Jump In The Capacitor Voltage?
The discussion centers on whether a capacitor's voltage can experience a jump, despite the principle that voltage is continuous. It is noted that charging a capacitor requires current, and theoretically, charging it instantaneously would necessitate infinite current, which is impossible. The conversation explores the concept of charge being quantized and how this relates to quantum mechanics. Ayy's explanation emphasizes that charge results from the flow of electrons, which move at finite speeds, indicating that charging takes time. Ultimately, while a square wave voltage can charge a capacitor rapidly, it cannot do so instantaneously.
symsane
I know that voltage of a capacitor is continuous. However, I want to learn that; can it be a jump in the capacitor voltage? Also, if it is, how it can be happened?
Classically, to charge a capacitor requires current. To charge a capacitor in zero time requires infinite current, which is not possible. I could imagine that if the charging were very fast, it might be reasonable to approximate it as an instantaneous jump in voltage.
But charge is quantized. I wonder what happens in the quantum mechanical case. :confused:
charge on a capacitor is given by q = CV...there is superficially no time here ...BUT
atyy's explanation is a good one: charge is the result of the flow of electrons which have have finite, not instantaneous speed...in fact charge in coulombs is given by q=it...amps times time...so in this formulation you can see...charging takes some "t"...
in fact a step function (square wave) voltage will charge it really,really,fast...but not instantaneously...
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
