Is this Vector-set Linear dependent?
  • Thread starter Thread starter NorwegianStud
    Linear
The discussion centers on determining whether a given set of vectors is linearly dependent. It is suggested that if the number of vectors exceeds the dimensions, the set is linearly dependent. The concept of linear independence is clarified, stating that a set of n independent vectors defines an n-dimensional vector space. Consequently, if three vectors are independent, any fourth vector must be expressible as a linear combination of them. The conclusion drawn is that the provided vector set is indeed linearly dependent.
NorwegianStud
-1 1 2
0 8 4
4 2 0
v1= {1, -1, 0} and so on.
Is it linear dependent?
I think it is, since I read somewhere that if the Vector have less dimensions than it have vectors in the set then it's linear dependent. Or is it? I'm a bit confused.
Yes. Are you aware that a set n of linearly independent vectors define a n dimensional vector space? That is, if you have 3 independent vectors, you can build any other 3d vector from them. If some 4 vectors are independent, than any 3 must be independent too. This follows from the definition of independence. If 3 vectors are linearly independent then the fourth must be a linear product of them.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
