Is This Perpetual Motion Machine Really Possible?
13 replies · 4K views
tribdog
I just read about a new perpetual motion machine and it looks like it will work. You take a cat and tie a piece of toast on to its back. then you butter the toast and toss the cat into the air. Since the toast has to land butter side down and the cat always lands on its feet it spins forever.
When the cat hits the ground the toast hasn't really landed. Thus once again confirming that the laws of physics do hold!
That theory about toast always landing butter side down is just a myth. The chances of landing butter side down depend on the ratio between table height and toast length.
For a standard 5" piece of toast, the chances of landing butter side down is only better than 50% if the table is between 12 inches high and 110 inches high (approximately). The chances are better than 90% between 30 inches high and 70 inches high.
If you use a larger piece of toast, say a 12" piece of toast, the chances of landing butter side down are better than 50% when the table height is between 30 inches high and, uh, really high. The chances of landing butter side down are better than 90% when the table height is between 75 inches high and 170 inches high.
And, naturally, that assumes a perfect landing surface that will absorb virtually all of the bounce. The worse the landing surface, the more likely you are to get a lucky bounce and have the bread land butter side up.
Would it help if the cat was tossed onto a trampoline??:biggrin:
http://uncyclopedia.org/wiki/Cat-Toast_Device
Well at least the laws of statistics are broken, given that the cat always hits the ground instead of butter. I think we have an infinite improbability drive here, not a perpetual motion machine.
The link in that article details experimentation on toast droppings: http://cockeyed.com/science/toast/toast1.html. They're bad at math (2/20 is a 10% survival rate, not a 5% survival rate), but that might just be a side effect of sticking a knife in the toaster to free a stuck piece of toast. I don't think Brooke paid enough attention to making the sure the plate was always at the same angle, either. A better test would have been to slowly push the toast towards the edge of the table until its center of gravity was just beyond the table edge. I think that would have gotten more consistent results.
All in all, I'm not even sure they're scientists.
I've never dropped a piece of toast off of a table. I don't even know how that's possible. I've only dropped it out of my hand either because it is too hot, in which case I haven't buttered it yet, or when I was in the process of buttering it.
Personally, I avoid those problems by buttering and spreading jam on the bread before inserting it into the toaster. It's a good toaster, too, except the side with the butter and jam tends to stick to the ceiling.
There must be an exception to the rule here, if one is holding the toast and it breaks i sure 9 times out 10 it will fall butter side down.
It's the bounce that gives the buttered side the advantage. If the dry side hits first, you get a bounce to flip it to the buttered side. If the buttered side hits first, it'll stick to the floor and reduce the chances of bounce to negligible.
Okay, I just tried to perform the experiment. Unfortunately, this cat rather likes the toast and won't cooperate as needed. Now she's in a temporary state of perpetual licking.
Thank God for that, they forgot to mention that if the theory is true then the buttercat will turn into a black-hole.
