Kinematics bouncing ball problem
The discussion centers on a kinematics problem involving a ball bouncing elastically in a moving train compartment. The ball has a speed of 1 m/s relative to the train, while the train itself moves at 10 m/s. Observers on the ground see the ball's speed as a combination of its speed relative to the train and the train's speed. The direction of the ball's motion changes with each bounce, affecting its observed velocity from the ground. The correct interpretation of the ball's velocity and the implications for the multiple-choice options are clarified throughout the conversation.
mridulag
given below is a more than one choice type MCQ,
A ball is bouncing elastically with a speed 1 m/s between walls of
a railway compartment of size 10 m in a direction perpendicular
to walls. The train is moving at a constant velocity of 10 m/s parallel
to the direction of motion of the ball. As seen from the ground,
(a) the direction of motion of the ball changes every 10 seconds.
(b) speed of ball changes every 10 seconds.
(c) average speed of ball over any 20 second interval is fixed.
(d) the acceleration of ball is the same as from the train.
i could not understand what observer at ground will see,is it ball velocity i.e 1m/s or ball velocity relative to train.
please give answer with an explanation
Hi mridulag, welcome to PF.
1 m/s is the speed of the ball with respect to the train.
ehild
is it then 1st option be correct .Will the ball will retain its velocity 1m/s unjustyfyng option b?.
IN answer sheet b,c,d options are given correct
Inside the compartment, the direction of motion of the ball changes every time it bounces off from the compartment wall. How do you express the velocity v of an object observed from the ground, if it has some velocity v' with respect to an object, traveling with velocity V with respect to the ground ?
What is the velocity of the ball observed from the ground when it moves in the same direction as the train, and what is it when it moves backwards inside the compartment?
ehild
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
