Issue with math in physics problem?
  • Thread starter Thread starter fightboy
    Physics
The discussion revolves around a physics problem where the user is confused about simplifying an equation presented in the solutions manual. The key issue is the transition from one expression to another, specifically how (2/3mdebrisRE2) simplifies to (5/3mdebris). Clarification is provided that the initial fraction (2/5mERE2)/(2/5mERE2) equals 1, and the ambiguity in the fractions is acknowledged. The user learns that by adding parentheses, the R_E^2 terms cancel, allowing for further simplification. The explanation concludes that the manual's steps are valid when correctly interpreted.
fightboy
Ok so for the problem I'm mainly having trouble with setting up one of the equations.
The solutions manual jumped from:
ωiz([(2/5mERE2)/(2/5mERE2) + (2/3mdebrisRE2)]-1)
to:
ωiz([mE/(mE + (5/3mdebris))]-1)
I placed the brackets to clearly separate the fraction from the -1. Anyways I'm having trouble seeing how the math is done to get from the first equation to the second equation, how was it simplified? If anyone is confused on how i wrote the problem please just ask! Thanks!
Mathematics news on Phys.org
to:
These aren't equations - they are expressions.
Inside the parentheses you have (2/5mERE2)/(2/5mERE2), which is just 1.
The fractions you wrote are ambiguous, which doesn't change what I wrote above.
Is the numerator ##\frac{2}{5}m_ER_E^2##
or is it ##\frac{2}{5m_ER_E^2}##?
The numerator is ##\frac{2}{5}m_ER_E^2##. I get that ##\frac{2}{5}m_ER_E^2##/##\frac{2}{5}m_ER_E^2## is equal to 1, I am mainly confused on how (2/3mdebrisRE2) became (5/3mdebris) or if the manual made a mistake.
If you put an extra set of parentheses in the original expression, the ##R_E^2##s cancel and you can multiply everything by ##\frac{5}{2}## to get $$\frac{\frac{2}{5}m_ER_E^2}{\frac{2}{5}m_ER_E^2+\frac{2}{3}m_{\text{debris}} R_E^2}=\frac{m_E}{m_E+\frac{5}{3}m_{\text{debris}}}$$
Likes 1 person
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
