Kinetic equilibrum and chemical equilibrium
Kinetic equilibrium refers to a single particle species obeying Bose-Einstein or Fermi-Dirac distributions at a defined temperature, achieved through rapid scattering while maintaining particle number. In contrast, chemical equilibrium involves multiple particle species connected by processes that change particle numbers. The discussion highlights that a particle can be in kinetic equilibrium with itself while being out of chemical equilibrium with the universe, indicated by a "freezing out" process where reaction rates become negligible. The term "chemistry" can also encompass nuclear reactions that alter particle numbers, relevant to the early universe's conditions. Understanding these distinctions is crucial for grasping the dynamics of particle interactions in cosmology.
karlzr
All particle species are in equilibrium at early times of the universe. But I didn't find any book that makes the difference of kinetic and chemical equilibrium clear. I have some of my own opinions and I hope to get your comments:
(1) kinetic equilibrium means the distribution function obeys the Bose-Einstein or Fermi-Dirac distribution with a well-defined temperature. This concerns only one specific particle species. Then kinetic equilibrium can be reached as long as it scatters rapidly enough with any particle while keeping its particle number unchanged: ##a + b \to a + b##.
(2) While chemical equilibrium involves at least two particle species that are connected by processes that change the particle number: ##a + b \to c + d## or ##a \to b + c##.
So whether some particle species such as ##t## quark is in equilibrium depends only on the thermally averaged cross section related to that specific kind of equilibrium. Thermodynamic equilibrium means both kinds of equilibrium are satisfied. Same temperature applies only to thermodynamic equilibrium, right?
So when we say some particle freezes out at some point, we really mean it is out of chemical equilibrium with the rest of the universe but it may still be in kinetic equilibrium with itself and thus maintain a different temperature.
Thanks,
Space news on Phys.org
I think you are confusing particles with atoms.
Atoms must exist in order for any kind of chemistry to happen.
In the very early Universe there were no atoms, and only after it had cooled considerably, atoms appeared.
However nearly all atoms at that time were hydrogen or helium, and those do not chemically react.
Much more time then elapsed before stars formed and other elements were produced, and more time still until these heavier elements became dispersed into the intersellar medium.
Only at that stage could any chemical processes occur.
Not necessarily. The term "chemistry" can refer to nuclear reactions that change particle numbers. (More often you see related usage such as the term "chemical potential" to describe terms appearing in the thermodynamic equations for systems containing multiple particle species.) Such reactions certainly exist and are relevant under the conditions the OP is describing, so even if you don't like the term "chemistry" to describe what the OP is describing, what he's describing certainly occurs.
PeterDonis said:
Not necessarily. The term "chemistry" can refer to nuclear reactions that change particle numbers. Such reactions certainly exist, so even if you don't like the term "chemistry" to describe what the OP is describing, what he's describing certainly occurs.
Thanks.
I did not know of the term 'chemistry' being used in that context.
(but now i do - :smile:)
Basically, yes. What causes the "freezing out" is the rates of all relevant reactions that interchange the particle species under consideration with other species, becoming low enough to be negligible.
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Why was the Hubble constant assumed to be decreasing and slowing down (decelerating) the expansion rate of the Universe, while at the same time Dark Energy is presumably accelerating the expansion? And to thicken the plot. recent news from NASA indicates that the Hubble constant is now increasing. Can you clarify this enigma? Also., if the Hubble constant eventually decreases, why is there a lower limit to its value?
