Is there a nice formula for the following function?
  • Thread starter Thread starter arildno
    Formula Function
The discussion centers on finding an explicit formula for the function S(k,n), which represents the sum of products of k distinct integers from the set {1, 2, ..., n}. The trivial cases are noted as S(1,n) = n(n+1)/2 and S(n,n) = n!. A proposed formula involves using combinations of integers, but the user is seeking a simpler expression rather than a recursive method. The conversation reveals that S(k,n) relates to the unsigned Stirling numbers of the first kind, which could provide further insights into the problem. The user expresses satisfaction upon discovering this connection, linking it to the coefficients of the falling factorial polynomial.
arildno
Dearly Missed
Hi there!
I am seeking a nice formula for the following function S(k,n), k and n natural numbers, k<=n, where S(k,n) is the sum of all possible products (permutations not allowed) of k distinct integers, where the integer set runs from 1 to n.
Thus, for example, we have the trivial cases of S(1,n)=n(n+1)/2 and S(n,n)=n!
Thanks in advance
EDIT:
I'm not really interested in an implicit recursive method (that's fairly trivial to set up), but an explicit expression of S
Mathematics news on Phys.org
arildno said:
Hi there!
Thanks in advance
In general I doubt you'll do better than
<br /> S(k,n) = \sum_{\begin{array}{c}U \subset \{1, \dots, n\} \\ |U| = k\end{array}} \left(\prod_{u \in U} u \right)<br />
Thanks!
I've thought of that as well, and it won't be any touble for me setting up a recursive scheme to calculate whatever value of S that I want.
I was hoping, though, that some mathematician had figured out a surprisingly simple formula..
You can calculate S(2,n) (partial solution given here),
S(2,n) = \sum_{j=1}^{n-1} j \sum_{r=j+1}^{n} r
\sum_{r=j+1}^{n} r = (n+j)(n-j+1)/2
So
S(2,n) = \sum_{j=1}^{n-1} j(n+j)(n-j+1)/2
You can distribute it and get a sum over j, a sum over j2, and a sum over j3 all of which have known formulas. Trying to repeat this exact process (sum over j, sum over r > j, sum over s > r for S(3,n) for example) is doable but tedious. It might be able to be generalized to S(k,n) directly though with extreme cleverness
Thank you, Office Shredder!
I did think of such schemes, but didn't want to go through the calculations (I do not trust myself in gleaning a general pattern here).
It would be easier, say computerwise, to set up a plodding algorithm, but I thought that a function S(k,n) OUGHT to occur in lots of combinatorics problems, for example, so that some mathematician had done some serious thinking upon S.
Another explicit value will, obviously, be S(n-1,n), which must equal (n!)*H(n), where H(n) is the harmonic sum of the n first numbers (which DOES have a rather nice expression).
But, it is all those in-betweens I wonder about..:frown:
If I understand you correctly, your ##S(k,n)## is the (unsigned) Stirling number of the first kind ##\left[n+1 \atop n + 1 - k\right]##. You should be able to find a lot of information about these numbers once you know that they are the Stirling numbers of the first kind.
Hooray!
That seems to be the name of my beast!
Thanks a bundle!
As a matter of fact, my conundrum arose from seeking to calculate the coefficients of the polynomial I now have learned the name of, "the falling factorial", x*(x-1)*(x-2)*...(x-n)
