Just need someone to clear something up for me
  • Thread starter Thread starter iminhell
The discussion revolves around the complexities of gravitational theories, particularly Einstein's general relativity and Newton's laws. It highlights the concept of distorted space fabric, where larger masses like the Sun influence the orbits of smaller masses like Earth. The Earth is indeed moving away from the Sun at an average rate of 15 cm/year due to tidal friction, which also affects the Moon's orbit. The conversation clarifies that if Earth were not in orbit, it would fall into the Sun, emphasizing the importance of orbital mechanics in understanding these movements. Overall, the thread seeks clarity on the relationship between Earth's motion and the Sun's potential changes, suggesting a need for further exploration of these concepts.
iminhell
I'm fascinated with space and all it's wonder but don't have much time to read about it. Recently taking some time to watch a few video's I've missed, and am enjoying them. But I'm coming up with questions that don't seem to mix well, or maybe it's just the analogies used that don't fit well?
The one that troubles me the most is this distorted space fabric theory, larger mass distorts fabric more and objects of less mass rotate about the higher mass ones ... marble in a funnel idea.
With that model I've seen people talk that nearing infinity the object of less mass will at some point prior to infinity hit the object it's orbiting around. But yes when I ask Google if the Earth is moving away from the Sun it tells me yes, and at an average rate of 15cm/year. source
- but how was this measurement taken? (3 points like GPS)
I assume one point, or maybe the only for all I know, was the Sun. So I ask Google, because I recall reading it years ago, is the Sun shrinking. It gives me a very good link that does not definitively say yes or no. source
But in my mind, the dark place that it is, one, the other or both have to be true for the marble in the funnel to be true, right?
If the Earth, according to General Relativity, should be moving closer to the Sun and someone's data says it isn't but someone else says that the Sun may be shrinking (at a rate faster than we're moving away I'd bet); then we would be moving closer to the Sun, right? (2 steps back, 1 forward sort of deal)
I'm just not sure what to search on at this point. So if someone could point me in the right direction would be great. Quite sure I'm not the only one who's been confused on these points, so there has to be something explaining the quandary.
-John
Space news on Phys.org
That's Einsteins general theory of relativity's way of describing gravity.
It mostly gives the same answer as Newton's law - that the gravity force between two object is the two masses multiplied together divided by their distances squared.
There are some areas where Einstein's theory is better but mostly they are different ways of looking at the same thing.
Newton's law says that as objects get closer the gravity between them gets bigger and at 0 distance the force will be infinite. This is impossible but that's ok because you can't put two real objects zero distance apart.
That's completely different and not unexpected - the moon is moving away from the Earth for the same reason. It's a little difficult to really believe unless you know more about orbital mechanics - but the moon slows the Earth's rotation slightly and moves further as energy is lost. The same thing is happening between the Earth and the sun (goolge for tidal friction)
The Earth would move to toward and crash into the sun if it wasn't moving in an orbit around it. If the Earth somehow stopped it would fall straight into the sun!
I always thought tidal friction was very interesting (well, at least since I learned about it).
The basic idea here is that astronomical bodies aren't perfectly rigid (whether we're talking about moons, planets, stars, whatever). So when you have to bodies in a mutual orbit, they tend to pull one another into very slightly oblong shapes. This happens much more readily for fluids, which, for instance, is what causes the tides on Earth.
But the crucial thing here is that if the two bodies aren't rotating perfectly in sync, the distortion of the planet tends to get slightly out of sync with the body that caused it. For the tides our own moon causes, for instance, because the Earth rotates faster than the moon's orbital period, the tides are always pushed a little bit ahead of the Moon by this faster rotation.
In turn, the resulting elongated shape of the Earth results in a slightly different gravitational pull on the Moon. Because the elongated part of the Earth is slightly closer to the Moon, and because it remains ahead of the Moon in its orbital path, it tends to cause the Moon to speed up in its orbit. This has the effect of causing the Moon to go into a higher orbit, as well as slow the Earth's rotation. Eventually, the same side of the Earth will always face the Moon, just as the same side of the Moon currently always faces the Earth. This is known as "tidal locking".
Of course, the effect is small, but it large enough to make a significant difference over millions to billions of years (how long depends upon how close the bodies are and how massive they are), and very accurate measurements today are also able to measure the tiny changes in distances that it causes on shorter time scales.
Well, that or it would move in a hyperbolic trajectory and escape the Sun's gravity entirely. But obviously the Earth formed from the same gas cloud that formed the Sun, so either situation is highly unlikely.
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
The formal paper is here. The Rutgers University news has published a story about an image being closely examined at their New Brunswick campus. Here is an excerpt: Computer modeling of the gravitational lens by Keeton and Eid showed that the four visible foreground galaxies causing the gravitational bending couldn’t explain the details of the five-image pattern. Only with the addition of a large, invisible mass, in this case, a dark matter halo, could the model match the observations...
Hi, I’m pretty new to cosmology and I’m trying to get my head around the Big Bang and the potential infinite extent of the universe as a whole. There’s lots of misleading info out there but this forum and a few others have helped me and I just wanted to check I have the right idea. The Big Bang was the creation of space and time. At this instant t=0 space was infinite in size but the scale factor was zero. I’m picturing it (hopefully correctly) like an excel spreadsheet with infinite...
