Is wave a physical object or its just a model?
  • Context: High School
  • Thread starter Thread starter LSMOG
    Model Physical Wave
12 replies · 2K views
LSMOG
Have you ever surfed?
A physical wave is a physical wave and a model of a wave is a model of a wave.
This is an open question. To quote from Franck Laloë's Do we really understand quantum mechanics? Strange correlations, paradoxes and theorems:
To what extent should we consider that the wave function describes a physical system itself (realistic interpretation), or rather that it contains only the information that we may have on it (positivistic interpretation), presumably in some sense that is more subtle than a classical distribution function? This is not an easy question, and various authors answer the question with different nuances;
Having trouble seeing how a wave function can be interpreted as a physical thing...it implies too many exotic attributes. By Occam's razor it is more efficient to discard a wave function as a physical object, IMO.
If we say " the electron is a wave" does this mean an electron is traveling up and down like water?
No it does not mean that.
The electron is neither a wave nor a particle, it is a quantum object that displays wave-like or particle-like behaviour depending on context.
The position and momentum is described by a probabilistic function, which takes the form of a complex wave equation.
No "we" are saying that in the context of specific physical systems a wave function can be defined such that when specific operations are applied to it we get a range of values that describe the electron's behaviour that can be verified experimentally.
That's what "we" are saying... but I don't want to speak for other people so "we" is just "me".
houlahound said:
No
In a wave, let's say a string, we can measure the wavelength to be the distance between the two troughs. Then which points in an electron can we use to measure the trough if it is a wave?
Diffraction of electrons yields their wavelength. Just as in light.
You have seen electron microscope images?
Before thinking about an electron, you might want to analyse your example of a wave in a string. What is the wave as a "physical object" in this case? The string is physically a row of particles and each particle is moving up and down with simple harmonic motion, out of synchronisation with each other, such that particles a certain fixed distance apart are in synchronisation. Now, where and what is your wave physically in this case? You appear to have a sinusoidal wave propagating along the string, but is that really a "physical" thing or just an illusion caused by the vertical motion of each particle?
If you simulated a wave by, say, having sets of vertical lights in a long horizontal row and had the lights go on and off in a certain pattern, then you would see a wave appear to propagate. Is this still a physical wave or a simulation?
In other words, what actually is a wave physically?
Context.
