Largest resistor value such that BJT remains in active mode
The discussion centers on determining the largest resistor value for a BJT to remain in active mode, given a transistor with a current gain (β) of 30. The key inequality derived is Vc - Vb > 0.4V, which is crucial for maintaining the transistor in active mode, as saturation occurs when Vce reaches 0.2V. The participants clarify that for a silicon transistor, the base-emitter voltage (Vbe) is largely constant, influencing the voltage relationship between the collector and base.
  • Understanding of BJT operation and active mode conditions
  • Knowledge of transistor parameters, specifically β (beta)
  • Familiarity with voltage relationships in BJTs, including Vce and Vbe
  • Basic circuit analysis skills
  • Research the implications of Vce saturation in BJTs
  • Learn about the role of β in transistor biasing and stability
  • Explore the characteristics of silicon transistors, particularly Vbe
  • Investigate resistor sizing for BJT biasing in active mode
Electrical engineering students, circuit designers, and anyone involved in transistor circuit analysis and design.
theBEAST
We are given that the transistor has β = 30. The BJT is shown below (along with the solution). Every value in the figure is given with the exception of the equation I circled in red:
What I don't get is how they got the inequality Vc - Vb > 0.4V? Where does this come from? I thought saturation occurs when Vce reaches 0.2V, so shouldn't our inequality be Ve - Vc > 0.2V?
Assume that the magnitude of the base-emitter voltage for the BJT is largely constant. What value might you choose?
theBEAST said:
I thought saturation occurs when Vce reaches 0.2V?
You are probably right. So at saturation what would be the voltage between C and B? Work it out for a silicon transistor.
