Lagrangian mechanics for two springs
5 replies · 11K views
wglmb
A spring of negligible mass and spring constant k, hanging vertically with one end at a fixed point O, supports a mass m, and beneath it as second, identical spring carrying a second, identical mass.
Using a generalised coordinates the vertical displacements x and y of the masses from their positions with the springs unextended, write down the Lagrangian.
Find the position of equilibrium and the normal modes and frequencies of vertical oscillations.
KE: [tex]\frac{1}{2}m(\dot{x}^{2}+\dot{y}^{2})[/tex]
PE: [tex]mg(l+x)+mg(2l+y)+\frac{1}{2}kx^{2}+\frac{1}{2}k(y-x)^{2}[/tex] [tex]=mg(3l+x+y)+kx^{2}+\frac{1}{2}ky^{2}-kxy[/tex]
Lagrangian: [tex]L=\frac{1}{2}m(\dot{x}^{2}+\dot{y}^{2})-mg(3l+x+y)-kx^{2}-\frac{1}{2}ky^{2}+kxy[/tex]
Equations of motion:
[tex]\frac{d}{dt}(\frac{\partial L}{\partial \dot{x}})-\frac{\partial L}{\partial x}=0 \Rightarrow m\ddot{x}+mg+2kx-ky=0[/tex]
[tex]\frac{d}{dt}(\frac{\partial L}{\partial \dot{y}})-\frac{\partial L}{\partial y}=0 \Rightarrow m\ddot{y}+mg+ky-kx=0[/tex]
Know that [tex]B_{ij}\ddot{q}_{j}+A_{ij}q_{j}=0[/tex]
[tex]\Rightarrow B=\left( \begin{array}{cc}<br /> m & 0 \\<br /> 0 & m \end{array} \right), A=\left( \begin{array}{cc}<br /> 2k & -k \\<br /> -k & k \end{array} \right)[/tex]
[tex]B^{-1}A=\left( \begin{array}{cc}<br /> \frac{1}{m} & 0 \\<br /> 0 & \frac{1}{m} \end{array} \right)\left( \begin{array}{cc}<br /> 2k & -k \\<br /> -k & k \end{array} \right)<br /> =\left( \begin{array}{cc}<br /> \frac{2k}{m} & \frac{-k}{m} \\<br /> \frac{-k}{m} & \frac{k}{m} \end{array} \right)[/tex]
Eigenvalues turn out to be:
[tex]\lambda=\frac{k}{2m}(3+\sqrt{5}) and \lambda=\frac{k}{2m}(3-\sqrt{5})[/tex]
This doesn't look very likely to be right.
Then when I work out the eigenvectors, I get (0,0) in both cases...
... where have I gone wrong?
When you moved the masses down x and y respectively, the strain energies increased as you have indicated, but the gravitational energies also increase?
Haven't I got that included in the [tex]mg(3l+x+y)[/tex] part of the PE? This comes from [tex]mg(l+x)+mg(2l+y)[/tex] which is mg times the height of the first particle plus mg times the height of the second.
The gravitational potential energy is decreasing with increasing values of x and y, so you need some negative signs.
Ah, I see what you mean - of course! I don't have time just now but I'll work that through later and see how I manage :)
Edit:
Hmm, well I still get the same matrices A and B, since they come from the double-dotted terms and the x&y terms. The constant terms (now -mg for both of the equations of motion) aren't used.
I have a feeling those constant terms shouldn't even be there, since none of the examples we've been given have any...
It's OK, I've figured it out now. Thanks :)
