MHB Jamie's question at Yahoo Answers regarding an indefinite integral
The discussion focuses on integrating the function (3x + 2)/(x^2 + 3x + 1) dx using different methods. One approach involves partial fraction decomposition, where the integrand is expressed in terms of its roots derived from the quadratic formula. Another method utilizes substitution, transforming the integral into a more manageable form. Both methods ultimately lead to the same result, showcasing the versatility of integration techniques. The final integral expressions highlight the importance of logarithmic and hyperbolic functions in solving such problems.
MarkFL
MHB
Here is the question:
Integrate (3x + 2)/(x^2+3x+1) dx?
Please tell me the name of the way you did it, for ex. Start with integration by parts, or substitution.
I got to the Integral of 1-(3u+2)/(u^2+3u+1)du where u = tanx
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Jamie,
We are given to evaluate:
$$I=\int\frac{3x+2}{x^2+3x+1}\,dx$$
I would look at the partial fraction decomposition of the integrand. Application of the quadratic formula gives us the roots of the denominator as:
$$x=\frac{-3\pm\sqrt{5}}{2}$$
Hence, we may state:
$$x^2+3x+1=\frac{1}{4}\left(2x+3-\sqrt{5} \right)\left(2x+3+\sqrt{5} \right)$$
And so the integrand may be expressed as:
$$\frac{4(3x+2)}{\left(2x+3-\sqrt{5} \right)\left(2x+3+\sqrt{5} \right)}$$
Thus, we may assume the partial fraction of this integrand will take the form:
$$\frac{4(3x+2)}{\left(2x+3-\sqrt{5} \right)\left(2x+3+\sqrt{5} \right)}=\frac{A}{2x+3-\sqrt{5}}+\frac{B}{2x+3+\sqrt{5}}$$
Using the Heaviside cover-up method, we find:
$$A=\frac{4\left(3\left(\dfrac{-3+\sqrt{5}}{2} \right)+2 \right)}{2\left(\dfrac{-3+\sqrt{5}}{2} \right)+3+\sqrt{5}}=3-\sqrt{5}$$
$$B=\frac{4\left(3\left(\dfrac{-3-\sqrt{5}}{2} \right)+2 \right)}{2\left(\dfrac{-3-\sqrt{5}}{2} \right)+3-\sqrt{5}}=3+\sqrt{5}$$
And so we find:
$$\frac{4(3x+2)}{\left(2x+3-\sqrt{5} \right)\left(2x+3+\sqrt{5} \right)}=\frac{3-\sqrt{5}}{2x+3-\sqrt{5}}+\frac{3+\sqrt{5}}{2x+3+\sqrt{5}}$$
And we may now state:
$$I=\frac{3-\sqrt{5}}{2}\int\frac{2}{2x+3-\sqrt{5}}\,dx+\frac{3+\sqrt{5}}{2}\int\frac{2}{2x+3+\sqrt{5}}\,dx$$
Using the integration rule:
$$\int\frac{du}{u+a}\,du=\ln|u+a|+C$$
we find:
$$I=\frac{3-\sqrt{5}}{2}\ln|2x+3-\sqrt{5}|+\frac{3+\sqrt{5}}{2}\ln|2x+3+\sqrt{5}|+C$$
$$I=\frac{1}{2}\left((3-\sqrt{5})\ln|2x+3-\sqrt{5}|+(3+\sqrt{5})\ln|2x+3+\sqrt{5}| \right)+C$$
And in conclusion, we may now state:
$$\int\frac{3x+2}{x^2+3x+1}\,dx=\frac{1}{2}\left((3-\sqrt{5})\ln|2x+3-\sqrt{5}|+(3+\sqrt{5})\ln|2x+3+\sqrt{5}| \right)+C$$
When I look at integration problems, the first thing I always look for are simple substitutions...
$\displaystyle \begin{align*} \int{\frac{3x + 2}{x^2 + 3x + 1}\,dx} &= 3\int{\frac{x + \frac{2}{3}}{x^2 + 3x + 1} \, dx} \\ &= \frac{3}{2} \int{ \frac{2x + \frac{4}{3}}{x^2 + 3x + 1} \, dx } \\ &= \frac{3}{2} \int{\frac{2x + 3 - \frac{5}{3}}{x^2 + 3x + 1}\,dx} \\ &= \frac{3}{2} \int{ \frac{2x + 3}{x^2 + 3x + 1}\,dx } - \frac{3}{2}\int{\frac{\frac{5}{3}}{x^2 + 3x + 1} \, dx} \\ &= \frac{3}{2} \int{ \frac{2x + 3}{x^2 + 3x + 1}\, dx} - \frac{5}{2} \int{ \frac{1}{x^2 + 3x + \left( \frac{3}{2} \right) ^2 - \left( \frac{3}{2} \right) ^2 + 1 } \, dx} \\ &= \frac{3}{2} \int{ \frac{2x + 3}{x^2 + 3x + 1} \, dx} - \frac{5}{2} \int{ \frac{1}{ \left( x + \frac{3}{2} \right) ^2 - \frac{5}{4} } \, dx} \end{align*}$
Now making the substitutions $\displaystyle \begin{align*} u = x^2 + 3x + 1 \implies du = \left( 2x + 3 \right) \, dx \end{align*}$ and $\displaystyle \begin{align*} x + \frac{3}{2} = \frac{\sqrt{5}}{2}\cosh{(t)} \implies dx = \frac{\sqrt{5}}{2}\sinh{(t)}\,dt \end{align*}$ and we get
$\displaystyle \begin{align*} \frac{3}{2} \int{ \frac{2x + 3}{x^2 + 3x + 1} \, dx} - \frac{5}{2} \int{ \frac{1}{ \left( x + \frac{3}{2} \right) ^2 - \frac{5}{4} } \, dx} &= \frac{3}{2} \int{ \frac{1}{u}\,du } - \frac{5}{4} \int{ \frac{1}{\left[ \frac{\sqrt{5}}{2} \cosh{(t)} \right] ^2 - \frac{5}{4}} \, \frac{\sqrt{5}}{2}\sinh{(t)}\,dt } \\ &= \frac{3}{2} \ln{|u|} - \frac{5\sqrt{5}}{8} \int{ \frac{\sinh{(t)}}{\frac{5}{4} \left[ \cosh^2{(t)} - 1 \right]}\,dt } \\ &= \frac{3}{2} \ln{ \left| x^2 + 3x + 1 \right| } - \frac{\sqrt{5}}{2}\int{ \frac{\sinh{(t)}}{\sinh{(t)}}\,dt } \\ &= \frac{3}{2}\ln{ \left| x^2 + 3x + 1 \right| } - \frac{\sqrt{5}}{2} \int{ 1 \, dt} \\ &= \frac{3}{2} \ln{ \left| x^2 + 3x + 1 \right| } - \frac{\sqrt{5}}{2} t + C \\ &= \frac{3}{2} \ln{ \left| x^2 + 3x + 1 \right| } - \frac{\sqrt{5}}{2} \,\textrm{arcosh}\, { \left[ \frac{\sqrt{5} \, \left( 2x + 3 \right) }{5} \right] } + C \end{align*}$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
