic energy is transferred from wind to turbines also with conversion in heat and so it's going to increase the local warming, and then the global one; surely this is not good.
Kinetic energy to heat conversion has nothing to do with the climate effect reported in that article. With or without turbines, 100% of wind energy ends up as heat.
A windfarm has tougher restrictions than the Betz limit, because wind turbines in close proximity will interfere with each other. The front ones may get efficiencies close to the Betz limit (yes, turbines are that good), but they cause turbulence in the air stream which interferes with the efficiency of the back turbines. The calculation of efficiency becomes a lot more difficult. There is a limited amount of energy you can extract from some volume of air above a land area. You can increase the available energy by building taller turbines, but it gets more expensive and structurally difficult.
It's comparable to a couple of high trees. You could compare the rate at which we are removing trees, to the rate we build windmills.
http://en.wikipedia.org/wiki/Deforestation_by_region
World annual deforestation is estimated as 13.7 million hectares a year, equal to the area of Greece. Only half of this area is compensated by new forests or forest growth.
[QUOTE=It's comparable to a couple of high trees.
I was beginning to wonder of this really was a physics forum... question was not about whether a windfarm was a GOOD THING, or not. Nor was it about the cost .. it was about detecting and measuring the effect.
1 windmill = 2 tall trees
sounds like a measurement... and yet... I have 2 tall trees in my garden and am not aware of any Megawatts being dissipated
Rough numbers regarding wind energy: global average of 2 W/m2 to maintain a global average wind speed of 10 m/s; that's also a global average energy of moving air that is ~ 500 kJ/m2; average viscous dissipation of 2 W/m2. Play with those numbers as you will, keeping in mind that they are estimates. They may have been refined somewhat over the past fifty years, but they haven't changed much. How much interference in water transport, precipitation patterns, evapotranspiration, and other atmospheric transport might result from wind farms is anybody's guess, and to my knowledge, not been examined in any detail.
"A couple of" doesn’t mean exactly two. If the total size of the tree crowns is comparable to the disc area of the windmill, the removed wind energy will be comparable.
Thanks for the numbers, although I am not sure what could be done with them.
This is interesting
http://www.mdpi.com/2072-4292/6/12/12234
1 Windmill = 1 object with the same characteristics as a windmill ? http://web.iitd.ac.in/~drsbr/IMAGES/HornsRevTurbulence.jpg may give a way of detecting the effect .. so what about measurements?
Does Betz law imply that the wind behind the mill is exhausted ... or at least has less energy?
Is this air slower, denser, lower pressure?
Could a windfarm produce an area of "low pressure"
Here's an interesting article:
Stanford Report, September 10, 2012
Wind could meet many times world's total power demand by 2030, Stanford researchers say
The researchers have dubbed this point the saturation wind power potential. The saturation potential, they say, is more than 250 terawatts if we could place an army of 100-meter-tall wind turbines across the entire land and water of planet Earth. Alternatively, if we placed them only on land (minus Antarctica) and along the coastal ocean, there is still some 80 terawatts available – about seven times the total power demand of all civilization. Hypothetical turbines operating in the jet streams 6 miles up in the atmosphere could extract as much as 380 terawatts.
"We're not saying, 'Put turbines everywhere,' but we have shown that there is no fundamental barrier to obtaining half or even several times the world's all-purpose power from wind by 2030. The potential is there, if we can build enough turbines," said Jacobson.
According to wiki:
Wind power capacity and production
Worldwide there are now over two hundred thousand wind turbines operating, with a total nameplate capacity of 282,482 MW as of end 2012.
Using the hypothetical 380 terawatts from the article, and the 282 Gw from wiki, I calculate that we currently have the capacity to remove ≈1/10 of 1% of the energy from the air.
I'm not sure if a study has been done of how much energy has not been redistributed due to deforestation over the last 6,000 years.
That might be something fun to model.
