Kinematics and rigid body simulation
The discussion centers on simulating motion for rigid bodies using time integration methods, specifically addressing the discrepancy in the kinematic equation related to the missing one-half term. The user derives the position equation but realizes it does not align with the kinematic equation due to the assumption of constant velocity, which is incorrect when acceleration is present. The conversation highlights the importance of using average velocity in calculations, particularly when dealing with uniform acceleration, to accurately represent motion. A connection is made between the area under a velocity-time graph and the kinematic equations, emphasizing that the exact velocity at each time point should be used. The user seeks feedback on their code and understanding of the physics involved in the simulation.
clipmon
Hello, I have a question regarding how I'm simulating motion using the common time integrating approach to simulating rigid bodies.
I have net forces and solve for position from those:
acceleration = force / mass
velocity = initial velocity + acceleration * time
position = initial position + velocity * time
but if you combine the above and distribute you get something that matches the kinematic equation, but is missing the one half term. Where'd it go?
position = initial position + (initial velocity + (force / mass) * time) * time)
position = initial position + initial velocity * time + (force / mass) * time^2
which does not equal the kinematic equation
y = y0 + v0*t + (1/2)a*t^2
Where'd the one half go?
That applies only if the velocity is constant. Since you have an acceleration, velocity is not constant & you cannot use these expressions.
Do you know calculus? (simple integration). It can very easily be proved with calc.
As graphene points out, the velocity isn't constant.
Here is a short route to arriving at y = 1/2*a*t^2
If the velocity is constant then in diagram the distance covered is proportional to the area of a rectangle. Draw a diagram with time on the horizontal axis and velocity on the vertical axis. So the line representing the velocity at each point in time is horizontal. As time progresses the rectangle stretches in horizontal direction. In other words, the distance covered is given by the area that is enclosed between the horizontal axis and the line that represents the velocity.
Now the case of uniform acceleration.
Then the line representing the velocity has a uniform slope. Interestingly, the total distance covered is still the area that is enclosed between the horizontal axis and the line that represents the velocity. The enclosed area is a rectangular triangle, and the surface area of a triangle is (1/2)*width*height.
At t=0 the velocity is 0,
At tend the velocity has climbed to a*tend
The area of the enclosed triangle is (1/2)*a*tend^2
These equations should be good for constant acceleration, and since I'm doing fixed time steps changes acceleration should always be constant. I've taken calculus and physics and have the books and follow the derivation of the kinematic equation.
y'' = a
y' = a*t + c1
y = (1/2)a*t^2 + c1 * t + c2
where c1 = initial velocity and c2 = initial position
Looking in my physics book I see they define the kinematic equation in terms of average velocity
avgvel = (initial velocity + velocity) / 2
Which I think is where the one half is coming from, but do I need to find average velocity if I'm doing 16ms time steps? I'll start looking into the difference of average velocity / velocity to see if I can figure things out.
Alright Cleonis's explanation relating it to triangle area made things mentally click for me, I need to use the average velocity term. Thanks!
By coincidence a calculation that works with average velocity can end up looking the same. Don't be distracted by that: the relation:
y = (1/2)*a*t^2
is exact. Whenever the acceleration is uniform it is exact for every point in time.
Your purpose is not to average the velocity; your purpose is to use the exact velocity at each point in time. In this particular case it ends up looking the same.
