Is There a Trick to Solve for Theta in this Algebraic Equation?
  • Thread starter Thread starter scavok
    Algebra
To solve for theta in the given algebraic equation, start by dividing the entire equation by g sin(theta) to simplify it. This leads to a new equation where y is defined as 14/(g sin(theta)). By manipulating the equation, you can express it as a quadratic in terms of y. Squaring both sides after isolating y allows for solving the quadratic equation. Finally, substituting back will yield the values for theta, though the results may indicate a potential error in the original physics context.
scavok
http://home.comcast.net/~andykovacs/equation.GIF
g is a constant. I need to find theta.
Is there some trick I can do to cancel out the denominator in the root?
Hint:
Set
y=\sqrt{\sin\theta}
and see what type of equation you get for y.
No, you can't cancel- but you can square. I would first divide the entire equation by g sin(\theta) to get
\frac{20}{g sin(\theta)}= \frac{14}{g sin(\theta)}+ \sqrt{\frac{14}{g sin(\theta)}}+ 8.41
I would even write it as
\frac{10}{7}\frac{14}{g sin(\theta)}= \frac{14}{g sin(\theta)}+ \sqrt{\frac{14}{g sin(\theta)}}+ 8.41
because then I can let y= \frac{14}{g sin(\theta)} and have
\frac{10}{7}y= y+ \sqrt{y}+ 8.41
That gives
\frac{3}{7}y- 8.41= \sqrt{y}
Square on both sides:
(\frac{9}{49}y- 8.41)^2= y[/itex]<br /> <br /> Solve that quadratic equation for y and then solve <br /> y= \frac{14}{g sin(\theta)}<br /> for \theta.
Do you get y=-11.2432 and y=-1.0611 after solving the quadratic equation? If so then I probably screwed up with the physics.
