'Jet' engine with positive displacement compressor?
- Thread starter NateTG
- Start date
10 replies · 5K views · last reply
- Air holes turn silicon wafers into flat ultraviolet focusing mirrors for compact optics
- Quantum gas microscope reveals individual atoms in first tunable three-component Hubbard system
- Scientists achieve record-breaking low temperature on China's space station, paving the way for new physics experiments
Discussion
- 11
You know, I vauguely remember a paper detailing an engine concept that did have a piston on top of an axial compressor. IIRC believe the compression was supplemental. Let me see if I can hunt it down.
Homework Helper
- 2,449
- 7
FredGarvin said:You know, I vauguely remember a paper detailing an engine concept that did have a piston on top of an axial compressor. IIRC believe the compression was supplemental. Let me see if I can hunt it down.
I was actually wondering about something similar to turbo-fans, but with positive displacement. Still, that sounds zany.
- 11
It was on a turbo jet IIRC. I still haven't found it. Still looking.NateTG said:I was actually wondering about something similar to turbo-fans, but with positive displacement. Still, that sounds zany.
EDIT: Now I recall what the heck I was thinking about. It had to do with free piston topping for turbines. I have a paper from the 2003 ASME Turbine expo on the topic, but it is copyrighted. Try doing a search on it and see what you can come up with. It's not what you were looking for, but it's kind of in the ball park.
Homework Helper
- 2,449
- 7
FredGarvin said:Try doing a search on it and see what you can come up with. It's not what you were looking for, but it's kind of in the ball park.
Yeah, I was wondering if anyone had, for example stuck together a screw compressor, combustion chamber, and screw expander as a power plant.
Thanks for the response though.
Danger
- 251
Jeez, Nate... I thought that you were just asking about the intake side. A positive displacement output? I wouldn't want to be anywhere near it. I've seen a Funny Car shell its blower. Even with pop-off valves, it's not a pretty sight. I'd want an unobstructed exit for that combustion chamber.
I've seen quite a few 'turbojets' made out of surplus turbochargers, but that's about it.
Homework Helper
- 2,449
- 7
Danger said:Jeez, Nate... I thought that you were just asking about the intake side. A positive displacement output? I wouldn't want to be anywhere near it.
I don't understand why. Piston engines, for example, have positive displacement output in that sense.
- 42
Hi Nate, I've always been amazed at what's been patented. I was saying to myself, "I've never heard of such a machine, though I can't think of any reason why not." So I checked. Sure enough, this one looks pretty close to what you suggested (screw compressor, screw expander).
http://www1.uspto.gov/web/patents/patog/week06/OG/html/1303-1/US06993897-20060207.html
I suspect there are quite a few of these designs out there. A quick Google search turns up a lot of hits.
Hey Fred - New avatar? Which one is Fred?
Danger
- 251
That thing would be a hell of a lot easier to understand if I could get it all on the screen at the same time. Also, I'm not used to reading flow diagrams instead of blueprints. Looks sensible enough, if perhaps overly elaborate.
I guess that my objection might be more intuitive than based upon actual engineering principles. It's hard for me to envision a Roots-type blower, which is what I was thinking of, being easily reversible (like a worm gear set-up). Based upon the airflow through one, it seems that it would develop a lot of pressure internally as opposed to something that takes the flow axially. I suspect that the side-load on the rotor bearings must be incredible.
Thanks for the link, Q. Maybe if I print it out and get to look at the picture and text at the same time, it'll be easier to tell what's going on in it.
- 11
Yeah. It's a new one. I need to change things around every once in a while. That's Lou and Andy from Little Britain. The best skit show EVER.Q_Goest said:Hey Fred - New avatar? Which one is Fred?![]()
- Stormer
- · Replies 10 ·
- Mechanical Engineering
- Replies
- 10
- TheRedDevil18
- · Replies 7 ·
- Replies
- 7
- steves1080
- · Replies 4 ·
- Replies
- 4
- orb_yt
- · Replies 20 ·
- Replies
- 20
- metameta
- · Replies 4 ·
- Replies
- 4
- obliqueweapons
- · Replies 2 ·
- Replies
- 2
- FreeBob
- · Replies 7 ·
- Replies
- 7
- hagar
- · Replies 2 ·
- Replies
- 2
- JD_PM
- · Replies 2 ·
- Mechanics
- Replies
- 2
- Astronuc
- · Replies 2 ·
- Aerospace Engineering
- Replies
- 2
