Isomorphism from <R,+> to <R+,\times>: Proving 1-1 and Onto Function
  • Thread starter Thread starter LMKIYHAQ
    Isomorphism
LMKIYHAQ
Is there an isomorphism from <R,+> to <R+,\times> where \phi(r)=0.5^{r} when r \in R?
2. Homework Equations
For an isomorphism I know it is necessary to show there is a 1-1 and onto function. I am unsure if I can use the steps I am trying to use to show it is 1-1.
For phi(r)=phi(s) I want to show r=s. Am I able to take the ln (or log?) of both sides to get ln(.05^{r})=ln(0.5^{s})? I am not sure which to use (ln or log) and where these logarithmic functions would be defined since for r=s, r and s are supposed to be real numbers.
Thanks for the help.
Maybe try rewriting 0.5^r=0.5^s as 2^r=2^s. This may make things cleaner.
I don't know how to make that change?
Even if that way does clean it up, is my way of taking ln of both sides wrong?
Sure, just use logs. (0.5)^r=(0.5)^s iff r*log(0.5)=s*log(0.5). That shows it 1-1. Is it onto? But 1-1 and onto doesn't make it an isomorphism. You have to prove things like phi(r+s)=phi(r)*phi(s), right?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
