Is this alternating series convergent?
  • Thread starter Thread starter chesshaha
    Series
15 replies · 4K views
chesshaha
series converge?
DL the img, sry, can't type it.
http://www.geocities.com/chessobeyer/math.bmp
what's the sum if converge?
none.
alternating series, but it's (-2)
quasar987 said:
Are you saying it converges, or diverge?
I don't know where to start, I didn't know what test to use?
Can u give me a hint of which test to use?
Based on what you said, I assume that you already understood that the series can be rewritten as
[tex]\sum_{n=1}^{\infty}2(-1)^{n}[/tex]
I don't see which test can be used on this. But you can fall back on the very definition of convergence: A series converge if the sequence of the partial sums converge. But if you find two subsequences that converge to different values, then the sequence itself diverges. Can you find those subsequences?
thx, that helps a lot, so the alternating series?
Can u factor out the 2? r u sure that can be done?i don't understand
I got the series diverge, because the 2 cancels and it left with [tex]\sum_{n=1}^{\infty}(-1)^{n}[/tex]
is it right?
thx for ur help
Thanks for your help. But I still don't understand how can did u rewrite the series... to this [tex]\sum_{n=1}^{\infty}2(-1)^{n}[/tex]
Sorry, I am a bit of slow, Please Explain more, Thank You!
Ok, here is how.
[tex]\frac{(-2)^{n+1}}{2^n}=\frac{(-2)(-2)^n}{2^n}=(-2)\left(\frac{(-2)}{2}\right)^n=(-2)(-1)^n=2(-1)^{n+1}[/tex]
Thus,
[tex]\sum_{n=0}^{\infty}\frac{(-2)^{n+1}}{2^n}=\sum_{n=0}^{\infty}2(-1)^{n+1}=\sum_{n=1}^{\infty}2(-1)^{n}[/tex]
quasar987 said:
Ok, here is how.
Thus,
catching the bump up in the index is tricky. notice that the series now starts at n=1.
Thank you very much, this helps a lot.
So the series converge, the sum is either 0 or -2, depends if it's even or odd, right?
A series cannot converge to two limits. That sort of behavior is called 'divergent'.
Ahh I think a more appropriate word would have been is oscillating =]
Right. And the sum of i from i=0 to infinity could more accurately be said to 'increase without bound' rather than diverge. :smile:
