Is this condition for infinite roots wrong?
The discussion revolves around the interpretation of a theorem and method presented in Stroud's book "Engineering Mathematics" regarding polynomial equations and their infinite roots. Participants explore the validity of the theorem and the method for determining asymptotes, particularly in the context of high-degree polynomials.
  • One participant asserts that every polynomial equation will have two infinite roots at +infinity and -infinity, questioning the correctness of the theorem and method in the book.
  • Another participant argues that the claim does not make sense, stating that every polynomial has a largest power and thus an infinite number of infinite roots, while also noting that multiplying an equation by certain terms can lead to unmathematical solutions.
  • A third participant suggests that while the initial statement seems strange, it may have some correctness, indicating that the author may have misrepresented the method related to projective geometry and homogeneous coordinates.
  • One participant points out a potential issue with the statement regarding polynomial terms, specifically if the coefficients of the first two terms are zero.
Participants express differing views on the validity of the theorem and method, with no consensus reached on whether they are correct or incorrect. Multiple competing interpretations and models are presented.
The discussion highlights uncertainties regarding the assumptions made about polynomial behavior and the implications of the method described in the book, particularly in relation to high-degree polynomials and asymptotic behavior.
Readers interested in polynomial equations, asymptotic analysis, and projective geometry may find the discussion relevant.
vopros217
I found a strange theorem and a doubtful method in Stroud's book "Engineering mathematics":
I think, every polynomial equation will have two infinite roots (at +infinity and -infinity).
I also think that this method of the determination of an asymptote gives wrong results if f(x) is a polynomial with a high degree.
Are the theorem and the method in this book wrong?
Mathematics news on Phys.org
That doesn't make sense. Every polynomial has a largest power, so every polynomial has an infinite number of infinite roots?
Multiplying the equation by yn generates additional solutions for y=0, so it is not surprising that they produce unmathematical solutions for y=0 later. Of course y=0 is a solution to an equation where you multiplied both sides by 0.
This looks strange but it is kind of correct. It seems the author absolutely butchered the method though. I think what the author likes to do is to compute infinite point and asymptotes in projective geometry using homogeneous coordinates. That uses a method kind of similar to what is in the OP, but the exact explanation of the book is very doubtful.
Something of the following would be correct though: consider ##y = \frac{x+2}{3x + 2}##. Then we have
$$3xy + 2y - x - 2 = 0$$
which gives rise to a homogeneous equation
$$3xy + 2yz - xz - 2z^2=0.$$
The points at infinity correspond to ##z=0##, which yields ##x=0## or ##y=0##. This gives us a result that the function has two asymptotes: one parallel to ##x=0## and one parallel to ##y=0## which is indeed correct.
Statement is strange. if [itex]a_0\ and\ a_1[/itex] are both 0, then the first term should be [itex]a_2x^{n-2}[/itex].
Thank you all. Stroud's textbook is mostly very good, but I stuck on that place.
  • · Replies 43 ·
