Kinematics - trajectory formula
The original poster seeks to find the trajectory formula in the context of kinematics, specifically involving trigonometric identities and their relationships to the variables involved.
  • Participants discuss various trigonometric identities and their potential relationships to the trajectory formula. There are attempts to express variables in terms of each other, and questions arise about the correctness of these relationships.
Some participants have provided guidance on simplifying expressions and have pointed out potential mental blocks in understanding the relationships between the variables. There is an ongoing exploration of how to manipulate the equations to arrive at a parabolic form.
There appears to be some uncertainty regarding the application of trigonometric identities and the correct substitutions to use in the equations. The discussion includes attempts to clarify these points without reaching a definitive conclusion.
quas
given :
i need to find the trajectory formula
i'm not sure if to use :
[/B]
I tried different options with the trigonometric identities that I have written before:
thanks
quas said:
[/B]
If ##x## and ##y## are as above, can you not find a simple relationship? You've already quoted the relevant trig identity somewhere.
do you mean?
quas said:
do you mean?
No, I meant:
##\frac{y}{a} = \cos(2 \omega t) =## something to do with ##\sin(\omega t) =## something to do with ##\frac{x}{a}##
You're terribly over-complicating this.
PeroK said:
No, I meant:
Ok I can write ##\frac{y}{a} =1-2sin^2(\omega t) ##, also to ## \frac{x^2}{a^2}\ = sin^2(\omega t) ## and then insert ## sin^2(\omega t) ##
to the equation ##\frac{y}{a} =1-2sin^2(\omega t) ## . would it be correct?
You seem to have a mental block about replacing ##\sin(\omega t) ## by ##\frac{x}{a}##.
first of all thanks for your help it's not taken for granted
Last try:
in the end I will get : ## \frac{2x^2}{a^2}+ \frac{y}{a}=1 ## then : ## y= - \frac{2}{a}x^2+a ## and that's parabola figure . right ?
Last try:
It is!
  • · Replies 42 ·
  • · Replies 25 ·
  • · Replies 20 ·
