Kinematic Equation Homework Question
  • Thread starter Thread starter vmercadooo
    Homework Kinematic
The discussion focuses on solving a kinematic equation problem involving a rock released from a 40 m tower with an acceleration due to gravity (g) of 9.8 m/s². The correct final velocity of the rock as it hits the ground is determined to be 28 m/s. The confusion arises from the sign conventions used for displacement and acceleration, with the consensus that both should be negative when considering downward motion. The equation used, v² = v₀² + 2aΔy, is confirmed to be appropriate for this scenario.
  • Kinematic equations, specifically v² = v₀² + 2aΔy
  • Understanding of acceleration due to gravity (g = 9.8 m/s²)
  • Concept of displacement in vertical motion
  • Sign conventions in physics for motion direction
  • Study the derivation and application of kinematic equations in vertical motion
  • Learn about gravitational potential energy and its relationship to kinetic energy
  • Explore the implications of sign conventions in physics problems
  • Practice solving various kinematic problems involving different initial conditions and displacements
Students studying physics, particularly those focusing on kinematics and motion under gravity, as well as educators looking for examples of common misconceptions in these topics.
vmercadooo
Gwen releases a rock at rest from the top of a 40 m tower. If g = 9.8 m/s2 and air resistance is negligible, what is the speed of the rock as it hits the ground?
v0 = initial velocity = 0
a = acceleration = 9.8
Δy = displacement in y direction = -40
v = final velocity = ?
v2 = v02 + 2aΔy
v2 = v02 + 2aΔy
v2 = 0 + 2 (9.8) (-40)
v2 = -784
but v2 can't be a negative number. I'm guessing either delta y is not supposed to be negative, but I thought it should be since the rock is falling, not being thrown upwards, or gravity should be negative, but I thought that when motion is downwards, the acceleration due to gravity should be positive.
v2 = v02 + 2aΔy
v2 = v02 + 2aΔy
v2 = -784
Welcome to the PF.
If you have the y-axis pointing up, so that the displacement is -40m, then be sure to use the correct sign on the acceleration due to gravity. In which direction does that acceleration point?
BTW, I would have used a different equation for this problem, but yours is probably fine. I would have used:
y = y(0) + v(0)*t + 1/2 a*t^2
Spinnor:
That's the answer I got, too, but the correct answer is simply 28 m/s. I think something must be wrong with my axes/alignment.
vmercadooo said:
Spinnor:
Make the change I suggested, and you will get the correct answer.
vmercadooo said:
v2 = v02 + 2aΔy
v2 = -784
No. With kinematics problems, it's always best to think of vertical motion as positive in the upward direction and negative in the downward direction. Therefore, in this case, both displacement and acceleration are negative (the rock is accelerating downward, and moving in a downward direction).
Why would you use that equation? The OP isn't looking for the time. This equation would require more work, whereas the equation used by the OP gives the answer they're looking for directly.
Good point. The question was asking for the final speed, so the OP equation is the better one to use. I just hardly ever used that equation, that's why I mentioned the other one.
And I would have used gravitational potential energy at the top equals kinetic energy at the ground, which is very logical.:-)
  • · Replies 34 ·
