Is this line integral correct?
29 replies · 3K views
Jamin2112
C1(0) dz / (z * sin2(z))
Residue Theorem material
z * sin2(z)
= z * (1/2 - cos(2z)/2)
= z * [1/2 - (1/2)∑(-1)n(2z)n/(2n)! ]
= z3 + ...
---> z * sin2(z) has a zero of order 3 at z = 0
---> 1/(z * sin2(z)) has a pole of order 3 at z = 0
The circle C1(0) encloses z = 0 (its only singularity), so we have
2πi * Res[f, 0] = 2πi * 1/(3-1)! * limz-->0 d2/dz2 (z-0)3 1/(z * sin2(z)),
which I don't want to calculate if there's an easier way to do the problem. Is there an easier way? I'm too cool for calculating double derivatives.
z * sin2(z)
= z3 + ...
You could expand it in a Laurent series around z=0 and look for the coefficient of the 1/z term if you are so dead set against finding derivatives.
Ah, I see! So perform long division using the series from the trig identity I invoked?
Factor out all of the z's like you did so you should be left with something like z^3*(1-g(z)). Then use the expansion 1/(1-g(z))=1+g(z)+g(z)^2+... Remember?
I got 1/3. That seem legit?
Dick said:
That's what I got. Not sure it makes it legit.
Awesome, brah. Now let's look at ∫C f(z), where f(z) = dz/(z-1)2(z2+4) and C = C4(0). The integrand clearly has 3 singularities, all of which lie inside C. They are z = 1, which has order 1; z = 2i, which has order 2; and z = -2i, which has order 2. The residue is therefore
2πi * (Res[f, 1] + Res[f, 2i], Res[f, -2i]).​
But hang on a sec, brah. For Res[f, 1] I got limz-->1 (z-1) * 1/(z-1)2(z2+4) = ∞. Wat do?
The pole at z=1 has order 2. The other two have order 1. Why do you think otherwise?
Let me redeem myself. To find the order of the pole z=1, I need to write (z-1)2(z2+4) in the form ∑an(z-1)n. Is this supposed to be incredibly obvious? I can't figure it out.
No. You are supposed to write f(z)=g(z)/(z-1)^n where is g(z) is analytic in a neighborhood of z=1 and g(1) is not zero. What are n and g(z)? Yes, it's supposed to be pretty obvious.
Dick said:
[...] where is g(z) is analytic in a neighborhood of z=1 [...]
A punctured neighborhood of z=1?
You must be referring to g(z) = 1/(z2+4), n = 2.
Dick said:
Sure. Pole of order 2.
Ah, I understand the reasoning now.
Since g(z) = 1/(z2+4) is analytic in a neighborhood about z=1, it will equal some power series centered at z=1:
g(z) = ∑an(z-1)n.​
Thus
g(z)/(z-1)2
= (z-1)-2 (a0 + a1(z-1) + a2(z-2)2 + ...)
= a0/(z-1)2 + ...
Thus f(z) = g(z)/(z-1)2 has a finite number of terms of the form a-k/(z-1)k (with k>0), the first of them being being k = 2. Is that basically right?
g(z) = ∑an(z-1)n.​
Thus
g(z)/(z-1)2
= a0/(z-1)2 + ...
Sure. The point is near z=1 f(z) behaves like a0/(z-1)^2 plus small corrections.
Sweet deal. (Maybe I should actually buy the textbook and stop sleeping in class.)
I have another question, though. (See this as an opportunity to become an even higher contributor to the homework help sub-forum.)
Am I correct that z-2csc(z) has a pole of order 3 at z=0?
For z2sin(z)
= z2(z - z3/3! + z5/5! - z7/7! + z9/9! + ...)
= z3 - z5/3! + ...
undeniably has a zero of order 3 at z=0.
And in that case,
Res[z-2csc(z)] = 1/(2-1)! limz-->0 ((z3 * z-2csc(z))'' = limz-->0 (z*sin2(z) - 2cos(z)sin(z) + 2z*cos2(z))/sin3(z) ??
For z2sin(z)
= z3 - z5/3! + ...
undeniably has a zero of order 3 at z=0.And in that case,
Sure again. Now you can either use l'Hopital on the trig stuff to find the limit, or you can use the Laurent series trick like in the first problem.
Sweet deal. Again, how do I solve z6+1=0?
I tried this:
z6+1=0 <---> (z3+i)(z3-i)=0
z3+i
= (x+iy)3+i = 0
<---> (x2+2xyi - y2)(x+iy) + i = (x3 - 3xy2) + i * (3x2y - y3 + 1) = 0
<---> x2 = 3y2; 3x2y - y3 = -1
<---> y = (1/8)-1/3 = -1/2
So two of our zeroes are √3/2 -1/2 * i and -√3/2 - 1/2 * i
Ditto for (z3-i)=0? amidoinitrite?
I tried this:
z3+i
= (x+iy)3+i = 0
Now can't you think of a simpler way to do it than that? You are trying to find the six sixth roots of -1. Try using polar form r*exp(i*theta).
(re)6 = -1
<---> r6cos(6ø) + r6isin(6ø) = -1.
<---> r6cos(6ø) = -1; r6isin(6ø) = 0
That right so far?
Jamin2112 said:
(re)6 = -1
That right so far?
Still too hard. (r*e^(iø))^6=r^6*e^(6iø). r must be 1. Now express (-1) in polar form.
cos(6ø)+isin(6ø)= -1
---> cos(6ø) = -1
---> 6ø = (2k+1)π
---> ø = (2k+1)π/6 =π/6, π/2, -π/6, -π/2, 7π/6, -7π/6, ... (everything after the "..." is redundant)
---> cos(6ø) = -1
---> 6ø = (2k+1)π
Yes. This is review for you, isn't it?
This is me catching up after slacking last quarter.
Dick said:
I think buying the textbook and not sleeping in class are really good ideas.
Question: Do you think it's a good idea to drink a few beers to get a good buzz going before an exam? It helps one not second-guess himself when writing down answers.
If you've done all your homework, bought the textbook and not snoozed through all you classes, it MIGHT not hurt you that much. If you haven't, well, you are probably dead in the water anyway and hoping everybody else sucks more than you do. No. I don't think it's a good strategy. Do the beers after the exam. You'll enjoy the buzz more. So we're done with complex analysis then?
Almost. This problem has been ticking me off. I've checked my work several times.
Using residues, I'm supposed to find the partial fractional representation of (z2-7z+4)/(z2(z+4)).
I have it on good word that
(z2-7z+4)/(z2(z+4)) = A/z2 + B/z + C/(z+4),
where
A = Res[(z-0)*f, 0],
B = Res[f, 0],
C = Res[f, -4].
Thus
A= limz-->0 d/dz (z-0)*(z-0)2(z2-7z+4)/(z2(z+4),
B = limz-->0 d/dz (z-0)2(z2-7z+4)/(z2(z+4)),
C = limz-->4 (z+4)(z2-7z+4)/(z2(z+4)).Right?
where
B = Res[f, 0],
C = Res[f, -4].
Thus
I'm getting tired. What part of that are you having a problem with? Can you be specific? Since you haven't shown your work, what part isn't checking?
