Kinetic Friction Experiment Conservation of Energy Question
The discussion focuses on a kinetic friction experiment utilizing the conservation of energy principle, specifically in a driveline setup. The proposed experiment modifies a traditional setup by eliminating the sliding block and instead wrapping a line around a pulley attached to a weighted system. The inquiry centers on whether the same methodology for calculating friction can be applied to the pulley, with the understanding that the energy lost during the mass's descent is attributed to the kinetic friction in the pulley. The discussion concludes that the frictional force can indeed be calculated as the resistive force exerted over the distance of the pulley’s rotations.
  • Understanding of conservation of energy principles
  • Familiarity with kinetic friction concepts
  • Basic knowledge of pulley systems
  • Experience with experimental physics methodologies
  • Research the principles of energy loss in pulley systems
  • Study methods for calculating kinetic friction in mechanical systems
  • Explore experimental designs for measuring frictional forces
  • Learn about the dynamics of weighted systems in physics experiments
Physics students, experimental physicists, and engineers interested in understanding kinetic friction and energy conservation in mechanical systems.
elliott87
I am currently working on an experiment to find the kinetic friction in a driveline. The experiment uses the principle of conservation of energy and is based on the following experiment: http://hyperphysics.phy-astr.gsu.edu/HBASE/Class/PhSciLab/frictionex.html
The difference in my proposed experiment is that instead of having the sliding block on the table, there would basically only be the pulley and a line would be wrapped completely around the pulley attached to a weighted system.
The initial energy balance would still be the potential energy of the hanging mass, and a withdrawal from the system would be the mass hitting the floor and losing kinetic energy. In the experiment in the link, the rest of the energy is said to go to the sliding block (assuming a frictionless pulley I'm guessing). My question is can the same methodology be used to calculate the friction in the pulley in the case of my experiment (no sliding block)? ie. Would the rest of the energy in the system, assuming it is kinetic friction keeping the mass from free falling at g, be equal to some frictional force over some distance?
If the friction is accounted for by the pulley and not the block then yes, you would be correct. The force over some distance would be the resistive force on the pulley and the distance would be the number of rotations the resistive force was exerted.
I'm a little confused near the end of this experiment when they solve for the force exerted on the block by the string (the pulling force) to be 0.63 N and then they say the frictional force is 0.63 N as well. What is the reasoning behind this? Here is the link again: http://hyperphysics.phy-astr.gsu.edu...rictionex.html
  • · Replies 77 ·
  • · Replies 65 ·
  • · Replies 20 ·