Not sure what you are asking here
Betz law limits how much less it can have behind a stationary turbine.
http://en.wikipedia.org/wiki/Betz's_law
http://www.nature.com/nclimate/journal/v3/n2/full/nclimate1683.html
Geophysical limits to global wind power
snip
We find wind turbines placed on Earth’s surface could extract kinetic energy at a rate of at least 400TW, whereas high-altitude wind power could extract more than 1,800TW. At these high rates of extraction, there are pronounced climatic consequences. However, we find that at the level of present global primary power demand (~ 18TW; ref. http://www.nature.com/nclimate/journal/v3/n2/full/nclimate1683.html#ref2), uniformly distributed wind turbines are unlikely to substantially affect the Earth’s climate.
How much is the energy of wind?
If its speed is 10 m/s, the density is about 1 kg/1 m^3 and its volume is 1 m^3, then the energy is 50 J.
How much is the power of wind?
If its speed, density, and volume are invariated and the surface is 1 m^2, then the power is 500 W.
How many watt are transferred in a turbine?
If speed is 10 m/s, almost enough to produce work and the power of the wind is 500 W for every m^2 and the efficiency is about 0,6, then the power transferrred is 300 W for every m^2. So the total depends by effective area of interaction.
In which ambiental conditions the speed of wind can be 10 m/s?
In a gas energy is the product PxV, at a certain temperature, and its delta is due to a variation o pressure, volume, or both.
So it must be for example a difference of pressure for making work.
To produce a speed of 10 m/s and an energy of 50 J it occours a difference of 50 Pa, mantaining costant the volume.
How much time this velocity can hold on?
If the volume of the gas is 1^m3 and the delta of pressure is 50 Pa, then the time is 0,1 s.
If the volume is 3600 m^3 and the delta of pressure is 500 Pa, then the time become one hour.
Can trees, and other obstacles reduce the wind?
They can reduce the speed, togher with an increase of the duration of the wind, because they are like a barrier that initially divide in two a chamber, holdin costant the difference of pressure, and then, opened, it allows the air flow; only a flying tree subtract watt.
How could we measure the impact of remixing warm and cold air during night by wind farm?
Mixing air makes it homogeneous; P x V and its delta depends on temperature and its value and the duration of wind could change; if we know in the normality the values of speed, difference of pressure and the duration of wind, we could compare them with those obtained in presence of wind farm.
I hope I've explained correctly it.
I said "If the volume is 3600 m^3 and the delta of pressure is 500 Pa, then the time become one hour."
I must correct in "if the volume is 36000 m^3 and the delta of pressure is 50 Pa, the speed is still 10/ms and the durating becomes one hour.
I only checked the math on your first 3 answers, and they looked good to me, so I didn't check the rest.
The above assumption, about "flying trees", got me thinking though.
If you were to build a model of the Earth, by hanging a balloon from the ceiling, and attached a piece of tape to the perimeter, such that it stuck out, and then you blew on the tape to model a wind, wouldn't the wind impart a torque on the balloon, making it spin?
I tried figuring out this morning what the resultant torque on the Earth would be from a single hypothetical tree (20 meters tall, and 1 meter wide) with 1 Newton of force per square meter being extracted:
Code:
total force                                    20   N
rotational kinetic energy of Earth      2.138E+29   joules
radius of Earth                           6371000   m
mass of Earth                               6E+24   kg
torque                                   44597000   N*m
But then, as the meme tells us to do, I cried.
OmCheeto said:
If you were to build a model of the Earth, by hanging a balloon from the ceiling, and attached a piece of tape to the perimeter, such that it stuck out, and then you blew on the tape to model a wind, wouldn't the wind impart a torque on the balloon, making it spin?.
Yes.
But wind does not come from outer space so the result is meaningless.
How would you be aware of that, in any case? How many MW of solar power are landing on your garden?
But what would be the efficiency of energy conversion with your two trees? As a transducer from moving air to heated tree, they could be very low in efficiency. Have you tried measuring air temperatures? Even if you have, could you actually relate them to power transfer?
billy_joule said:
Yes.
Actually, I've heard that wind is solar powered, so the source of the wind is, in a roundabout kind of way, from outer space.
Anyways, we could duct tape a small fan onto a larger balloon, and do the experiment with, and without the protruding tape/tree.
I'm fairly certain, the results would be different.
