Is this derivative in terms of tensors correct?
The discussion revolves around the differentiation of a scalar function involving a constant vector and an inner product, specifically the expression $$\frac{\partial}{\partial x^{\nu}}\frac{3}{(q.x)^3}$$ where q is a constant vector. The problem is situated within the context of tensor calculus and differential geometry.
  • Participants explore the validity of the original poster's differentiation steps and question the handling of indices in the inner product. Some suggest checking the result with specific examples, while others raise concerns about the assumptions made regarding the metric tensor.
The discussion is ongoing, with participants providing feedback on the original poster's calculations and assumptions. There is a focus on clarifying the use of the metric tensor and its implications for the problem. Multiple interpretations of the problem are being explored, particularly regarding the inner product and the differentiation process.
Participants note the importance of correctly identifying free and dummy indices in tensor notation. There is also mention of the metric tensor's role in the calculations, with discussions about its form in different coordinate systems, such as Cartesian versus polar coordinates.
TimeRip496
Solve this, $$\frac{\partial}{\partial x^{\nu}}\frac{3}{(q.x)^3}$$
$$\frac{\partial}{\partial x^{\nu}}\frac{3}{(q.x)^3}=3\frac{\partial(q.x)^{-3}}{\partial (q.x)}*\frac{\partial (q.x)}{\partial x^{\nu}} \\ =\frac{-9}{(g^{\mu \nu}q_\mu x_\nu)^4}[g^{\mu \nu}[q_{\mu,\nu}x_{\nu}+q_{\mu}x_{\nu,\nu}]] \\ =\frac{-9}{(g^{\mu \nu}q_\mu x_\nu)^4}[g^{\mu \nu}[0+q_{\mu}x_{\nu,\nu}]] \\ =\frac{-9}{(g^{\mu \nu}q_\mu x_\nu)^4}[[q_{\mu}\delta^\mu _\nu]]\\ =\frac{-9}{(g^{\mu \nu}q_\mu x_\nu)^4}q_{\nu}$$
Is this correct? Besides is there an easier or faster way to solve this? Or can it be reduce further to lesser terms?
Did you think of checking with an example? When you say reduced further, you have left the answer with the expanded form of the inner product.
Note that you have ##\nu## as the free index, so you can't use this for a dummy index in your inner product. You should see that's wrong as you have three ##\nu##'s in the same term.
Sorry about the inner product. I just want confirm the validity of my answer.
$$\frac{-9}{(q.x)^4}q_{\nu}$$
$$\frac{-9}{(g^{q.x)^4}q_{\nu}$$
It's not right.
PeroK said:
It's not right.
I don't get why my answer is not right. Even when I reduced it to a normal derivative of x, I will get the same result.
$$\frac{\partial}{\partial x}\frac{3}{(qx)^3}=\frac{-9}{(q x)^4}q$$
Do you know any examples where the metric tensor is not ##\eta^{\mu \nu}##?
No unless is curved spacetime. Correcting for the ημν and v,
$$\frac{\partial}{\partial x^{\nu}}\frac{3}{(q.x)^3}=3\frac{\partial(q.x)^{-3}}{\partial (q.x)}*\frac{\partial (q.x)}{\partial x^{\nu}} \\ =\frac{-9}{(\eta^{\mu \kappa}q_\mu x_\kappa)^4}[\eta^{\mu \kappa}[q_{\mu,\nu}x_{\kappa}+q_{\mu}x_{\kappa,\nu}]] \\ =\frac{-9}{(\eta^{\mu \kappa}q_\mu x_\kappa)^4}[\eta^{\mu \kappa}[0+q_{\mu}x_{\kappa,\nu}]] \\ =\frac{-9}{(\eta^{\mu \kappa}q_\mu x_\kappa)^4}[[q_{\mu}\delta^\mu _\nu]]\\ =\frac{-9}{(\eta^{\mu \kappa}q_\mu x_\nu)^4}q_{\nu}\\=\frac{-9}{(q.x)^4}q_{\nu}$$
$$\frac{\partial}{\partial x^{\nu}}\frac{3}{(q.x)^3}=3\frac{\partial(q.x)^{-3}}{\partial (q.x)}*\frac{\partial (q.x)}{\partial x^{\nu}} \\ =\frac{-9}{(\eta^{\mu \kappa}q_\mu x_\kappa)^4}[\eta^{\mu \kappa}[q_{\mu,\nu}x_{\kappa}+q_{\mu}x_{\kappa,\nu}]] \\ =\frac{-9}{(\eta^{\mu \kappa}q_\mu x_\kappa)^4}[\eta^{\mu \kappa}[0+q_{\mu}x_{\kappa,\nu}]] \\ =\frac{-9}{(\eta^{\mu \kappa}q_\mu x_\kappa)^4}[[q^{\nu}\delta^\mu _\nu]]\\ =\frac{-9}{(\eta^{\mu \kappa}q_\mu x_\nu)^4}q_{\nu}\\=\frac{-9}{(q.x)^4}q_{\nu}$$
The metric tensor (in flat spacetime) is ##\eta^{\mu \nu}## when you have Cartesian coordinates. You could try polar coordinates in 2D (flat) space, where the metric tensor is not ##\eta^{\mu \nu}##.
