Is there actually such thing as center of mass in polar coordinates?
The discussion revolves around the concept of center of mass in polar coordinates, comparing it to the established definitions in Cartesian coordinates. The original poster questions whether a similar formula exists for calculating the center of mass using polar coordinates, specifically focusing on the average values of "r" and "theta".
  • Participants explore the possibility of defining center of mass in polar coordinates and question whether integrals can yield average values for "r" and "theta". Some express uncertainty about the existence of such formulas, while others suggest that suitable substitutions in existing integrals might lead to the desired results.
The discussion is ongoing, with participants sharing their thoughts on the topic. Some express interest in the integrals that could provide the center of mass in polar coordinates, while others reflect on the relationship between Cartesian and polar representations. There is no explicit consensus, but various interpretations and approaches are being explored.
Participants note that some functions may be easier to work with in polar coordinates, and there is a reference to the derivation of area in polar coordinates, which may influence the discussion on center of mass.
flyingpig
Or any coordinates really. In the normal Cartesian plane, the center of mass is defined from the x, y , and z distance as follows
[tex]\bar{x} = \frac{1}{Area(R)}\iint_R x dA[/tex]
[tex]\bar{y} = \frac{1}{Area(R)}\iint_R y dA[/tex]
[tex]\bar{z} = \frac{1}{Area(R)}\iint_R z dA[/tex]
Now is there one for polar coordinates where you find the center of mass from the average "r" and "theta"?
[tex]\bar{r} = \frac{1}{Area(R)}\iint_R r dA[/tex]
[tex]\bar{\theta} = \frac{1}{Area(R)}\iint_R \theta dA[/tex]
I feel the derivation is going to be a bit lengthy and this really isn't as much of "HW", but just ponder.
In my Calculus book, although we do double integrals in polar coord and find the center of mass, we still stick to the cartesian coordinates.
Sure. Coordinates are just a way of identifying a point in the plane or space, or wherever. The center of mass could be at (1, 1) in rectangular (or Cartesian) coordinates, or at (sqrt(2), pi/4) in polar coordinates.
No, I mean as a formula.
Like if I give you [tex]f(r,\theta)[/tex], without converting, is there a way to find r and theta's center of mass?
As stated, this doesn't make any sense, but I think I understand what you're asking, which is, "Are there integrals that give r-bar and theta-bar?"
There might be, but I don't recall ever seeing any.
If you are given r = f(θ) then the answer is yes and no.:rolleyes:
You can certainly calculate the center of mass:
[tex]\overline x = \frac{\iint_R x\ dydx}{\iint_R 1\ dydx}= \frac{\iint_R r\cos\theta\ r dr d\theta}{\iint_R \ rdrd\theta}[/tex]
and similary for [itex]\overline y[/itex]. And you will get the r coordinate of the center of mass:
[tex]\overline r = \sqrt{\overline x^2+\overline y^2}[/tex]
But that doesn't give you the same as if you tried to use the first r moment to define the r value:
[tex]\overline r = \frac{\iint_r r\ rdrd\theta}{\iint_R rdrd\theta}[/tex]
You can find the formulas yourself by suitable substitution in integral for x-bar and y-bar. and using from both of them try to get separate integrals for r and theta
I am also interested in these integrals. Some functions are just easier to work with in polar coordinates. If I remember correctly, the integral used to find area is derived my summing up areas of infinitesimal sectors of a circle. The formula for area is
A=[itex]\frac{1}{2}[/itex] [itex]\int[/itex] f(θ)[itex]^{2}[/itex] dθ
[itex]\displaystyle \text{A}=\frac{1}{2}\int (f(\theta))^{2}\, d\theta[/itex]
That's true for a planar object whose boundary is defined by r = f(θ) .
  • · Replies 19 ·
