Laplacian term in Navier-Stokes equation
The discussion focuses on deriving part of the Navier-Stokes equations, specifically addressing the discrepancy in terms involving viscosity, η. The user initially calculates a factor of 2η in their derivation, questioning the assumption that the transpose of the gradient, ∇u^T, equals ∇u. Clarification is provided that the divergence of the velocity field u is zero, leading to the conclusion that the second term in their equation vanishes. Ultimately, the correct formulation results in η∇²u_i, aligning with the expected vector form in the equations. The conversation highlights the importance of careful notation and understanding of divergence in fluid dynamics.
Hypatio
I am trying to derive part of the navier-stokes equations. Consider the following link:
http://www.gps.caltech.edu/~cdp/Desktop/Navier-Stokes%20Eqn.pdf
Equation 1, without the lambda term, is given in vector form in Equation 3 as \eta\nabla^2\mathbf{u}. However, when I try to get this from Eq. 1, I get 2\eta\nabla^2\mathbf{u}. I am getting 2\eta because
\eta\left(\frac{\partial u_i}{\partial x_j}+\frac{\partial u_j}{\partial x_i}\right)=\eta(\nabla \mathbf{u}+\nabla \mathbf{u}^T)=2\eta\nabla \mathbf{u}
and then the taking the divergence gives \nabla\cdot 2\eta\nabla\mathbf{u}=2\eta\nabla^2\mathbf{u} for constant viscosity \eta
I suspect that my second step in the first line is wrong. But I don't get it.
Thanks in advance.
You might want to keep the divergence and the terms in the parentheses together to remind yourself that you only sum over the j subscript (which is repeated).
You should notice that the derivatives of the second term in the parentheses add up to the divergence of u.
I don't see a repeated subscript. Do you mean that \nabla\mathbf{u}^T=\nabla\mathbf{u}? That is in fact my assumption and thus why I get 2*eta, not eta. Is this not true?:
\eta(\nabla\mathbf{u}+\nabla\mathbf{u}^T)=2\eta\nabla\mathbf{u}
if so, what happened to the 2?
What rules am I missing??
In the original Eq. 1:
$$\frac{\partial} {\partial x_j} \left[ \eta\left(\frac{\partial u_i}{\partial x_j}+\frac{\partial u_j}{\partial x_i}\right) + \ldots \right]$$ has the subscript ##j## both outside and inside the parentheses.
The i-th component of the force (rewriting equation 1 with \lambda=0 ) is
F_i=\eta\sum\limits_{j}{\frac{\partial^2{u_i}}{\partial^2{x_j}}}+\eta \frac{\partial}{\partial{x_i}}\sum\limits_{j}\frac{\partial{u_j}} {\partial{x_j}}.
The second term is zero cause the divergence of u is zero hence all that is left is \eta\sum\limits_{j}{\frac{\partial^2{u_i}}{\partial^2{x_j}}}=\eta\nabla^2u_i.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