In general, 2D polar coordinates are the simplest example to use when you want to check something like this. Note, however, that they still have a diagonal metric. So, your other option is just to make one up. For example:
##a \cdot b = a_1b_1 + 2a_2b_2 + 3a_1b_2 + 3a_2b_1##
Also, your problem hinges on the derivative of the inner product wrt ##x^{\nu}## so you can just focus on that:
When you mean check answer, do you mean something like this?
E.g.
$$q=(a\ \ \ \ \ b)\\ x=(x_1\ \ \ \ \ x_2)$$
$$\partial_\nu \frac{3}{(ax_1+bx_2)^{3}}=\begin{pmatrix}-9a(ax_1+bx_2)^{-4}\\-9b(ax_1+bx_2)^{-4}\end{pmatrix} \\=\frac{-9}{(ax_1+bx_2)^{4}}q_\nu \\=\frac{-9}{(q.x)^{4}}q_\nu$$
And how does the metric tensor fit into the checking here? Is it used to check the validity of the intermediate steps here?
E.g.
I think you have several conceptual problems here. First, I better check. You used a general form of the inner product in your OP that used a general metric tensor ##g^{\mu \nu}##. Did you really mean that? Or, are you assuming that ##g^{\mu \nu} = diag(1, 1, 1)##?
PS note that ##\eta^{\mu \nu} = diag(-1, 1, 1, 1)##. So, even with that as the metric the answer is not correct.
Is ##q\cdot x = q_\mu x^\mu##? If so, an elementary differentiation process gives
$$\frac{\partial}{\partial x^\nu} \frac{3}{(q \cdot x)^3} = -\frac{9}{(q \cdot x)^4} q_\nu$$ with essentially no work.
My mistake because I did assume that ##g^{\mu \nu} = diag(1, 1, 1)## which shouldn't be the case.
$$\frac{\partial}{\partial x^{\nu}}\frac{3}{(q.x)^3}=3\frac{\partial(q.x)^{-3}}{\partial (q.x)}*\frac{\partial (q.x)}{\partial x^{\nu}} \\ =\frac{-9}{(\eta_{\mu \kappa}q^\mu x^\kappa)^4}[\eta_{\mu \kappa}[q^{\mu}_{,\nu}x^{\kappa}+q^{\mu}x^{\kappa}_{,\nu}]] \\ =\frac{-9}{(\eta_{\mu \kappa}q^\mu x^\kappa)^4}[\eta_{\mu \kappa}[0+q^{\mu}x^{\kappa}_{,\nu}]] \\ =\frac{-9}{(\eta_{\mu \kappa}q^\mu x^\kappa)^4}[\eta_{\mu \kappa}[q^{\mu}\delta^\kappa _\nu]]\\ =\frac{-9}{(\eta_{\mu \kappa}q^\mu x^\kappa)^4}[\eta_{\mu \nu}q^{\mu}]\\=\frac{-9}{(\eta_{\mu \kappa}q^\mu x^\kappa)^4}q_{\nu}$$
where qv=[-q1 q2 q3 ...]
However, what do you mean by this? Why won't that metric work?
where qv=[-q1 q2 q3 ...]However, what do you mean by this? Why won't that metric work?
In #11, if ##q \cdot x = \eta_{\mu \nu} q^\mu x^\nu## we can write it as ##q \cdot x = q_\nu x^\nu,## where ##q_\nu = \eta_{\mu \nu} q^\mu.## So we just have ##q \cdot x = q_1 x^1 + q_2 x^2 + \cdots + q_n x^n##, irrespective of the exact form of the metric ##\eta_{\mu \nu}.##
How do I then ensure that the property of metric tensor is expressed in the equation then? Do I leave the metric tensor and the contravariant vector as separate then?
Sorry, I think I misled you. I didn't understand why you were not differentiating the tensor components and how you got rid of them. I didn't notice, I must admit, that you had the correct answer all along. Sorry for that.
I thought that if you used an example metric that depended on the coordinates (like polar coordinates) you would see that you have to differentiate the metric components as well.
In any case, @Ray Vickson has given you the best approach.
Okay thanks for the help!
  • · Replies 38 ·
