Lambda decay, momentum of the pion and proton
33 replies · 6K views
Orodruin said:
You should be able to deduce this from 4-momentum conservation.
I think I understand the concept of 4 momentum, but I am unsure about if I will have to be using sin/cos or some type of geometry to find the angles. I understand the conservation of momentum so then, only the x component will change and it will be the cos of the angle ?
But my problem is there are two particles decaying, the pion and the proton so they would potentially both have different angles & momentum except I only focus on the pion right now
on Phys.org
4-momentum conservation is just energy and momentum conservation wrapped up into one and a more convenient way of constructing invariant quantities.
I suggest you write down the general momentum and energy conservation equations assuming that the pion has some unknown total momentum at some angle ##\theta## to the initial direction.
In this case I would assume the the energy conservation is simply Ea=Eb+Ec
However for momentum if I separate into the three components,
but then I am ignoring the proton and if I add in that
Pa=Pb+Pc I'm not sure how to combine the angle to this
Alternatively
http://www.dzre.com/alex/P442/lectures/lec_04.pdf
I see all their formulas for angles and such but I just can't relate it my head
